CV16 Wyvern
Re: CV16 Wyvern
Chris, those gunwales are going to look great And I love the fenders, very nice, very salty I used to know how to do that fancy rope work years ago, I need to re-learn some of it.
Re: CV16 Wyvern
Thanks for the encouragement!Cracker Larry wrote:Chris, those gunwales are going to look great And I love the fenders, very nice, very salty I used to know how to do that fancy rope work years ago, I need to re-learn some of it.
The fenders are easier than they look. Stopping is the hard part. I wasn't very neat at the end with the toggle. At that point however I did not care. You can only make so many overhand knots one after another before losing motivation.
I agree I love the look of the gunwales. Each step I take twords thier finished state makes me love them all the more.
Re: CV16 Wyvern
Well.... I got the foredeck on and the seats all glued down. last night I was sanding away, I was using a block because I am really begining to hate the noise of sanding with power tools. So I'm sanding along and the boat is shifting under my sanding stroke when suddenly the cobbled together cradle colapses. (no damage ) Now I must lift the boat off the cradle and rebuild the cradle and then put it back. what a drag.
Re: CV16 Wyvern
Almost had that happen myself, but caught it just in time and put in 4 diagnols, then went at again. Glad nothing broke, especially you.
With those parts in and cured, she should be much stiffer now. Starting the road to finish prep I imagine.
Re: CV16 Wyvern
Still some glass work to do, tape on the mid seats and cloth on the outside. Then about 10,000 epoxy drips to sand. The boat did not fall very far when the cradle broke. and only the bow end. the aft part of the cradel kept it upright and the bow dropped about 4 inches to rest on the a different part of the cradle. It wasn't a catastophe but it is something I need to fix before I go on. I'll have to think about redesigning the cradle a bit as she will spent a fair amount of time upside down on the cradle as I glass, fair and paint the outside. I was encouraged by the very solid thunk it made when it fell.ks8 wrote: Starting the road to finish prep I imagine.
Re: CV16 Wyvern
Here are pictures of the current state of Wyvern. All the seat tops are on and taped. The fore deck is on. I rebuilt the cradle today. Its much sturdier than before. The boat is much heavier than before. When the previous cradle colapsed it almost completely crushed the various supports. Just about the only bits left undamaged were the cross members with the wheels.
I've added a little pad as I discovered that the trolling motor that I will use would not clamp onto the transom without a block.
I've added a little rail to stop water from running off the foredeck into the cockpit.
Re: CV16 Wyvern
Hey hey! There she is!
Her first embarassing naked baby picture!
Now you get to do more of that part you really like.... fairing and sanding.
What camera/lens are you using? Nice job of picking angles....
Re: CV16 Wyvern
I just need to get in there and do it. When I work on sanding I always hate it. but I love the result. I just went back and looked at the begining of this thread, its encouraging. I need to keep advancing the project. The problem with sanding is that it does not really change the shape of the project so it does not seem like a big advance. I liked the painting. That was very dramatic visually.
I use a Canon SD1000 PowerShot. I like it, its a great camera, very small, fits right in your pocket, you wouldn't even know that you have it.What camera/lens are you using? Nice job of picking angles....
Re: CV16 Wyvern
That lense is doing a nice job.
My tape lines are invisible at the hull side seam. You can barely see them at the seat riser seam. It was fun watching them fade toward being barely perceptible. It will pay when you get primer on there and see the difference that some good fairing makes. I don't know that any CV16 builders make that inner tape line completely vanish. Its not hideously ugly, and helps if the tape is uniformly wide all along the top. When its a uniform dimension the full length of the seat top, it almost looks intentional.
If you work towards making those outer hull joint tape lines vanish, you won't be dissappointed. It is hard to describe until you see it with primer. Either way, you won't be dissappointed.... enjoy it. She's looking good! You're into pre paint prep. Moving right along!
Re: CV16 Wyvern
I sat in the boat for the first time the other night. My new cradle is sturdy enough for me and the boat. It was weird to be onboard for the first time. I'm using quick fair to fill the weave of the biax and the edge of the tape. I'm doing a lot of sanding.
Users browsing this forum: Google [Bot] and 1 guest
