GF16 In The PSL
Posted: Mon Jan 06, 2014 12:43 pm
by Noles309
Ok guys, Iv'e had the plans for 6+ months and the materials since the week before Christmas. It's my first build.
My major fault is I tend to over-think/analyze everything almost to the point I don't get anything done.
My first dilemma is whether to build this thing on the garage floor, a set of sawhorses or a table like CL did on his GF18 build. I can see the advantages of the table but is it really worth the extra expense of doing it?
Thanks and this will most likely be the 1st of 10000 questions.
Re: GF16 In The Pizzle
Posted: Mon Jan 06, 2014 1:16 pm
It's a matter of ergonomics: I am older than when I started boat building and my back hurts if I have to build seams and sand on the floor.
You will do a better job with the hull at a comfortable height.
You could assemble the hull on the floor and once it is stiff enough, raise it on pair of saw horses.
Posted: Mon Jan 06, 2014 4:59 pm
by Cracker Larry
I'm the same as Jacques, the older I get the more it hurts my back to bend over for long periods. Make it a comfortable working height. I would not build it directly on the floor unless it is a wood floor and you don't mind marking on it, cutting on it or shooting screws into it.
Here is a simple frame that I built a GF16 and a GF12 on.
Posted: Tue Jan 07, 2014 6:49 am
by Noles309
Thanks. I figure 4' wide and 12-14' long. The way the bow curves up it doesn't need to be the length of the boat does it?
Posted: Tue Jan 07, 2014 8:50 am
by pee wee
I think you will find that it does need to be a full length frame in the beginning- you need some way to hold the bow and stern transoms in accurate position as you assemble the hull.
Posted: Tue Jan 07, 2014 9:41 am
by Cracker Larry
What Peewee said. You will also be using the frame for laying out, marking, cutting and splicing the panels on, so it should really be full length.
Posted: Thu Jan 09, 2014 7:10 pm
by Noles309
OK Thanks. I will go ahead and build one. I'm not as young as I used to be either...
Should it be decked with plywood? I've seen them both ways.
My plan was to start today but it has rained all day and is still raining. Didn't want to deal with wet wood. Hopefully tomorrow.
Posted: Fri Jan 10, 2014 11:06 am
by Vanagod
What I did on my build was lay a bunch of 2x3 down on top of my saw horses for cutting the plywood on top of, then I put down sheets of [what my hardware store called] 1/4" melamine on top of those when it was time to glue and glass. It is basically 1/4" press board with a thin sheet of plastic or formica on top. The epoxy does not stick to the formica. That gave me a workbench the size of the boat to build it on that the epoxy doesn't stick to, and if I bugger up the to formica sheet too much, I can replace it for another $18.
Posted: Fri Jan 10, 2014 4:42 pm
by Noles309
Thanks, I just bit the bullet and got plywood.
Posted: Sat Jan 11, 2014 10:39 pm
by Noles309
I got the frame built today and now I'm ready to start making some progress. Unfortunately, it will probably be Tuesday before I actually get to work on it. I've never posted pics on this forum so I'll have to look into that as well.
Posted: Sun Jan 12, 2014 12:04 am
by Vanagod
Nice-looking stand. I would cover it with a tarp or some kind of sheet of plastic or like that quarter inch melamine I was talking about earlier to keep the epoxy from sticking to it because you're going to get a lot of epoxy on it over the build. And as for gilding the Lily, if you reinforce the legs a little bit you might be able to put casters on them and roll the boat around the garage to make accessing various corners easier too.
How long is your garage? It looks like your stand is almost as long as the garage itself like you have just a few feet behind the back of the stand and you'll have to have the garage door open in order to work on the boat. Please keep posting pictures this project. I'll be watching it. I'm thinking about making a GF 16 for my next build (or an FS 17 or a GF 18 or a CK 17; who knows, too many good plans to choose from.... Now how big is my garage?
Posted: Sun Jan 12, 2014 10:23 am
by Noles309
The garage is 20x20 and the frame is 16x4. I may need to move the compressor, table saw and welder off of the back wall but maybe not.
I will probably cover it with visqueen when the epoxy starts flying. A tarp is a good idea, I have some left over from the twin hurricanes we had in 04 that were covering our blown off roof.
I thought about casters still kind of up in the air on them. $$$ is adding up quick.
