Jacques -- these are real questions about the GV15.
<BR>
<BR>And we can test the forum.
<BR>
<BR>If you remember, I want to extend the casting deck back to Frame 2. This design would make what is now seat 1 part of a long casting deck. Here are my questions about that:
<BR>
<BR>1) The cockpit sole is 1/2 in ply and the casting deck is 3/8 play. Since I am making the casting deck longer , should I increase it to 1/2 in ply?
<BR>
<BR>2) Is the cockpit sole structural and does it need to be under the extended casting deck? (If not, I can use the sole plywood for the casting deck if it needs to be increased to 1/2 in)
<BR>
<BR>3) Would rasing the casting deck cause a design issue? Right now it is about 7 inches below the top deck -- what if it was about 2 inches below the top deck?
<BR>
<BR>(I know you don´t like changes to your plans <IMG SRC="images/forum/icons/icon_wink.gif"> -- I´m just trying to understand what is changable and what should not be tampered with...
<BR>
<BR>Fritz <IMG SRC="images/forum/icons/icon_wink.gif"> <BR><BR><font size=1>[ This message was edited by: FritzNewWin200 on 15-08-2002 11:48 ]</font>
Test Post -- But real questions GV15
- Fritz
- Website admin
Lost -- but not forgotten.
>1) The cockpit sole is 1/2 in ply and the >casting deck is 3/8 play. Since I am making >the casting deck longer , should I increase it >to 1/2 in ply? <BR><BR>Switch: part of the sole under casting deck = 3/8.<BR>You could even build the hidden sole from 1/4", what counts is the FG seam all around.<BR><BR>2) Is the cockpit sole structural and does it need to be under the extended casting deck? (If not, I can use the sole plywood for the casting deck if it needs to be increased to 1/2 in) <BR><BR>See above.<BR><BR>3) Would rasing the casting deck cause a design issue? Right now it is about 7 inches below the top deck -- what if it was about 2 inches below the top deck? <BR><BR>No problem to raise it.<BR><BR>(I know you don´t like changes to your plans -- I´m just trying to understand what is changable and what should not be tampered with... <BR><BR><BR> <IMG SRC="images/forum/icons/icon_razz.gif"> <BR><BR><BR><BR><font size=1>[ This message was edited by: jacquesmm on 20-08-2002 15:45 ]</font><BR><BR><font size=1>[ This message was edited by: jacquesmm on 20-08-2002 15:45 ]</font>
- JohnM
hmmm, i couldn´t reply on the other forum. but i can on this one. and what´s my boat´s "SKU"? i thought that´s a barcode number.
You're already there.
SKU is GV15, FL11, C19 etc. We may change to "boat type".<BR>Thanks for the feedback: that is why we are testing.
- JohnM
thanks jojo...yes, boat type or "boat model" ... keep up the great work you bateau.com/amateurboatbuilding crowd!
Where did JoJo get the Baghead? I love it. Reminds me of New Orleans Saints Fans. <IMG SRC="images/forum/icons/icon_biggrin.gif">
Richard Warner
Louisiana: America's Banana Repu
- Fritz
- Website admin
Skydad, if you chose "Your Account" from the left column menu, and Edit your information, you will find a box for Avatar and a "List" link next to it.<BR><BR>CLicking on the List will show you several you can choose from. Find the ohne you like, remember the number, and then pick it from the prior screen. <IMG SRC="images/forum/icons/icon21.gif">
JohnM: This is a test message. I didn´t know they had to have codes for the bars in California. <IMG SRC="images/forum/icons/icon_wink.gif"> <BR><BR>Richard Warner<BR><BR><font size=1>[ This message was edited by: Skydad on 22-08-2002 21:08 ]</font>
Richard Warner
- JohnM
RW, in moments of crystal clarity (or insanity), have you ever wondered about designing and building a S+G experimental home-built airplane? Even if it´s remote controlled...maybe 1/2 size...maybe amphibious... ... Maybe a S+G skeleton with fabric covering...
<!-- BBCode Quote Start --><TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote:</font><HR></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE><BR>On 2002-08-26 16:02, JohnM wrote:<BR>RW, in moments of crystal clarity (or insanity), have you ever wondered about designing and building a S+G experimental home-built airplane<BR></BLOCKQUOTE></FONT></TD></TR><TR><TD><HR></TD></TR></TABLE><!-- BBCode Quote End --><BR><BR>Kern Hednricks, owner of System Three, has build an airplane with a method very close to stitch and glue. <BR>On my bookshelf, I have several books about amateur plan building and the techniques are very close.<BR>I sometimes go to the local airport and bother the guys at Evolution, picking their brains to see if they came up with new ideas or building methods. In general, they are more advanced, use vacuum bagging, thermo cure etc. but many techniques are common.
Users browsing this forum: Bing [Bot] and 6 guests
