I thought of a few more questions.
1.Is the roof stong enough to stand on (when at anchor of course)? I also plan to extend it out over the rear cockpit. I like the foam core option. I will not do the flat roof but will have a 3 inch camber in it.
2. Are the benches in the cockpit structural? I would like to eliminate them.
3. I want to change the layout of the cabin and put a dinette on the port side, narrow up the aisle and offset the doors.
4. I would like to scale the boat down by 6% which would get me close to 22 feet.
Any comments appreciated.
Daddy
Gubbs GT23
Yes: strong enough to stand on it but not for permanent fly bridge.Daddy wrote:I thought of a few more questions.
The rear bench is structural. It can be replaced by a bulkhead 6 to 10" in front of the transom.
No problem with 3 and 4 except that it will become tight inside.
Daddy
Let's say replace it with a full height bulkhead in front of the transom, ideally 10 to 12" in front of it.
That bulkhead should be tied to the transom with a few uprights and a shelf. This will become a box, a beam that strengthen the transom and gives you some storage.
All this is for engines 25 HP and above. For slow speeds, a few transom knees are sufficient.
Daddy,
Sounds like you have some good ideas for your GT23. To answer your questions, I plan on putting a 115 hp Yamaha 4-stroke on the boat. I put a deposit on one that was a fairly good deal because he used it as a demo and it has only about 50 hrs on the engine. I got my windows from Wynne enterprise, they have a good website that you should be able to google if you are interested. I was quite pleased with their construction and think they will look good in this boat. I will post more pictures once they are installed, of course.
Cheers
Bill
Cheers
Bill
Ozzy,
My wife and I have been pushing really hard to have it in the water for our vacation in August. We want to do the Trent-Severn Canal system in it. I currently have an appointment with the dealer to install the engine on August 7th. So I better have it in 'floatable shape' by then! It won't be finished, as I will still have lots of interior work to finish, and lots of accessories to install, but it will at least be useable.
Cheers
Cheers
I can tell that you (and the Mrs.) have really been busting @$$. I'm impressed as hell with the progress and based on what I see, the August goal is certainly attainable.
Understanding that it won't be done, you could always work on it while you're floating through the canals
Greg and I got the hull primed, but we've hit another minor setback. I broke my ankle over the weekend while water skiing. Fortunately I'm wearing a boot, not a cast, and I've been given the green light to put weight on it. So in a week or two I may feel up to getting back over to Greg's for some actual painting. But I don't think I'll be much help when it comes time to flip her.
