fs18 or sc16
- New Poster
fs18 or sc16
Ive been really looking to build an fs18 but I love the lines of the bow of the sc16 can I and what would the effects of building an sc16 with 4ft + beam all the way to transom like the fs18 could the weight be keep down to the 250# range given add ons such as stringers and a sole
It's probably easier to build the FS18 and change the sheer so it has the lines of the SC16. No real structural changes, so it would be pretty easy but you'd need a few extra sheets of plywood.
Changing the width of the SC16 in the way you describe would require all the panels to be recalculated, which would not be an easy task.
Fred in Wisc
Fred in Wisc
I agree with Fred start with the FS18 and change the shear to the SC16. In fact if it was me I would buy both sets of plans and interpolate the SC16 numbers onto the FS18 shear, for $50 it would be worth it to get it right. I don't know how much extra room you have on the FS18 nesting so be prepared to buy 2-3 extra sheets of plywood.
Good luck and have fun. I love the planning process.
C17ccx, Mirror Dinghy
Use the FS18 as your base. The SC16 is not only smaller in size, but the scantlings are too light to be used on the bigger boat. In other words a SC16 built to be larger, will not be strong enough without making it more like the FS18.
If you want a sole, just forget about the SC16 altogether. Everything you describe that you want is the FS18 to a "T". You can modify the shear line look like whatever you like, thats easy.
Joel
Joel
- New Poster
How hard is it to lower the sheer from the plans? I like the FS17 Low sheer version Joel is building but I think it could be cut down some more for shallow water sight fishing on the Lower Laguna madre. Is it simply a matter of chopping say 12 inches from the frames and then subtracting an equal measurement from the side panels?
Not difficult, simply draw the side panels as normal then use a tracing gage of some sort to reduce the sheer line by whatever you like.Anonymous wrote:How hard is it to lower the sheer from the plans? I like the FS17 Low sheer version Joel is building but I think it could be cut down some more for shallow water sight fishing on the Lower Laguna madre. Is it simply a matter of chopping say 12 inches from the frames and then subtracting an equal measurement from the side panels?
12" is WAY too much, mine will be about 4" in places which will make for very low freeboard