I hear ya on all the different possibilities here. I actually had a set of FS18 plans and a partial FG and plywood kit. I bought it from a guy on Microskiff. I ended up selling it because I wanted to start with something easier first, I didn't want to build it outside and SWMBO refuses to park her ride outside
. I would need the whole garage to build an 18 footer...
Posted: Mon Jan 13, 2014 11:11 am
by Vanagod
I'm using scrap tarp material on my work bench and other places. Cured epoxy comes off of tarp pretty easily.
Posted: Mon Jan 20, 2014 3:56 pm
by Noles309
I'm in the process of laying everything out. Do you cut out each frame then lay out the next or lay it all out and cut it at one time? I guess I'm really asking is if the width of the saw blade requires you to lay out and cut each panel individually? I ask because some of the seat frames touch each other on the nesting diagram.
Re: GF16 In The PSL
Posted: Tue Jan 21, 2014 12:03 pm
by Noles309
CL already answered in the powerboats section.
Re: GF16 In The PSL
Posted: Tue Jan 21, 2014 9:59 pm
by majorgator
Definitely add some casters...and get 3" or bigger. You're going to want to roll that thing outside for sanding, cutting, sanding, sanding, getting it out of the way, sanding, sanding, and sanding.
Re: GF16 In The PSL
Posted: Tue Jan 21, 2014 11:10 pm
by Matt Gent
I'm local, give a shout if you need a second set of hands during your build.
Re: GF16 In The PSL
Posted: Wed Jan 22, 2014 7:41 am
by Walkers Run
Matt Gent wrote:I'm local, give a shout if you need a second set of hands during your build.
X2
Re: GF16 In The PSL
Posted: Wed Jan 22, 2014 10:46 am
by Noles309
Thanks for the offer Matt and Walker. I may very well take you up on that.
Re: GF16 In The PSL
Posted: Thu Jan 23, 2014 4:54 pm
by Noles309
Nothing really exiting to report. I have most everything laid out. I hope to finish that and get everything cut tomorrow.
Feels good to finally be started.
Re: GF16 In The PSL
Posted: Sun Jan 26, 2014 11:58 am
by Noles309
Using the Cracker method of laying out the curves on the sides.
I'm resisting the urge to go full bore on this and trying to take it slow and steady. The frames, seat tops, deck, transoms, clamping boards and sides are cut.The next step is laying out and cutting the bottom panels.
Re: GF16 In The PSL
Posted: Mon Jan 27, 2014 9:48 pm
by Noles309
Re: GF16 In The PSL
Posted: Wed Jan 29, 2014 6:02 pm
by Noles309
Spliced one side of the side panels today amidst the crappy weather.
Re: GF16 In The PSL
Posted: Thu Jan 30, 2014 9:27 am
by tech_support
very fair lines
nice job
Re: GF16 In The PSL
Posted: Thu Jan 30, 2014 11:06 am
by Noles309
Thanks Joel.
Today I spliced the mid seat top together and did the other side of the side panels. I did allot better with the epoxy quantity today, pretty much got it right on the money.
Re: GF16 In The PSL
Posted: Thu Jan 30, 2014 11:26 am
by Cracker Larry
Splices look great! Not bad for a first timer
Re: GF16 In The PSL
Posted: Sat Feb 01, 2014 3:52 pm
by Noles309
Alright, I made a major screw up I'm afraid.
I cut the rear section on the side panels 2.5" too tall. I overlooked the rear dimension at the transom on the plans and cut the whole back of the boat at 1' 8 7/8" instead of the 1' 6 3/8". How can I fix it? I'm guessing the transom angle is off, the bow curve and maybe the bottom is now too short? I know I cant take it off of the sheer line. Can I cut it off the bottom and blend it into the bow curve? I'm thinking if i do that the transom angle will be wrong if that matters that much.
Do I start all over with new ply? Of course I didn't figure it out until I was putting it together and the transom was way too short.... I'm pissed in the PSL...
Re: GF16 In The PSL
Posted: Sun Feb 02, 2014 12:57 pm
by pee wee
Now is a good time to stop and review. My thinking is that the panels need to be like the plans show or it won't assemble properly. Lay the measurements out like you would before you cut and see what you have extra or are missing. Builders sometimes opt to change the sheer line, but your chine edge needs to be like the plans show or the side panels wont fit the bottom panels or the frames. Hopefully you won't need to buy new plywood, but don't do any more cutting until you have it all figured out. Lay out the proper lines on the panel and post pictures, if you have questions.
