Hi Guys, Finally had a few minutes to start a thread for our FS17 before she hits the water! A more condensed and orderly version than in our gallery. Enjoy!
Cut, glued and clamped the stringers
Built the jig with stringers installed, started stiching panels. Thought using PVC idea from Shines Low Sheer worked great-lined up the corners really well.
All seams taped and primed the whole hull. Getting ready to wet out the glass on the hull.
Glassed hull and found out later that it is much easier down the line to cut off the excess rather than overlap to much-as we did!
Fairing the hull isn't easy,especially when you get sloppy with the glass work. Thought we did a pretty good job until we started fairing.
seem to be out of room on this post window, so will submit and keep going.
FS 17 First build
- sitandfish
Re: FS 17 First build
Great documentation and very clean and precise work.
Back again! Put on micro balloons and built strakes out of silica, milled fibers and 1/2 in strands. Got the tip from Cracker Larry! Used an angle and worked great!
Putting on quickfair. After we put on Hi-build and finally put on a guide coat we sanded most of it off! Live and learn!
4 coats of high build later, which also came off with the fairing, after we put on the quide coat.
2 coats of Blue Water primer followed by 2 coats of Blue Water Mega Gloss-color is Sky Blue. Used a $40. gun from HF after a bit of practice. Great color, but maybe you get what you pay for! Came out with a little orange peel. Will probably opt for Sterling on our next build.
Cradle built and flipped her over. That's where we stand now!
Keep you posted.
Linda and Willie
Keep you posted.
Linda and Willie
Please doKeep you posted.
- stickystuff
Open the tip just a little will let more paint come out, also may be shooting with the air pressure a little high. practice on a piece of scrap plywood or card board and adjust the gun accordingly will help the flow cover better and not orange peel.
Capt. Ken Owens
orange peel or not, very fine looking boat. Keep it coming.
Dont outsmart your common sense!
- Bowmovement
Looks great. Love the color
Matt
Matt
"Aoccdrnig to a rscheearch at Cmabrigde Uinervtisy, it deosn't mttaer in waht oredr the ltteers in a wrod are, the olny iprmoetnt tihng is taht the frist and lsat ltteers be at the rghit pclae. The rset can be a total mses and you can sitll raed it wouthit porbelm. Tihs is bcuseae the huamn mnid deos not raed ervey lteter by istlef, but the wrod as a wlohe."
Nice looking hull, I love the color. The ninja will come in handy if you have to repel borders.
Not much time for building lately. Linda got a job and I'm trying to finish one in Ft Lauderdale. I'm hoping to have a few weeks before the next one starts and get some work in on it. Probably won't have it done before the meet at Boca.
We did find time to tape the inside seams the other day. Hope to do the inside glass this weekend if it's not to dang hot. Been awfull hot and dry down here lately.
Also found time to wet a line with the kids. Julia caught this little redfish off the dock. I love fishing with kids, they get so excited.
That's it for now.
We'll keep you posted
Willie
That's it for now.
Willie
Clean taping job Willie and Linda. Nice little catch too. Size doesn't matter too much when you're that age; it's just all about the tug on the end of the line
Will
Will
Users browsing this forum: Bing [Bot] and 8 guests
