GF16 end in sight??
Posted: Fri Mar 26, 2004 2:31 pm
The end is in sight (I hope). I applied the final coat of epoxy. I just need to sand some of the ridges down, go over it with some fine-grit sand paper, prime and paint. I'm using white, with green on the spray and rub rail. Inside will also be white with green spongepaint. Check out the below pic.
http://gallery.bateau2.com/displayimage ... 1896&pos=1
