Page 1 of 30
FS14 build saga continues......
Posted: Thu Nov 30, 2006 3:22 pm
by dborecky
Posted: Thu Nov 30, 2006 3:36 pm
by mecreature
Posted: Thu Nov 30, 2006 3:43 pm
I don't know how the thread was deleted. I found a wrong setting in this forum: any user could delete any thread! It's fixed and I posted the dimensions again one hour ago:
http://gallery.bateau2.com/forum/viewtopic.php?t=12123
Please compare to the drawing, I am getting confused by all the pictures.
Posted: Thu Nov 30, 2006 3:48 pm
I tried to compare and your distances are wrong, sorry.
More than 1-1/2" total differences.
Plus, there is something wrong with the shape of the stringers but let's fix the distance between frames problem first.
One thing I did not post in the other thread is the length of the bow mold but it is on the plans. Your bow mold is 3/4" too long.
Posted: Thu Nov 30, 2006 3:50 pm
I'm going to copy my messages in the other thread below.
The whole thread dissapeared! Somebody must have clicked the wrong button, sorry.
Let's restart it.
dborecky had problems with panels fitting at the bow. After many exchanges, we discovered that the molds (frames) were not located properly.
At least we think that is the problem.
I will repeat the last post about the exact dimensions below.
Frames (molds) locations on the strongback.
All these dimensions are on the plans but the tickmarks are difficult to see. The tick marks show from which side a mesasurement is taken.
The strongbacks are 127-1/8" long and we start measuring from the bow side.
The stern side of the bow mold is lined up with the forward edge of the strong back.
- From the bow mold (stern side) to the 1st mid seat frame (bow side): 36"
- From the 1st mid seat frame (bow side) to the 2nd mid seat frame (stern side): 16"
- from the 2nd mid seat frame (stern side) to the rear seat frame (bow side): 36".
This is extracted from the plans:
Except for the text under "molds spacing", that is how it is supposed to look on the plans but with the thickness of the lines, once printed, the tick marks are difficult to see. That is why I added the text about spacing.
I will lock the otehr thread, let's discuss this here.
Posted: Thu Nov 30, 2006 3:55 pm
by dborecky
Jacques,
Sorry about all the photos..... I thought they would help. I measured from the outsides of all frames not the insides so when you subtract for the thinckness of the wood 3/8 + 3/8 = 6/8 and the measurment I got was 5/8th for a total of 1/8th per frame width excluding the seat frames. Total of 3/8th off. Too short I think...
What do you think?... do I have a bad bow mold or did I mess up the stringers or .......
Thanks,
Derrick
Posted: Thu Nov 30, 2006 4:12 pm
by AdamG
This is just me, but I'd mod the stringers to fit the curvature of the hull panels myself. Maybe butt block some extensions on them. You could put the hull panels back on, and get under and trim a peice of cardboard to fit the curvature, and then use that as a template. Cut the end 8" or so off of your stringers, and make a new end conforming to the hull shape template, and butt block them on. You lose a day or two of work, and some scrap, but the problem is solved. It's not that your parts need to match the plans exactly...they need to match to eachother, and have the bottom be fair and the curvatures be even and natural....
It also looks like if you moved the forward frame back about 1 inch or so, it would better fit the stringers, and give your side panels more room to bend to meet at the bow. Getting the hull panels on the molds takes a lot of tweaking and adjusting sometimes. I had to trim my panel edges a little here and there to get a better fit.
Posted: Thu Nov 30, 2006 5:44 pm
by dborecky
Jacques,
Thanks for taking the time today on the phone. For those of you following this we figured my measurments were actually pretty good and only 1/8" here or there off. That would not explain the problem. We agree that the front of the stringers have been sanded too much and I lost too much curve but that should not effect the fair of the panels. We also figured that the bow mold was too long. I did pull the bow mold off this afternoon and measure it off the boat and it was very very close to the 38 1/8" called for in the plans. I cut off 1/4" from the straight edge and lowered the mold by about 3/16" or so and I started to stitch the boat very very lightly together. I will take a pick of what I have right now and post it for you all to see and for Jacques to take a look as well.
I was going to wait for this weekend but then I was in the garage and the wife was away so I started to cut and stitch again......
Jacque,
Let me know what you think of these latest pics..
Derrick
Posted: Sun Dec 03, 2006 7:20 pm
by dborecky
Posted: Sun Dec 03, 2006 8:12 pm
by baba101
You are a winner Derrick...
Its all easy from here onwards.....you are going to love this boat when its done...
