TW28 Luka
- TheBroomside
Re: TW28 Luka
It has been too long, so I forgot how to get the 'Glossieblack wrote' in the quote...TW28 Luka is certainly a great boat for cruising Europe's inland waterways.
You are right. The TW28 can take coastal waters, but at sea I do prefer sailing boats, with greater dynamic stability.
We are lucky to have a fine-mazed net of streams, rivers and canals. The canals date from as far back as the 13d century, the older ones w started as a river, so no straight lines. We do not have wilderness anymore, but the waterways are mostly in the nicest natural environments present here
Colin, I hope all is well with you. I think your build is great. It is certainly technically the most sophisticated, with the strict regulations in the UK. I am looking forward to see completion, perhaps next year?I seem to be stuck on other things not boat building,
This is displacement hull, so speed is limited by its 28 ft length. The engine is a Mitsubishi 4 cyl. of 39 HP, this is ample power for this hull. We have an 19x12 prop..4 gallons per hour at what rate of travel?
It might be good to share with potential builders.
At 1400 - 1500 rpm, 9.5 - 10 km/hr
At 1600 - 1800 rpm, 10 - 11 km/hr
Top speed 13 km/hr.
Travel is the essence, not 'getting there'. As the older canals wher build to serve medieval towns, there are plenty nice places worth visiting when cruising. Typically, we travel for a few hr, then stop to enjoy en visit the neighbourhood.
Anyway, there are speed limits on most older canals, often 9 km/hr
I agree. Although the picture was meant to show the nice cloudsBeautiful boat Peter!!! Jef
Greetings,
Peter
LUS
Re: TW28 Luka
FYI, the quote feature is
Replace name with the person. You need the quotes.
Code: Select all
[quote="name"]
Re: TW28 Luka
So hope its next year sorted out the mooring at the bottom of our road sad really as next door neighbour died so getting his mooring. Just finished gardening work we opened the garden for charity. Got marking to finish A level astrophysics should take a week and a bit daughter not starting new job till end of August so some sanding (oh joy) and then painting for the both of us
- TheBroomside
Re: TW28 Luka
Thanks, tried a lot of things, but forgot about the =Jaysen wrote:Replace name with the person. You need the quotes.
I am in a different field but have always been fascinated by astrophysics. You are a lucky guy - the astrophysics part, not the marking.Colin wrote:Got marking to finish A level astrophysics should take a week and a bit daughter not starting new job till end of August so some sanding (oh joy) and then painting for the both of us
Just a picture now and then would be fun. Its not the speed of building that gets you to the finish, just not stopping, whatever little visible progress is made. I think its Jaysen who called this the 'tractor approach'.
Re: TW28 Luka
I don’t think Jaysen is that clever. I’m pretty sure he’ll take the credit though.
Re: TW28 Luka
Peter, next week the Tough girl is going to Belgium. We're coming! I'll call you soon.
I can indeed confirm that a TW28 is a perfect boat for two people to make longer trips. She is a stable, easy to sail and comfortable boat.
Like the Luka, the Tough girl has a four cylinder Mitsubishi of 40 hp, she uses approximately 1.7 liters per hour of fuel at 1800 RPM. Her speed is then about 10 km per hour. My prop has a diameter of 16 inches and a pitch of 13 inches. So the consumption and speed are similar to the Luka, only the prop is different.
It would be great if Colin could make the crossing to the continent with his T28 next year. The Luka and the Tough girl would like to be the welcome committee.
An update of the Tough girl will follow in a few weeks.
Allard
Allard
TW28 Stoere meid, the best boat for long trips
- TheBroomside
Re: TW28 Luka
Yearly update: we just did spend 3 weeks on the Luka traveling the canals/rivers in the Walloon part of Belgium. Its the sixth season with the Luka, still extremely happy with this design.
Great fun, 71 locks.
Granddaughter being trained as young skipper
The highlight was the boat lift of Strepy-Thieu - 75 m high in one go,
and the 4 historical 19th century boat lifts ( 4x16 m) nearby in Strepy-Bracquegnie.
Great engineering, they are powered exclusively by gravity: the higher bin is filled a little higher than the lower one and pushes the lower one up.
They are located on the Canal du Centre.
Back in the home "port" of Leuven, we enjoyed the visit by Allard and Luppie with the Stoere meid, the other TW28 in the EU.
What happens to all the other builders?
Corto Maltese, Colin, Mike... Any progress? Unknown courageous TW28 builders? I was happy to see a new post by Rick, back at work...
I'll report back next year
Peter
LUS
Peter
LUS
- glossieblack
Re: TW28 Luka
Nice update thanks Peter.
Re: TW28 Luka
Great update!!!! Jeff
Users browsing this forum: Ahrefs [Bot], Dougster, Google [Bot] and 1 guest
