Must be nice to be that close.Stuff wrote:... I went over Bateau this afternoon and got 1 gallon of medium hardener. ...
AD16 Karenina
Re: AD16 Karenina
Re: AD16 Karenina
Hi Stuff. I put swivel wheels on my cradle for the same reasons you did. I just wish I had one pair fixed so it is easier to control. I used a laser (bubble stick would be fine) to set the hull level in a specific location inside my shed. Then I could roll it all over different grades (the hull could twist) when I rolled it "home" it would sit level again. Be sure not to glue up the hull parts with the cradle in different locations unless you know your garage slab will allow it. Mark the centerline and other reference marks on the hull and cradle accordingly so you will be able to confirm the hull doesn't wander around on the cradle. I even had screws through the hull panels in the early stages to assure the hull stayed in the correct location on the cradle.
- Stuff
Re: AD16 Karenina
Thanks for the advice Bondo,
In the incoming weeks I am hoping to finish the basket. At this point I am concentrating on the lamination process. I Follow your advice and decided to buy some gel magic for lamination and putting togeteher the Transom, Ruder, Keel, centerboard and centerboard gabinet. I have not being able to post any pictures this week but hopefully this weekend I get a chance. I check my garage floor and I got lucky because the floor is relative level at any position.
Stuff
Re: AD16 Karenina
I started like you but held off on the cradle. The workspace is most comfortable to build in when there isn't some big plywood boat in the way.
- Stuff
Re: AD16 Karenina
Stuff
- Stuff
Re: AD16 Karenina
Cutting the Rudder. After gluing it my dad decided to make the profile. Next week I will post the pictures.
Stuff
- Stuff
Re: AD16 Karenina
Here is the centerboard. I need to make the profile before adding the lead. . All the Halloween decorations in the back. I need to organize the garage!!!
Stuff
- Stuff
Re: AD16 Karenina
my first big mistake. I decided to laminate the mast painter but forgot that it need to be bended. I was able to bend it with some deep cycle batteries but it was not enough. I need to cut a few groves in order to get the desire curvature. Hopefully it can be fix!
Stuff
