im looking to build a hardcore flats boat. i want the lowest possible sheer (for easy poling) with a full deck layout. i decided to go with the ob15 so it could fit in my garage and was it has a narrower beam then the ph series. i read a thread a couple monthes back that recommended building the hull with standard frames and creating a stringer system similiar to the fs18 or fs17 system.
this image was by another member and this is almost exactly what i wantto do.
well any input? would it actually work? i really dont want storage compartments, just maybe under front deck battery and portable gas tanks. i also plan to run minimum hp motor with tiller steering to reduce weight also. the only feature would be a poling platform i wish to have.
what do you think? also any input on how to minimize draft is good too (i know the decks will add weight)
