fuel tank decision
Troutlet
fuel tank decision
Post by Troutlet »
I'm shopping for a bow mounted fuel tank for my OD16. I have it narrowed down to a Moeller 19 Gal with a 1/4" withdraw and a Todd 17 gal with a 3/8" withdraw.
Can anybody help me determine if the withdraw sizes would be an issue for me? A Honda 40hp 4-stroke is my planned engine.
Johnshan
Post by Johnshan »
I dont think you will ever have problems getting fuel from either size, a 40 hp 4 stroke is pretty light on the fuel use.
Others will chime in, I wouldnt sweat it.
-John
Edward
Post by Edward »
Ditto to Johns post...you'll be fine fuel wise. I'm just suprized that you are able to fit a tank of that size up there. I fitted a 12 gallon and I thought it was big. Are you leaving any anchor storage room up there ?
Troutlet
thanks guys
Post by Troutlet »
Thank both of you very much. I just needed to hear that it wasn't an issue.
The bow tanks are shaped for the bow (short on one end long on the other). The tank will fit and leave room for an anchor well plus additonal storage and hatches in the same casting deck. Pretty sweet huh?
TimeWalker
Re: thanks guys
Post by TimeWalker »
Troutlet wrote:Thank both of you very much. I just needed to hear that it wasn't an issue.
Dont scold me if I'm wrong but I believe the 140's are hte first engine that list 3/8" fuel line as a requirement
Rick
When you build something with your hands
Troutlet
size
Post by Troutlet »
140's? Do you mean 140hp?
Thanks Timewalker.
TimeWalker
Re: size
Troutlet wrote:140's? Do you mean 140hp?
Thanks Timewalker.
Yep 120-150 depending on the type and age of the engine ( ie: do they sip or chug on the gas)
Rick
TimeWalker
you can empty a 50 gallon tank with 3/8" tubing in about 30-40 mins tubing/pipe size is all about flow rate you will be hardpressed to find less then 3/8" tubing at places like bass pro but sometime take a look at your fitting (engine side) most are 1/4" with even smaller holes for gas inlet into the fitting
Rick
Evildwarf
Post by Evildwarf »
Got my tank at Boaters world,used 3/8ths because the enging can only use as much gas as it will.It won't flood, it won't load up and it won't drown in exsessive fuel. What it will do is fuel starvation!Which means stop.Evild.
Users browsing this forum: No registered users and 27 guests
