I'm looking forward to your build. I like your FS12 pics... I check them often. I think the FS17 will be perfect cut down with the big deck! I really like the shape of the boat. I can see lots of variations with this boat.
On a side note... the Aquasport rebuild pics are great. I check them often as well!
FS17 low sheer
Exactly Donny. The casting decks make up for the sole. I believe the only other place you will need a peice of sole is in the rear for the transom. May be wrong there. Just build up the last frames to the height of the casting decks. Don't get me wrong you can put soles in if you want for storage, and to cover the foam if you use it, but you don't need to. And I might use a lighter plywood for them.
C17ccx, Mirror Dinghy
- peter-curacao
Users browsing this forum: Ahrefs [Bot], Amazon [Bot] and 3 guests
