AD 14 KIELGE
- glossieblack
Re: AD 14 KIELGE
Thanks for the explanation Karl. Are you going to make the boom and/or yard out of carbon fibre and glass fibre sleeves as per the bateau 3 part tutorial?
Re: AD 14 KIELGE
Hallo Michael,
Yes the boom and yard I already made a long time ago and they turned out perfect. In hindsight I could have made them with a smaller than 50 mm diameter but they work fine and weigh only around 900 gram each. On one I used peel ply and it weighs a bit less than the other.
Here a picture of boom and yard before fairing and painting :
and here are 2 pictures of them at my first sail :
I did not dare to make the mast myself because of the length and getting it straight.
Greetings from Karl
Greetings from Karl
Re: AD 14 KIELGE
Your rig looks great, Karl. I’m still trying to locate a yard and boom but haven’t had much luck
Re: AD 14 KIELGE
Nice Karl!!! Jeff
Re: AD 14 KIELGE
Hi,
Today after 2 sleepless nights because of thoughts about glueing my carbon mast pieces I did it at last and it took very little time. I think building my boat has taught me preparation for any task is the key to easy execution.
I first stuck on the 2 inserts lots of plastic tape around it like on the picture until it was the same diameter as the long pipes to make sure that it is completely straight lying on the table after glueing.
Mast head and middle insert ready for_gluing:
and then I mixed 25 grams of epoxy with 14 grams of hardener 3 teaspoons of silica and one spoon of wood flour and brushed first the insides of the long pipes and then the inserts themselves and slid them together wiping any excess epoxy away finished in 10 minutes.
Mast insert and head glued to the 3 meter long pipes:
Greetings from Karl
Greetings from Karl
Re: AD 14 KIELGE
Well done, Karl. Hope that mast makes things a lot easier for you
Re: AD 14 KIELGE
Great stuff, Karl.
But sorting out the solutions to odd problems you've never encountered before in life is one of the great pleasures attending almost all aspects of sailing. Well done!
--Well, and then there's fairing.I think building my boat has taught me preparation for any task is the key to easy execution.
Tony
- glossieblack
Re: AD 14 KIELGE
Nicely thought through and executed mast fabrication Karl.
Re: AD 14 KIELGE
Hi,
My carbon mast is finished and and my son suggested we should go for a sail on Saturday. Getting the boat ready at the slip was very fast with his strong help and he raised the mast in 15 seconds and then he insisted to make the following picture:
Me in front of the boat just before we put it in the water :
and here it is in the water next to the boardwalk :
and then I can only show a picture of the boat on the lake taken by my sister from the shore. I took this picture even that it is far away you can see my junk rig not much else.
We had a very nice time on the water although with practically next to no wind for four and a half hours.
Greetings from Karl
Greetings from Karl
Re: AD 14 KIELGE
Watch out for that rock!
Beautiful Karl!
Beautiful Karl!
Users browsing this forum: Ahrefs [Bot] and 11 guests