Re: GF16 In The PSL
Posted: Sun Feb 02, 2014 5:29 pm
by Noles309
Thanks peewee. I got it figured out after an hour or so of pondering today. I think i'm good to go. I have both sides clamped together and will cut it tomorrow.
Re: GF16 In The PSL
Posted: Mon Feb 03, 2014 9:30 am
by tech_support
If the cut is only offset a little high, then you should be able to re-draw the correct curve on the existing parts, then trim.
Re: GF16 In The PSL
Posted: Mon Feb 03, 2014 10:32 am
by Noles309
Thanks Joel.
It was just a rookie mistake on my part. I cut the bottom of the side panel straight from the first measurement where the curve starts instead of angling the cut from that point back to the rear transom. I overlooked the 2.5 inch shorter measurement on the plans difference at the rear transom. I was able to also correct the slight difference of the transom angle cut since I cut it too high. Live and learn
Re: GF16 In The PSL
Posted: Wed Feb 05, 2014 11:58 am
by Noles309
Is one 2 gal kit of foam enough flotation for this boat?
Re: GF16 In The PSL
Posted: Wed Feb 05, 2014 12:22 pm
by Cracker Larry
Real close, but you might want a little more. The 2 gal. kit under ideal conditions will provide 8 cubic feet and 480 pounds of buoyancy. The hull will be positive, floating itself plus a little bit. The fuel tank will float itself too. You need enough to support the weight of the engine, battery?, gear, anything that won't float, plus people, plus a little bit more, just for the heck of it
Re: GF16 In The PSL
Posted: Wed Feb 05, 2014 2:37 pm
by Noles309
So probably add a 2 quart kit to the 2 gal and that will be 720 lbs? I'm thinking of a 20HP 4 stroke or a 25hp 2 stroke for power.
Re: GF16 In The PSL
Posted: Tue Feb 11, 2014 2:27 pm
by Noles309
Looks like a boat finally
I have a question, as far as gluing in the frames the building notes say to glue with epoxy between the frames and side panels. Do you also put a fillet in at this time or do that later?
Re: GF16 In The PSL
Posted: Tue Feb 11, 2014 2:54 pm
I spot weld with little tabs of epoxy putty and build the complete fillets later when applying the tape.
That way I work wet on wet and avoid any sanding of the fillets.
Re: GF16 In The PSL
Posted: Tue Feb 11, 2014 3:03 pm
by Noles309
Thanks Jacques. Do you glue all the frames as well at this point or just the transoms?
Re: GF16 In The PSL
Posted: Tue Feb 11, 2014 5:09 pm
by Cracker Larry
Yes, tack glue them all in, then go back and fillet and tape one at a time after the tack welds cure.
Re: GF16 In The PSL
Posted: Tue Feb 11, 2014 5:17 pm
by Noles309
Thanks much Larry.
Couple of pics with the deck and seat tops set on. I'm feeling pretty good about it so far, way less problems than I anticipated.
Re: GF16 In The PSL
Posted: Tue Feb 11, 2014 8:15 pm
by keysrat
Looking good.
Couldn't but notice the nice pronghorn mount. Shame to relegate it to the garage
Go Noles!
Re: GF16 In The PSL
Posted: Tue Feb 11, 2014 8:41 pm
by Noles309
keysrat wrote:Looking good.
Go Noles!
Thanks.
Yeah, it is kind of degrading a bit. I had another and had to throw it out it was so bad. The taxidermist hosed me they were quite a few years old though.
Re: GF16 In The PSL
Posted: Tue Feb 18, 2014 11:05 am
by Noles309
Not much to report and nothing photo worthy. I got the frames tacked in and she is square, woohoo.
Up next is the rubrail.
Re: GF16 In The PSL
Posted: Wed Feb 19, 2014 11:00 am
by Noles309
I'm thinking of recessing a cooler into the center seat. Pros and cons?
Like so:
Primed the strips for the rubrail today.
