simple question (fillers)
Micro balloons vs wood flour. When to use each. Advantages... etc.
Re: simple question
Wood flour is for glue and structural filler. Micro balloons are for fairing and smoothing. If you want to make it strong and stick forever use wood flour, if you want to make it smooth and pretty use micro balloons.
- peter-curacao
Re: simple question
Mix the wood flour with silica to get smoother fillets
Re: simple question
OK then, if someone was wanting to conserve as much weight as possible, is there something other then wood flour that could be used? Or is it just not a significant amount to worry about.
Re: simple question
Silica also helps with sagging.peter-curacao wrote:Mix the wood flour with silica to get smoother fillets
Re: simple question
. . . not a significant amount to worry about. -> correct.AMC wrote:OK then, if someone was wanting to conserve as much weight as possible, is there something other then wood flour that could be used? Or is it just not a significant amount to worry about.
Use the correct filler for each application.
Glue made with micro balloons may fail.
