Page 1 of 44
Justin's P19
Posted: Mon Aug 19, 2013 4:11 am
by justin_dwyer
I have started building a P19 after a years deliberating which boat to build.
I collected a heap of wood from industrial bins around Darwin, can't believe what people throw out, I even found 2x6inch sleepers in a bin, enough for my strongbacks and all the uprights I'll need. Plus I scored a heap of ply from a demolision site.
I'd be grateful for any info, tips, tricks that might save me from making any mistakes that anyone has already made.
Cheers
Wood from the bins
Strongbacks
Good use of dead tomatos
Re: Justin's P19
Posted: Mon Aug 19, 2013 5:13 pm
by Joe H
Welcome aboard Justin,
Can't wait to see this one come together!
What kind of plywood are you using for the hull?
Joe H
Re: Justin's P19
Posted: Mon Aug 19, 2013 7:52 pm
by peter-curacao
Joe H
I was wondering the same thing, what are you cutting up there?
Re: Justin's P19
Posted: Mon Aug 19, 2013 10:20 pm
by justin_dwyer
Hi guys.
I am using AA Marine ply, 12mm for the transom (plus 2 clamping boards both 12 mm), 9mm for the frames and 6mm for the hull.
Why, what have you seen?
Re: Justin's P19
Posted: Tue Aug 20, 2013 7:49 am
by pee wee
justin_dwyer wrote: Plus I scored a heap of ply from a demolision site.
I suspect that comment made people wonder.
Re: Justin's P19
Posted: Tue Aug 20, 2013 8:40 am
by Joe H
You got it Hank!
Joe H
Re: Justin's P19
Posted: Tue Aug 20, 2013 8:52 am
by justin_dwyer
Haha, I should have clarified...I got all the stuff from the bins for frames, etc. I bought the marine ply.
What is an acceptable error range when measuring the diagonals from the transom outside edge to the opposite side on frame C, I have 2cm and think it is too much. Might start again.
What are your thoughts?
Re: Justin's P19
Posted: Tue Aug 20, 2013 10:06 am
I would say 10 mm (3/8) is fine. 20 mm is a little too much but not dramatically bad.
Re: Justin's P19
Posted: Tue Aug 20, 2013 10:40 am
I shoot for perfect
Why not
Re: Justin's P19
Posted: Tue Aug 20, 2013 11:47 am
Kick it.
I'm not joking, tapping one of the strongbacks with a rubber mallet is sometimes enough to line it up.