Re: GF16 In The PSL
Posted: Thu Feb 20, 2014 4:03 pm
by smilinmatt
Instead of recessing a cooler in the middle seat, why not just make the middle seat a cooler? The entire middle seat would probably be around 200+ quarts, so you wouldn't need all of it (1/2 storage and 1/2 cooler?) I built a coffin box with 2 layers of 3/4" blue foam for my OB19, and it'll hold ice for a week in the summer. For mine, I used caulking to glue 2 layers 3/4" foam to the sides, door skin over that (1/8" ply), then filleted and taped corners and used 6 oz fabric over everything. It's held up great after 5 years.
Re: GF16 In The PSL
Posted: Thu Feb 20, 2014 8:13 pm
by Noles309
Good point Matt. So many options and variables. So many options to ponder. Thanks
Re: GF16 In The PSL
Posted: Fri Feb 21, 2014 5:20 pm
by Noles309
Re: GF16 In The PSL
Posted: Sat Feb 22, 2014 10:53 am
by Noles309
I have a question, when I was flipping the bottom panel this morning to tape the other side, the side that was done made a cracking sound and the panel partially folded. It did not separate. it is still intact and I just taped the other side. Should I grind the tape off of that side and redo, maybe put another layer over it or is it ok?
Re: GF16 In The PSL
Posted: Sat Feb 22, 2014 4:45 pm
by garym
Wish I had an answer for you but I don't know for sure.
You may get a faster answer in you repost in the Board index ‹ Plans and Building ‹ Power Boats section of the site.
No worries anything can be fixed.
Re: GF16 In The PSL
Posted: Sat Feb 22, 2014 5:18 pm
by Dougster
I'd grind it down and tape it again. Won't take long and you won't have to worry about it.
No worry Dougster
Re: GF16 In The PSL
Posted: Sat Feb 22, 2014 5:58 pm
by pee wee
try to get some glue mixture between the ends of the panels as well, that might help. It sounds like the fiberglass was bonded well but the ends of the panels let loose from each other.
Re: GF16 In The PSL
Posted: Sun Feb 23, 2014 6:06 am
by justin_dwyer
When I am flipping Largs panels, I always clamp a piece of timber across the joint, that way it can't flex at the joint. I also use this method to carry long panels to the boat, again it makes sure there is no stress on the joint.
This is particularly helpfull when you work on your own.
Hope this helps,
Cheers
Justin
Re: GF16 In The PSL
Posted: Sun Feb 23, 2014 11:11 am
by Noles309
Thanks for the tip Justin. Live and learn I guess. The joint looks ok I think. After the other side cured I flipped it back to look closer at it. I should have looked closer at it instead of taping the other side right away. I'm prolly going to take dougsters advice for piece of mind and grind it and re-tape. Thanks
Re: GF16 In The PSL
Posted: Sun Feb 23, 2014 11:17 am
by gk108
Yep. Now is the easiest time to fix it.
Re: GF16 In The PSL
Posted: Sun Feb 23, 2014 11:29 am
by Noles309
Re: GF16 In The PSL
Posted: Sun Feb 23, 2014 6:35 pm
by Noles309
Re: GF16 In The PSL
Posted: Tue Feb 25, 2014 8:19 pm
by Noles309
The decks and seat top are screwed down and got the rubrail on the port side. Need more clamps...
Re: GF16 In The PSL
Posted: Thu Feb 27, 2014 8:18 pm
by Noles309
Finished up the rubrail today. Tomorrow or Saturday I hope to flip it and tape and/or stitch on the bottom.
Re: GF16 In The PSL
Posted: Thu Feb 27, 2014 9:10 pm
by justin_dwyer
Looking great Gary, you are powering through
Cheers
Justin
Re: GF16 In The PSL
Posted: Fri Feb 28, 2014 1:55 pm
by Noles309
Re: GF16 In The PSL
Posted: Fri Feb 28, 2014 2:55 pm
If it's fair, fill the gap with putty: when you build the fillets, push the putty in there.
Re: GF16 In The PSL
Posted: Fri Feb 28, 2014 9:56 pm
by Noles309
Thanks Jacques. Thats a relief.
Re: GF16 In The PSL
Posted: Sat Mar 01, 2014 12:49 pm
by osotexan
Very cool Gary! Isn't it fun seeing a boat come together from your hands? As we are both first time builders I will be following your build closely.
Titelines,
Matt
Re: GF16 In The PSL
Posted: Sat Mar 01, 2014 4:06 pm
by Noles309
Hey Matt, Its probably the coolest thing Iv'e done. I've had a great time with it so far. I'm kicking myself for waiting as long as I did to take the leap.
