Rebuilding a legend 202 dominator
I need glass and epoxy for 202 dominator which is a bullet xd splash the transom and sole will be coosa composite the rest will be wood. The transom is 22x20x2 the stringers are 3/4x4inchesx12ft 2outside, the inside is stringer is also 3/4 but is eight inches tall under the sole about five ft. I will try to post as many pics as possible.
Re: Rebuilding a legend 202 dominator
trying to post pics
Shine I hope that these pics help some I got a little more done than the photos show. It got too dark for the rest of pics tommorow I should have transom out and patterns cut . I would also like to have stringers out and ground down with patterns made. Today was a good day didn't get started till noon but got it seperated. The boat was a little more solid than I expected . The transom was normal water rot everything else termite damage..
- peter-curacao
first four are a little big but let me try to help you
- Mad Dog
Hello 202,
Here is how to post pics from Photobucket.
With both the forum and your photo album open in View Album mode, scroll over the pic you want to post. A drop down box pops up. The select the "IMG code" and right click. Select "copy". Switch to the forum thread and and paste. Should look like this:
Hope this helps. By the way, is that peeled back carpeting on the left?
MD
MD
Ergo piscor, ergo sum
- peter-curacao
Indeed also you want to resize them to a bit smaller size, if you want to appear them complete on this siteMad Dog wrote:Hello 202,
yes that is carpet. I got it and the rest of the sole out . Filled up a truck bed with floor foam and carpet.
glad to see the cap come off, makes it easy to get to everything. Make sure the hull is supported well before removing the stringers and frames. In addition to the templates take a couple measurement of the height of the stringers a various locations, I find it helpful to keep a small notebook so i can reference it later.
