Curacao CS 25
- peter-curacao
- peter-curacao
Since I have to wait for the glass I started to fool around with some old hardwood (Surinam) what in earlier days had a pool deck function.
Inspiration was this pic I saw a couple of weeks ago on this forum
I really like the looks of that boat (shearlineboatworks) and decided to try and make a rod holder similar to the one in the pic above.
First I did cut out some marlins from 10 mm marine plywood that was a little mistake as you can see at the end because when sanding it changed color.
Then I cut in some details and fill it up with epoxy and sand dust from the hardwood
After that I glued 3 pieces of hardwood together cut out the form and again the marlins
Than I sanded the plate and put the plywood marlins in, and a lot of epoxy again with the sanddust
than sanded the hole piece again and varnished it sanded again and varnished it etc etc and than put the rod holders in.
although the plywood chanced color I still think I like it and will use it on my CS 25.
I'm really curious what you guys think of it
Peter
Peter
What do I think? Phenominal , fantastic , beautiful , I've got to learn how to do that
How did you make the cut outs (inlets) for the marlins?
Peter that is fantastic. I have done strait in-laying but nothing like that. My hat is off to you! They are beautiful. Did you make the marlins thicker than needed and then sand them down to base. I also assume you used a sharp craft knife to mark there position and carefuly cut out the design.
It is amazing the detail you got.
C17ccx, Mirror Dinghy
- chicagoross
Users browsing this forum: Google [Bot] and 5 guests
