BarraMan's Mangusta 21 barraboat in Townsville, AUS
- glossieblack
Re: BarraMan's Mangusta 21 barraboat in Townsville, AUS
Looking good Lee. Whereabouts on the BBB are you installing it?
- BarraMan
Being custom built Michael to fit nicely under the big hatch in the fore deck.glossieblack wrote: ↑Thu Sep 27, 2018 4:18 am Looking good Lee. Whereabouts on the BBB are you installing it?
Looking good Barraman!
Nice BarraMan, nice cooler!! Jeff
- BarraMan
OrangeQuest
I am using West System105 epoxy, 206 slow hardener and 501 white tint.
I sanded the surfaces to be epoxied with 120 grit paper then rolled on tinted epoxy with a hard foam roller. I mixed the white tint into the epoxy until I had a nice "solid" white mixture.
I expect to roll on 3-4 coats of tinted epoxy to get the desired deep colour and smooth finish.
Wow! That is really looking good.
Maybe I needed to sand more before tinting. But I also remember that even though I added more tint than recommended it was never 100% solid color, was always a little milky. Thanks for the step by step, I am taking notes!
OQ
OQ
- BarraMan
Second coat of white tinted epoxy. I think one more will probably do it!
- glossieblack
Very nice!
Nice work BarraMan!! Jeff
Nice work BM.
That should keep your catch in prime condition for the table.
Is the cooler going to be fixed in place, or removable?
And one final question, is tinted epoxy subject to the same UV degradation as untinted epoxy?
Cheers,
Reefie
Cheers,
Reefie
"If you want something you have never had, then you've got to do something you've never done"
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 2 guests
