JerryF wrote:Generally the pine we get here in the western USA is much softer and lighter than Douglas Fir and would not be suitable for structural components IMHO.
A lot of the tree farm quality pine has wide growth rings and is, as Jerry says, not great for structural purposes. Douglas-fir, by the way, varies widely in strength from tree to tree, and is not necessarily stronger than some pines. As with any lumber, choosing wood with tighter growth rings will usually give you stronger sticks.
I cannot recommend the US Forest Products Laboratory highly enough. From their Web site at
http://www.fpl.fs.fed.us/documnts/FPLGT ... 3/CH01.pdf:
"Pine, Radiata
Radiata pine (Pinus radiata), also known as Monterey pine,
is planted extensively in the southern hemisphere, mainly in
Chile, New Zealand, Australia, and South Africa. Plantationgrown
trees may reach a height of 26 to 30 m (80 to 90 ft) in
20 years.
The heartwood from plantation-grown trees is light brown to
pinkish brown and is distinct from the paler cream-colored
sapwood. Growth rings are primarily wide and distinct.
False rings may be common. The texture is moderately even
and fine, and the grain is not interlocked. Plantation-grown
radiata pine averages about 480 kg/m3 (30 lb/ft3) at 12%
moisture content. Its strength is comparable with that of red
pine (P. resinosa), although location and growth rate may
cause considerable variation in strength properties. The wood
air or kiln dries rapidly with little degrade. The wood machines
easily although the grain tends to tear around large
knots. Radiata pine nails and glues easily, and it takes paint
and finishes well. The sapwood is prone to attack by stain
fungi and vulnerable to boring insects. However, plantationgrown
stock is mostly sapwood, which treats readily with
preservatives. The heartwood is rated as durable above
ground and is moderately resistant to preservative treatment.
Radiata pine can be used for the same purposes as are the
other pines grown in the United States. These uses include
veneer, plywood, pulp, fiberboard, construction, boxes, and
millwork."
