Finaly Mr Luke (my crazy heater that only blows luke warm air) Came through for me. The Butt was Bonded pretty strong..here is the other side....
Stitched the bow with consistant slack using the pencil..kept them 10" apart and 3/8" from the edge.
Gentlemen please welcome ....MadMax...
After the Butt was bonded it took 3 hours to get some of the frames tied... I reckon another three hours before I can take measurements for the bottom...
Baba’s FL14: MadMax in Toronto
Go Baba Go!
Do lots of diagnol checking before mixing the goop for fillets, and hopefully the weather will be in the 50's or 60's F consistently soon, which makes fillets and taping much more productive. With large exposed surfaces of wet epoxy, you really don't want it dropping below freezing anymore. You could get frost, and then as it melts, you get water contamination in the still wet epoxy, so be patient with what you tackle next.
Have you decided to do spot welds and then wet on wet, or embed the tie wraps? I'm a fan of spot welds, though it adds more time, but its nice to know the fillets are clean and free of tie wraps when done. I have 6 pieces of wire stitches in forever, cause the panels were very stubborn there. Looks like you're having fun now!
Looking good!
ks
Looking good!
ks
Baba,
I found it useful to run a stringline down the centre of the boat and check that it was perfectly symetrical. It only takes a few minutes to do and will ensure that you don't have any twist from stem to stern. Check the line is at right angles to the transom and that the distances to the sides on either side of the line at the frames are equal:
Mike
Mike
FL14 "Lake Dreamer" built.
Inorder to keep a consistent gap between the joints I used the Sacrificial plastic spoons.
A combination of Tie Wraps and Dry wall screws were needed to control the gaps and the symmetry of the frame. Screws to push and Tie wraps to pull.
So I started the measurement process...Used the strings like Mike Said...added one at the bottom too...I could easily move the Transom to get a perfect symmetry...but only a slight movement was needed to get everything twisted again.
Finally with the help of supports, MadMax was sitting perfectly square...and Baba scribed the Bottom...
Checked for smoothness and symmetry using a PVC pipe....Picked up my Jigsaw... and Suddenly I heard voices (in my head). It was Rick and Lbrewer and Mike...saying MEASURE MEASURE...TURN UPSIDE DOWN AND MEASURE...Also remembered an old friend saying Banana boats go round in circles...
I had been afraid of turning Madmax upside down..because the frame were too flimsy...
But like real trooper......Baba Decided to put away the bottom panels and turned the fragile skeleton of Madmax upside down...some of the screws came off but no real damage....
This was definitely a good move...accurate measurements can only be done with the frame upside down...
Baba is happy...
Baba is happy...
Well I am making the plan as I go along...but as I see this thing happening in my mind....ks8 wrote:......Have you decided to do spot welds and then wet on wet, or embed the tie wraps?....ks
I am thinking I should take one section at a time...spot weld, remove the ties/screws and complete the section before moving to the next.
I guess the epoxy welds have to be pretty hard before I take the ties/screws out...
I am going to take this project slow...and experiment and learn as I go along...
I feel very furtunate to have experienced builders provide their feedback on my work...Very valuable indeed.... Its like attending one of those cooking classes...you pay to attend...learn a new skill and go home with the food you make...