Re: GF16 In The PSL
Posted: Tue Mar 04, 2014 8:48 am
by Noles309
Made a little progress last night. I laid the fillets in, taped and laid the cloth in the bow compartment, all wet on wet. No pic yet. Kind of a milestone with my first big chunk of glassing. It went ok I guess but took allot longer than I thought it would. I had one batch of resin cook off because I mixed it too soon, doh
. Live and learn.
Re: GF16 In The PSL
Posted: Tue Mar 04, 2014 3:37 pm
by Matt Gent
When you get into bigger tasks, it really helps to have a second person mixing for you. And I only use SLOW hardener for our climate. The thinner film you keep the better, if you have a dish like a plastic cookie sheet it will give more working time than a butter tub.
Re: GF16 In The PSL
Posted: Thu Mar 06, 2014 9:22 pm
by Noles309
Re: GF16 In The PSL
Posted: Fri Mar 07, 2014 8:17 am
by Gramps
Looking good Noles! I'm amazed at the cleanliness of your work. Keep it up.
Re: GF16 In The PSL
Posted: Fri Mar 07, 2014 12:35 pm
by osotexan
Looks very good and clean.
Build on
Matt
Re: GF16 In The PSL
Posted: Tue Mar 11, 2014 9:44 pm
by Noles309
Thanks for the kind words guys.
Well I flipped her, filleted the outside seams and gave the outside a coat of epoxy last night. This morning I rounded off the edges cut all my biax tape and laid out all the wide cloth. I was surprised there was enough cloth to cover the entire outside of the hull up to the rubrail and both transoms.
I bought the FG kit and the plans only call for 6" up the side. I still have enough to probably do the inside hull sides. I don't know if e-boat mismeasured or if thats normal. Anyway, I started going to town, got all the tape done, laid out the starboard half of the bottom and side, wetted all that out and then looked at my epoxy stash. There may have been enough to finish it or maybe not it was that close. I didn't want to start and not be able to finish (if that even matters?) So I ordered a 1 1/2 gallon kit from e-boat and I hope to pick it up tomorrow morning. I will still be in the wet on wet window of 24 hrs to hopefully finish it off tomorrow. Glassing the hull sides made it too close to call with the epoxy. In hindsight I guess I should have just used what I had and I could have finished it up tomorrow and still been in the wet on wet window. Oh well I am a rookie. Heres some pics:
Primed and ready.
Look at all this cloth.
Taped
A little more than half done.
Re: GF16 In The PSL
Posted: Wed Mar 12, 2014 9:16 am
Nice fiberglass job.
Re: GF16 In The PSL
Posted: Wed Mar 12, 2014 4:15 pm
by Noles309
Re: GF16 In The PSL
Posted: Fri Mar 14, 2014 9:21 am
by tcason
wow that looks great!
sand on............
Re: GF16 In The PSL
Posted: Fri Mar 14, 2014 9:38 am
by tech_support
Very Clean, nice work
The epoxy will certainly wet out better when its warm. If its much lower than 60 degrees, i like to warm it up first (especially if wetting out somethign thick)
Re: GF16 In The PSL
Posted: Fri Mar 14, 2014 3:29 pm
by Walkers Run
looking great Noles! You'll be ready for lobster season at this pace.
Re: GF16 In The PSL
Posted: Fri Mar 14, 2014 8:52 pm
by Noles309
Walkers Run wrote:looking great Noles! You'll be ready for lobster season at this pace.
Thats an achievable goal I think Walker. Hope I'm done before that but we'll see.
I did make some progress today, sanded her down outside. Tomorrow I hope to get the runners and spray rails glued down. I have a couple of bubbles in the wide cloth, one on the corner of the transom and one on the corner of the bow transom. Nothing big though. I'm really happy with how it came out. Not bad for a first timer I think.
Thanks guys.
Re: GF16 In The PSL
Posted: Fri Mar 14, 2014 9:35 pm
by Cracker Larry
Not bad at all for a first timer
Looks good. You are moving along fast, wish we could get some of that FL weather up here in GA.
Re: GF16 In The PSL
Posted: Fri Mar 14, 2014 11:26 pm
by Hope2float
Looks good ,your moving along.
