Thanks Baba! Of course, you can copy to your hearts content. My goal was to de-emphasize the straight shear line of the OB17. From a practical point of view, this was the perfect design for my boating program and budget but like some others, aesthetically I preferred the 'classic' shear line of the C17, C19, C21 and now the FS17. The graphic was my solution and thankfully it seems to have worked out. Because my building area was so tight, I could never stand back and see the 'big' picture. Now I can see that I should have rounded the corners of the transom graphic to match the sides. Oh well, maybe when I build my Otter 16 or the TW35
SHINE: Yes, the engine is the Optimax 1.5 liter HPDI 2-stroke in the 75hp configuration. The same engine comes as a 90hp and a 115hp.... hmmmm
The fuel consumption numbers are touted to at least 18% better than a comparable 4 stroke at most throttle ranges except WOT.
As an aside, I noticed the tach at 4200 rpm in the shot (can't quite read the GPS numbers). This means we're doing around 32 mph in a 1' chop. That's my 220lb son up front sitting the casting deck. Notice any spray? Me neither
