herocomplex wrote:Thanks for the reply Jacques. Like I said, I have no prior experience, so things feel like they happen incredibly fast. I simply have no baseline for comparison for how much time I should expect to have before things go nuclear. It really felt as if the medium hardener, at 55 degrees F, had less than 30 minutes before it was unworkable. My perception of time could have been off due to the stressful situation, though. Also, this was in a plastic dixie cup with little surface area. I'll do a test tonight to get real data. I'm sure that the problem is with my technique...I need to do a bit more research on working with epoxy.
I've done most of the epoxy work on my CV16 using 3oz batches. The smaller the batches the longer the pot life. 20 minutes is probably a resonable expectation for the amount of time that you have to apply the epoxy that you have mixed. The cadence goes someting like this:
1. mix up 3 oz of epoxy and precoat all the surfaces and edges . use any left over on the big surfaces of the panels.
2. mix up 3 oz of epoxy add wood flour to make glue ( catsup consistency ) use anywhere you need glue.
3. Add more wood flour and silica for fillets to the glue that you made earlier to use up an excess glue.
4. mix up 3 oz of epoxy add wood four and silica for fillets. Use left over for filling an gaping divots of which you are not proud.
5. cut fiberglass tape to size for all filleted seams.
6. Set the tape down on the still tacky epoxy precoated seams.
7. mix up 3 oz of epxoy and wet out tape. Smooth the fillets by running your gloved finger down the lenght of the taped and filleted seam. (very gentle pressure)
Work quick, work clean, plan on only doing what you can do in 15 minute blocks.
