I am new to boatbuilding so I am going to start with the FL14. What do I need to look for in an outboard motor. I keep seeing terms like "short shaft", "long shaft", "transom length". Can someone give me an answer as to what I need for the FL14?
Thanks,
PS - I am doing this to prove all of my buddies wrong. They are all betting it will sink on me.
FL14 Motor
Any gasoline-powered short-shaft outboard motor will push the FL14 to hull speed in any water you should be out in with that boat. Anything over 2-3hp won't make it go any faster, and will just weigh more and use more gas.
The new water-cooled 2HP Tohatsu 4-stroke sure looks like a sweetheart choice for this kind of boat: http://www.tohatsu.com/outboards/2_4st.html.
Trolling motor
I have seen some pics of the FL14 being powered by Trolling motors. Anyone tried this? If so, what results did you have?
I too have a 30# electric motor. I have been in a pretty good head wind and it holds it's own. It's not fast but it gets me where I want to go.
I also cut my transom down just a bit for the motor. It worked out well.
See my gallary at
http://gallery.bateau2.comindex.php?cat=10098
You'll love the FL14. My family had doubts when I built it but now I can't go out without them.
Good Luck!
Kent
See my gallary at
Good Luck!
Kent
