22' Sabrecraft
tech_support
Re: 22' Sabrecraft
Post by tech_support »
Should I put my stingers on the outside chine like it was before and one in line with the old motor mounts? Seems like the best places as I want the bottom of the boat supported in the same places it was before. Thoughts? Thanks.
Yes, that is how I would do it. :!:
Saltfix
Re: 22' Sabrecraft
Post by Saltfix »
Thanks Joel. It really helps to have good advice. My confidence goes way up when I have help like this. Your forum and time are much appreciated.
Dan
tech_support
Re: 22' Sabrecraft
Its why we are here :D
Saltfix
Re: 22' Sabrecraft
Post by Saltfix »
Gosh,
I hope I didnt mess up.
I was watching the epoxy/ gel coat vid and it said only certain epoxies bond with gel coat. I used west marine 105 with 205 hardener when I filled in my transom hole..in fact its all I've used.for everything. I hope this is one of the epoxies that works well with gel coat. I still have to finish/gel coat the outside before the outboard bracket gets installed. :doh:
tech_support
Re: 22' Sabrecraft
all epoxies bond to gelcoat, but not the other way around. In fact, epoxy will bond to gelcoat better than gelcoat will bond to gelcoat. :)
BUT, Gelcoat will not bond to most epoxies.
Saltfix
Re: 22' Sabrecraft
Post by Saltfix »
So, to finish the transom hole so it is nice and flush, just forgo the gel coat and use epoxy? It wont be seen anyway as the bracket covers it.
tech_support
Re: 22' Sabrecraft
Saltfix wrote:So, to finish the transom hole so it is nice and flush, just forgo the gel coat and use epoxy? It wont be seen anyway as the bracket covers it.
yes
Saltfix
Re: 22' Sabrecraft
Post by Saltfix »
Would your Quikfair fairing putty work to finish it?Its epoxy too. Does it come out white, with the white hardener? (I have some I just bought)
Thanks.
tech_support
Re: 22' Sabrecraft
its a light cream color. I would fill the hole 90% with epoxy/woodflour then finish it off with quick fair to make it smooth
Saltfix
Re: 22' Sabrecraft
Post by Saltfix »
I see on the how to section .. splicing plywood for stringers. It shows the max length of 16 ft using two 8' lengths with two ft splices...
How do I make longer than 16 ft stingers with 8 ft lengths of ply? How do I splice it?
May be simple, but I am hoping there is a recipe for maximum strength.
Hope this makes sense.
I was thinking two 8' and a 2' on one side and a 4' 8' and 6' on the other so my splices have the longest span.. the shortest would be 2' on one end.
