Mawrob's FS14 build
The anchor locker and battery base tacked in. Other than the partial soles this is the first real addition to the plan. Really want to get the anchor out of the way. A previous 19' boat of mine had no anchor locker and the anchor and crate kept on getting in the way and stubbing ankles and toes. This locker is bigger than needed but I wanted to make allowance for the hatch size as well as provide room for the light base and cleat that will be mounted up front.
Some more updates
Made some good progress this week. Here are some updated pics:
Bench hatch and chase pipes:
Foam in the back and motor mount. Little screw up with the transom - somehow cut too low but this will not be noticable with the motor on.
Foaming beneath the soles:
Fish locker that I almost destroyed removing. I added too much foam and the box got pushed up - almost as good as before.
Anchor hatch and front locker:
Cutting rear deck:
Cutting rear deck:
- chicagoross
Thanks chicagoross. Bigger boat - hmm. Need a bigger workshop . My bigger (bought) boat is likely to see less use this year and my gas saving will cover the cost of the new materials - wonder if I can fabricate a stitch and glue for sale sign
I estimate I have about 100 hours in so far (12 to 14 hour weekends between sports and other events and 2 hour evenings and the occasional 1 hour early morning) since May 3, 2008 - my long suffering family . Probably about 70 hours to go now for a less than perfect finish. I have not spent much time pondering my work - I also order ahead as much as possible and am able to run off to a HD during lunch (not included in the time) - I have a tight schedule in MS Project that I adjust as I go along and try to stick to it - here is the rest of the plan - a little an*lFred in Wisc wrote:Nice looking boat and amazing fast build. How much time do you have into it thus far? Gotta say I'm a little envious of your construction progress in such a short time.
I'm guessing either you are really a "get it done" type of guy or you don't require sleep.
Fred in Wisc
Fillet Soles and decks 2 hrs 6/10/2008 20:30 6/10/2008 22:30
Glass Decks 2 hrs 6/11/2008 20:30 6/11/2008 22:30
Route rub rails 2 hrs 6/12/2008 20:30 6/12/2008 22:30
Flip Hull 2 hrs 6/14/2008 9:00 6/14/2008 11:00
Quick Fair Hull 1 hr 6/14/2008 11:00 6/14/2008 12:00
Quick Fair Setting Time 3 hrs 6/14/2008 12:00 6/14/2008 15:00
Sand Hull 1 hr 6/15/2008 10:00 6/15/2008 11:00
Quick Fair Hull 1 1 hr 6/15/2008 11:00 6/15/2008 12:00
Quick Fair Setting Time 3 hrs 6/15/2008 12:00 6/15/2008 15:00
Sand Hull 1 hr 6/15/2008 15:00 6/15/2008 16:00
Quick Fair Hull 2 1 hr 6/16/2008 20:30 6/16/2008 21:30
Quick Fair Setting Time 3 hrs 6/16/2008 21:30 6/17/2008 0:30
Sand Hull 1 hr 6/17/2008 20:30 6/17/2008 21:30
Quick Fair Hull 3 1 hr 6/17/2008 21:30 6/17/2008 22:30
Quick Fair Setting Time 3 hrs 6/17/2008 22:30 6/18/2008 1:30
Sand and Paint Bottom Coat 1 2 hrs 6/18/2008 20:30 6/18/2008 22:30
Bottom Drying Time 12 hrs 6/18/2008 22:30 6/19/2008 10:30
Paint Bottom Coat 2 2 hrs 6/19/2008 20:30 6/19/2008 22:30
Topcoat 1 6 hrs 6/21/2008 9:00 6/21/2008 15:00
Sand and glass fish hatch lid 2 hrs 6/22/2008 10:00 6/22/2008 12:00
Glue fish hatch lid 0.5 hrs 6/22/2008 12:00 6/22/2008 12:30
Sand and Fair Seats 2 hrs 6/22/2008 12:30 6/22/2008 14:30
Sand and Fair Seats Setting Time 3 hrs 6/22/2008 14:30 6/22/2008 17:30
Qfair Inside 1 hr 6/23/2008 20:30 6/23/2008 21:30
Qfair Setting Time 3 hrs 6/23/2008 21:30 6/24/2008 0:30
Sand & Qfair Inside 2 hrs 6/24/2008 20:30 6/24/2008 22:30
Sand & Qfair Setting Time 3 hrs 6/24/2008 22:30 6/25/2008 1:30
HIN Inspection 2 hrs 6/25/2008 20:30 6/25/2008 22:30
Prime Inside 2 hrs 6/26/2008 20:30 6/26/2008 22:30
Prime Inside Setting Time 12 hrs 6/26/2008 22:30 6/27/2008 10:30
Sand and Paint Inside Coat 1 6 hrs 6/30/2008 20:30 7/2/2008 22:30
Coat 1 Setting Time 12 hrs 7/2/2008 22:30 7/3/2008 10:30
Install Fittings 2 hrs 7/7/2008 20:30 7/7/2008 22:30
Install Motor 2 hrs 7/8/2008 20:30 7/8/2008 22:30
Rob,
It's coming together nicely.
I got two frames taped in place and the back seat top cut out. We've had some record setting weather the past week which makes working in the garage a real pain. My main problem now is where to put what. As Cracker Larry would say, "I'm pondering the problems". I'm thinking about putting the battery where you have your fish box and then put the gas tank under the middle seat, if it'll fit. The reason I don't know if it'll fit is that I haven't made up my mind what motor I want to put on it, 9.9 or 15 hp.
I like your idea of the anchor locker. Keeps it out of the way when not in use, I was thinking along the same lines. I plan to cut down the front fame and make it into a seat. I'm to clumsy to use it as a casting platform.
Keep up the good work.
don
don
Users browsing this forum: Google [Bot] and 11 guests
