rub rail material
frazoo
rub rail material
Post by frazoo »
I spent the morning over in the big shop cutting down some two by stock into 1/4" X 1-1/2" strips fourteen ft. long for my rub rails. It then occured to me that this is nothing more than lattice strips like you can get from any lumber yard for next to nothing.
Anyone tried lattice strips yet, and how'd it work for you?
frazoo
... use a bigger hammer.
Built and Using; V12, Cheap Canoe, Modified Honker 14
Strip Canoe (failed)
V12 and Honker Gone to Boat Heaven= Don't build with cheap ply
TomW
Post by TomW »
Fazoo, don't see why they wouldn't work. 1. Don't get pressure treated, they won't bond well with the epoxy. 2. Cedar would be great. 3. Would want the straightest grain possible to keep them from twisting. when putting them on.
C17ccx, Mirror Dinghy
bernd1
Post by bernd1 »
I used left over plywood 6mm Okume and made stripes.
After this I make 3 layers - step by step.
Bye
Bernd
:wink:
Lon
Post by Lon »
"Cedar would be great."
No need to be concerned about the softness of cedar or the oil in it reducing epoxy adhesion?
Lon FL14, GV11
Montana
Dukydo
Post by Dukydo »
As long as you already have them cut... I'd use them. Lattice is not usually the best cuts of wood and the finish is rough at best. From what I have experienced.
Spokaloo
Post by Spokaloo »
Cedar is very soft, but it glues wonderfully.
E
Brent
Post by Brent »
I used cedar for my OD18, It glued up fine , looks great.
The problem is the RUB part in rub-rail. I am thinking of what to cover them with when I am near a dock, which is often. Pilings and deck boards beat up the cedar badly.
I tried some pipe insulation which worked as a temp. bumper but did not stay long.
Just some thoughts.
Happy Building,
Brent
TomW
Post by TomW »
Duplicate
TomW
Post by TomW »
Brent found this, seems reasonable and should hold up. Also 40' lengths. http://store.hamiltonmarine.com/browse.cfm/4,15101.html
Boomer
Post by Boomer »
Not the prettiest thing in the world (but you can make it look o.k.) but if you can score a piece of old conveyor belting, it will work fine.
It's actually not that hard to find if you ask around.
I've seen big boats use old firehose. Don't know how that would work on a small boat.
Users browsing this forum: No registered users and 22 guests
