I plan to repaint the entire cockpit. Clearly I need to prime the faired areas. What I'm not sure about is what prep I should do for the parts that are still in paint. My current plan is as follows:
- Sand everything with 80G paper.
Prime everything (including over the existing topcoat) with a couple of coats of high build epoxy.
Sand with 80G.
Apply finish primer
Sand to a 320G finish.
Roll and tip.
One other question: There are a lot of places where there's no way I can apply paint with a roller (long, 1" wide strips between trim boards). I'm thinking I may use a foam brush to dab paint on, and then tip it out with a brush. Is that a good approach? Or would I be better off just brushing it straight on?
Thanks!
-Ben