Dave
Re: GF16 In The PSL
Posted: Sat Mar 15, 2014 8:49 am
by Noles309
Thanks Dave, your build is just off the chart in its level of fit and finish and Larry I'm on your thread daily especially when I'm ready to go to the next stage. This morning Its how you did your runners on the GF18.
As far as the weather, Its been a crazy winter for sure. We have run the a/c way more than usual this time of year. My son is up at Ft. Stewart and they have been in the field all week. Its been a pretty miserable winter up there for sure.
Thanks again guys.
Re: GF16 In The PSL
Posted: Sat Mar 15, 2014 6:00 pm
by osotexan
That looks awesome Gary!
I know what you mean about this winter. We've had several 50 degree temperature swing in less than 12 hours this year. Two weeks ago I had two heaters running in the garage and today it's a sweat shop. I hope sweat drops on wet epoxy does affect how it cures
Titelines,
Matt
Re: GF16 In The PSL
Posted: Sat Mar 15, 2014 9:56 pm
by Noles309
Thanks Matt.
Today I got the runners glued on. I still need to do a little shaping on them. I hit them with a 1/2 roundover bit with the router. I am going to glass over them, hopefully tomorrow.
Re: GF16 In The PSL
Posted: Sat Mar 15, 2014 10:13 pm
by osotexan
Build on Gary! You are making me feel lazy
I'm almost finished tabbing the inside of mine...
Re: GF16 In The PSL
Posted: Mon Mar 17, 2014 10:19 am
by Noles309
No you're not lazy, I'm just semi retired and have plenty of time.
Glassed the runners yesterday
Re: GF16 In The PSL
Posted: Mon Mar 17, 2014 3:23 pm
by Noles309
Re: GF16 In The PSL
Posted: Mon Mar 17, 2014 10:25 pm
by Aripeka Angler
Very nice and clean glass work
Fast too, you are making great progress. The GF's are fine boats, you made an excellent choice for a build.
Re: GF16 In The PSL
Posted: Thu Mar 20, 2014 4:06 pm
by Noles309
Thank you.
Well I got the bright idea to lay a level on the hull. I was pretty exicted I laid it down in the center of the hull and she was flat as can be. I moved it back to the transom and I have almost a 1/4" gap at the transom, rocker I guess? I got an 8' piece of my garage door hurricane brace and laid it on there and it looks like it starts at the rear seat frame.
How big of a deal is this? I'm assuming its supposed to be flat all the way to the transom. What are my options?
Re: GF16 In The PSL
Posted: Thu Mar 20, 2014 6:56 pm
by Irish
Just about everyone who has built the GF 14-16 has had this problem to some degree. Yours does not appear that bad. If you attach a hydrofoil to your outboard it should eliminate any porpoising that it may cause. These boats will need a hydrofoil for optimal performance anyway. ( others may think different, ask Cracker Larry he has built a few GF's)
Re: GF16 In The PSL
Posted: Thu Mar 20, 2014 7:52 pm
by Noles309
Thanks Irish, I guess I didn't do enough research on it. The building notes don't mention it either. Searching now its been quite a while since it was mentioned on the forum.
This is going to bug the crap out of me. Do I try to build it up with glass? Is it too much to build up with filler? The runners are already on and glassed. Do they have to come off or can I build it up around them?
I had the bow supported when I put it together and I only used 4 stitches in the boat and they were at the front in the curve.
Re: GF16 In The PSL
Posted: Fri Mar 21, 2014 8:19 am
by Cracker Larry
That's not enough to worry about, it'll be OK.
Re: GF16 In The PSL
Posted: Fri Mar 21, 2014 8:47 am
It's designed that way: with 1/2" "rocker".
Some of that 1/2" will be filled with fairing putty but a little rocker will be left. Many designers include a tiny little bit of rocker there.
Re: GF16 In The PSL
Posted: Fri Mar 21, 2014 11:31 am
by Noles309
Whew....that's a relief. For the life of me I couldn't figure out what I did wrong. I went back and read several old threads where it was stated that the bottom should be flat for the last 6-8' so I was pretty worried about it. Thanks for the response fellas.
Re: GF16 In The PSL
Posted: Fri Mar 21, 2014 12:16 pm
by Cracker Larry
The last 3 or 4 feet are what's most important, that's what will be in the water when planing. !/4" of rocker in 8' is insignificant.
