Frames pre-coated with neat epoxy on edges, filleted and taped in. Clamping board installed. Next will be a support for the rear deck at the clamping board. Will scribe off frame E shown and transfer this to the clamping board at appropriate height.
I dropped the clamping board down a bit. too many years doing custom trim and furniture. It's called a 'reveal' I I just can't help but put one in wherever two pieces of wood are stacked. Old habits die hard, I guess
Thanks Doc Dyer for moving that pic for me, I don't quite know what I did, but it worked tonight.
Rob Eades, I am thinking about a 4 hp, but depends on how 57 lbs sits on the transom. Might have to back it down, but if I have to go all the way down to 2.5 hp, I'll think hard about the elec. trolling motor again. Or maybe the ob on the transom and a trolling up on the from deck, weight should offset each other?
frazoo
frazoo's Honker "14"
Re: frazoo's Honker "14"
... use a bigger hammer.
Built and Using; V12, Cheap Canoe, Modified Honker 14
Strip Canoe (failed)
V12 and Honker Gone to Boat Heaven= Don't build with cheap ply
One of the best purchases I ever made was a little used Mercury/Tohatsu 3.3 two stroke.Its simple as can be,starts fisrt pull and weighs in at 29lbs.A trolling moter would also make sense since a displacement hull moves so easily.This is starting to look like a budget in-shore fishing boat!
Rob
Rob
- gk108
If the Torqueedo motors weren't so pricey the small one would probably be a good match.
If you go with a regular trolling motor, this link may be of interest:
http://www.kipawapropellers.com/
CC, D15, V10
Mock up of rear deck frame. I need to come up with something to allow me to seal off the motor mount access area so water doesn't fill the area from frame E to transom.
Budget inshore, near shore, concrete ships, 1st and 4th islands, grass flats, owls creek, hot ditch, and all rivers coming into the chesapeake bay.
Gk, yeah I like the torqueedos, but WOW , are they pricey! I'll check out the propellors site tonight.
No more work on boat 'til Monday or Tuesday, gotta go make a living this weekend.
frazoo
frazoo
A guy named Stefan built one of these a couple years back at one time there were videos of the boat online.I wonder if they are still out there? I had no luck finding them.
This looks like a great candidate to build with Ultraply.Its a good quality underlayment made with marine glue.Its $20 a sheet at Lowe's
Rob
Rob
- gk108
Rob, I finally found a post with that video link, but the site the video was posted on is gone now.
Frazoo, I noticed the prop co. has a dealer in Moultrie, right up the road from me. Next time I go that way, I'll see if they have any in stock that I can take a look at. I'm curious enough that I'd buy one if the price compares favorably with the factory props. With a 55 lb motor and a group 24 battery in my D15, I can go about 6 miles on a charge. With the narrower beam and rocker bottom, the honker might get 8 miles with that power setup. A different prop might get it close to 10 miles on a charge.
CC, D15, V10
Frame in and dry, support batten removed
rear deck rough cut oversized, once final cut, you will see more camber at the transom/clamping board.
Access hole is 4-1/2 X 8-1/4.
frazoo
frazoo
Splashwell problem solved.
frazoo
frazoo
GK108, where are you from? I was born in Moultrie and just got back from 10 day vacation down there. ALOT warmer than D.C. is nowFrazoo, I noticed the prop co. has a dealer in Moultrie, right up the road from me
Looking good frazoo she's gonna be a looker
Nice work Frazoo I don't think you are going to need a big hammer on this build...
Richard
viewtopic.php?f=12&t=62146
