Weather, work (pardon the four letter word) and all of that other stuff let up for a while and I had time to get back on the motor mount. My other excuse is that I'm not much of a tunnel rat and inchworming my way under the cockpit repeatedly isn't a fun part of this project.
Back at the back is the new backing for the bracket.
Here's a little better view.
I had to cut some kerfs in the backing plate to make it draw up to the slight camber of the transom. This is a bit of afterthought engineering. If I had it to do over again, I'd build the gusset into the stringer. It's probably overkill, anyway, but it just seemed like a good place for a brace.
O'Day 20 Rebuild and Refit
- gk108
Re: O'Day 20 Rebuild and Refit
CC, D15, V10
- gk108
Motor mount is dry fit and the wedges ready to fair.
Next up is the backstay chainplate. O'Day used the Rig-Rite CP-84-33X 3 hole T-shaped chainplate. I'm not sure how they assembled this part. The plate is trapped in place by the plywood backing for the rudder gudgeons. It's on the two bolts at the top of this picture, made during demolition.
The two bolts go through the hull/deck joint and the whole thing has always made me a little nervous, so I added a pair of SS links and two more bolts to make a stronger anchor point for the backstay.
Here it is from the inside. An extra nut and a washer spaced the stbd link out enough to clear the plywood backing. No lock washers on the new bolts yet. They still have to be removed for painting. Fender washers under the links to make a bearing surface with no sharp corners and a dab of 5200 to keep them in place during painting.
There's a little discoloration in the plywood backing where the gudgeon bolts went through, so I'll definitely be overdrilling and filling those holes with epoxy.
I'm still hung up on some details for my swim platform/ladder mounting. I need some braces to go from the transom to the back of the platform and can't seem to come up with anything satisfactory.
CC, D15, V10
- gk108
Nav light, stemhead fitting, pulpit rail base, chock and cleat mounting holes drilled oversize, filled and drilled to finished size.
A few more dabs of Quick Fair here and there and I'll be ready to prime the cabin and deck.
CC, D15, V10
Are there any more updates?
I have started refitting an '74 O'Day 20 and have found this thread to extremely informational.
When fitting the compression post, was there a gap between the outside shell and the internal headliner?
Thanks
Thanks
How is your mast set up?
It probably has a compression post but some Oday's have a threaded post that allows you to put tension on the rig.
That leaves a gap when you unstep the mast.
I have an ODay 17 and there is no liner but there is a backing plate under the deck at the compression post.
Please take pictures of what you are referring too and I will try to help.
Except for some specific details, fiberglass repairs techniques are the same of all boats.
Haven't heard from GK lately. Hope he's OK.
- New Poster
I am begining a rebuild and refit on a 1974 Oday 20. Would love to have access to your album of pics that you posted several years back. I can't seem to download them from this Boat Builders Central website. Thanks, Jim Palmer jpalmer415@gmail.com
Larry deleted a bunch of his pictures a few years back. And I hate to tell you but Larry passed away
I'm guessing Mr. Palmer was looking for GK, but he appears to be offline for a long time now.