Re: GF16 In The PSL
Posted: Mon Mar 24, 2014 9:23 am
by Noles309
Thanks CL. My concern was its all in the last 20" of the bottom.
Re: GF16 In The PSL
Posted: Mon Mar 24, 2014 8:17 pm
by cedarock
I pop in from time to time to see how my fellow boat building friends are doing and tend to follow boat building threads about boats that I am familiar with a little more often. When I saw this thread about the rocker, I sent Gary a PM about my experience with my gf14. I advised not to let the rocker go and thought about it and think that it should be shared for everyone to ponder and to help Gary and future builders come to the right conclusion.
I checked the bottom of my boat once while building and thought that it was flat from the mid seat back, which is what I had read in threads dating way back on the gfs. I launched with an old mariner 15 and was quite happy. It would push the boat 23-24 mph by myself and would plane okay with my wife and small dogs. Later, My brother and I took it out to the flounder hole and he weighs a touch more than Maggie!
The boat really struggled to get on plane with that extra weight up front. I also noticed that the bow was riding higher than I thought it should and it would porpoise really bad by myself. I was okay for a while but about six months went by and I started to question what was going on. I then checked the bottom closely and found pretty much the exact rocker as is in this thread. Last 20 inches or so had 1/4 inch of rocker. My thoughts were that the boat was trying to run on that 20 inches. By adding weight, the motor struggled to lift the bow to run on that planning surface. Thinking about how to correct my mistake...... I decided to turn it over and take out the rocker. Luckily, I used graphite on the bottom and up the sides a bit. I taped the paint and sanded the graphite down some. I glued a 1/4 piece of ply to take half of the rocker out, cutting around the runners. I shaped it down with a grinder to about 1/8 inch thick toward the bow and used biaxal strips at varied widths to build up and take out the rest of the 10" or so of the rocker. I covered the ply and the biaxal strips with a full piece of biaxal. And then one more piece to cover the entire patch and around the sides a little. Then a new fillet along the runners and taped them again to tie it all together. Faired and rolled some graphite on it all.
I noticed a difference right away. The boat would run with a lower bow at 27 mph by myself with the same motor. No problem planing with two and porpoising was all but gone while running solo. I don't know if my repair was the best way but it has worked well for a couple of years and if it fails (don't think it will), a gf16 will be in the future with no rocker in the last 20 inches. I am sure that more horsepower would have overcome my situation and I thought about getting a 25 before the repair. I did replace the mariner with a four stoke 15, due to dependability of the mariner, and it performs the same with the heavier motor. Does any of this make sense or am I just obsessive about getting the best performance possible!
Re: GF16 In The PSL
Posted: Mon Mar 24, 2014 10:05 pm
by Cracker Larry
It makes sense to me
Re: GF16 In The PSL
Posted: Thu Mar 27, 2014 12:04 pm
by Noles309
Thanks Cedarock for taking the time to address this issue.
I'm a little perplexed about the lack of comments on this as well as some contradiction of advice given in past threads. Those threads were all consistent in that the recommendation was to fix the rocker. The GF boats should be flat from the mid-seat to the transom...Now, it was designed into the boat and the same amount of rocker as outlined in past threads is ok.
Re: GF16 In The PSL
Posted: Fri Mar 28, 2014 10:29 pm
by Noles309
Crickets... Not surprised
I'm fixing it btw pretty much like cedarock did. Iv'e read too many articles and threads on forums about mediocre performance and porpoising with rocker to leave it.
Re: GF16 In The PSL
Posted: Sat Mar 29, 2014 10:31 am
by Cracker Larry
You have OCD like I do
I really don't think 1/4" will make any difference, but if it worried me I would certainly fix it so I could sleep at night. It will be quick and easy to build it up flat.
Re: GF16 In The PSL
Posted: Sat Mar 29, 2014 10:55 am
by Noles309
Cracker Larry wrote:You have OCD like I do
You got the OCD part right for sure.
I would just hate myself if I didn't fix it and then wasn't happy with the performance of the boat. I've strewed about it for a week now. Its a small setback I guess in the overall process.
Re: GF16 In The PSL
Posted: Sat Mar 29, 2014 11:31 am
by Cracker Larry
You could have fixed it in less time than you've been stewing
Make her flat and get some sleep.
Re: GF16 In The PSL
Posted: Tue Apr 01, 2014 9:48 pm
by Noles309
Re: GF16 In The PSL
Posted: Tue Apr 01, 2014 10:44 pm
by justin_dwyer
Nice work Gary, that looks like a neat fix-it job.
