Joel
I am close to ordering the paint for the TX sled but the colors I want aren't normally stocked by bbc. I want Hatteras White/3656 and Seamist Green/2116. Should be ordering in the next week or so. Also, what do you think about painting the bottom with Sterling. I can't seem to get away from the idea and I want your opinion (cost aside) about touching up the unavoidable scratches as well as moisture resistance.
Thanks in advance
Huck
Ordering non-stock colors
Huck,
As long as the boat lives on a trailer, you can paint the undersides with Sterling. A few nights in the water is OK too, but over time the paint will soften if kept submerged.
The sterling paints all have different prices, the whites being the less expensive and the darker colors being more.
I will get a price on those two colors, but you can expect the Hatteras White to be in line with the other whites and the seafoam/mist to be close to the light blue carry. We get the paint within a few days, so there is no real delay.
Joel
Joel
- Muddler
Daniel:
Where did you get your color chart to determine the colors? I requested a chart from E-Boats earlier this week, should be here in a few more days. I thought you may have found a chart on the Net somewhere. I have had no luck in my search. I was hoping to The bottom of my PH18 is primed and ready to paint. I am going with a white on the hull and deck and a wide dark blue band just above the water line and a small dark yellow above the blue. I just need to see a color chart to know what to ask for.
Bill Bauer
Bill Bauer
Is it a Boat yet?
- Muddler
Sterling Polyurethane or Epoxy??
Well I got the color chart that I requested, Thanks Shine. Now I am a little confused. In the Sterling Epoxy paint section on E-Boats it says get a color chart for 64 colors. So why does the Color chart show Polyurethane Coatings? So are Epoxy paints polyurethane, or does the poly color chart the same as Epoxy?
Confused
Muddler
Confused
Muddler
Is it a Boat yet?
- fishingdan
Users browsing this forum: No registered users and 21 guests
