Xf-20 Livewell water pickup
I need help as to the best location for my live well water pickup. Live well will be located where the center seat would be located if my boat had one.Thanks, Richard.
Richard you'll need to have it where it will always be under water even when you are on plane. This leaves you two options one a seacock through the hull in the last 3' of the hull, or through the transom below the waterline with another type of shutoff valve. Do not use plastic pipe for these connections in case they should crack they will flood your bilge.
Hope this helps.
Hope this helps.
C17ccx, Mirror Dinghy
Users browsing this forum: Bing [Bot] and 15 guests
