Very nice cuts and amazingly straight, which I'm not too good at with a rotary tool such as a router. The home made jig for the table saw is neat too, always good ideas to be had. Thanks for sharing.
George
Hope2float's P-21 in Jackson
- gstanfield
Re: Hope2float's P-21 in Jackson
Current build: FL14 (+10%)
Keep posting! I'm learning here!
- sitandfish
No one is going to ask you to delete anything. We will probably ask you the same question more that once, though. We forget.Hope2float wrote:...If you guys don't find this usefull I will delete it...
Lookin good there. I'll be sure to follow this one. I thing everyone here likes to see different ideas on cutting and nesting. I think Jaques does a wonderful job in the nesting, but it depends on the builder also. Very nice cutting job.
Completed: FL14, OD18
- Hope2float
Hey George, the cut on the transom is ok and made with battery saw. Fine tune the cut with a belt sander and you have the template the router uses 1/2" collet size with a 1"x5/16 flush cut bit. It is the reverse of a pattern bit. The template is on the bottom instead of the top. You just need to know where it is and the router will follow the template exact. All you need to do is keep slight pressure against template piece. The boat pieces are usually two identical so therefore make one nice and proper and use the router to make an exact copy of the first piece. Its like half of a CNC machine. I think the saying goes measure once and cut as many as you want.
These are pics of clamping boards. Thank you for the encouragement I don't want to fill you guys up with yada yada yada or bull doo doo.
But we absolutely love yada yada yada and especially bull doo doo!
Your work is great and can't wait to see you putting this girl together.
- gk108
Heck, that's the format I try to use in my building threads. Yada, yada, random boat term, yada. Cut yada yada and glued it to yada. Yada sanding! Yada DWL yada scuppers yada PPI. Bull doo doo stumps, yada graphite. Painted yada this color and yada that color. SPLASH!
CC, D15, V10
- topwater
Keep it comming , i for one dont know alot about woodworking tools and could use all the info
and tricks.
and tricks.
Novi 23 finally launched !
yada yada and beer. I caught this thread at a good spot.
looking good keep pics coming.
- Hope2float
Thanks all, Jaques nesting is fine. In small shop like mine being able to use one sheet instead of two half sheets helps to keep it organized and compact. There was no additional wood savings just a change in when its cut. I was able to save some wood on the stringer rips by changing the pecking order a little. Wound up with all stringers cut out of three sheets saving some misc. pieces on various sheets. Had three rips leaving about 3/4" max left over.
Dave
Dave
Users browsing this forum: Yandex [Bot] and 3 guests