Re: GF16 In The PSL
Posted: Wed Apr 02, 2014 10:34 am
by Noles309
Thanks Justin. Good work on yours as well. I didn't have the cojones to start with something that big. This one is my learning boat for the flats. If it turns out good I may try a bigger one for offshore
Re: GF16 In The PSL
Posted: Wed Apr 02, 2014 1:39 pm
by Cracker Larry
Nice fix. Did you sleep better last night
Re: GF16 In The PSL
Posted: Wed Apr 02, 2014 4:34 pm
by Noles309
Cracker Larry wrote:Nice fix. Did you sleep better last night
You know it.
Time to fair now, a new adventure.
Re: GF16 In The PSL
Posted: Wed Apr 02, 2014 6:01 pm
by cedarock
Wow..that looks great Gary! You will enjoy the gf.
Re: GF16 In The PSL
Posted: Wed Apr 02, 2014 7:14 pm
by justin_dwyer
Gary, this was my first attempt, really rough, but it floated and gave my wife and I something to muck around in the river with
I was so new to boat building that I didn't even fibreglass the bottom
(as I found this website after I built that).
Learnt a lot since then, but I still have a lot to learn, and this big boat is sorting me out for sure. Good fun though, and this forum is super helpfull.
We have a 5m aluminium boat for fishing, but it is an open side console and I got sick of getting wet when we go offshore, so I decided to build a boat with a cab, I wanted to to build the p21, but it is just too tall to get under my house to the garage out the back, with a modified trailer I can get the P19 under....well I hope I did my sums right, otherwise I'll have to turn it into a spa out the back or something
Keep up the great work Gary, you are making super progress.
Cheers
Justin.
Re: GF16 In The PSL
Posted: Wed Apr 02, 2014 9:39 pm
by Noles309
Thats a cool little boat. You can always air down the tires some if you were off by a little.
Re: GF16 In The PSL
Posted: Wed Apr 02, 2014 9:45 pm
by justin_dwyer
If I am off a bit, I have considered making a removable cab roof..in which case I should have built the P21
Boat building is certainly an addiction. It is all I think about during the day, makes it hard to get anything done here at work
Re: GF16 In The PSL
Posted: Wed Apr 02, 2014 9:59 pm
by Cracker Larry
It is a hard mistress. Be careful, soon you will just quit work and build boats like I did. Of course it is still work, but beats doing most things
Re: GF16 In The PSL
Posted: Wed Apr 02, 2014 10:02 pm
by justin_dwyer
Yep, If I had a choice as to what to fill my day with, I would be out the back building boats for sure
You've done well Cracker!!
Re: GF16 In The PSL
Posted: Thu Apr 03, 2014 10:54 am
by Noles309
Hmm, interesting thought. I can't say I haven't thought about it, need more practice though.
I did retire from one job after 27 1/2 years, but it seems the job market for 50 somethings is not good at all.
Re: GF16 In The PSL
Posted: Fri Apr 04, 2014 4:45 pm
by Noles309
Fairing has begun.
Re: GF16 In The PSL
Posted: Fri Apr 04, 2014 9:26 pm
by justin_dwyer
Gee, no mucking around, you're straight into it!
Nice work Gary!
Re: GF16 In The PSL
Posted: Sat Apr 05, 2014 1:30 am
by willg
You have made huge progress. I went back to page one of your thread and am really amazed at how much you've done in 2 months. Your boat looks great!
Re: GF16 In The PSL
Posted: Sat Apr 05, 2014 9:27 pm
by Noles309
Thanks will.
I started sanding today. My finish expectations are dropping I'm afraid, might be a workboat after all, flat paint and all. I'll keep plugging away at it. Hopefully I'll figure it out and it will turn out ok.
Re: GF16 In The PSL
Posted: Sun Apr 06, 2014 10:25 am
by gk108
Just be patient. What you've done so far looks great.
Re: GF16 In The PSL
Posted: Sun Apr 06, 2014 6:28 pm
by Noles309
gk108 wrote:I'll keep plugging away at it. Hopefully I'll figure it out and it will turn out ok.
Thanks for the vote of confidence
Re: GF16 In The PSL
Posted: Mon Apr 07, 2014 11:15 am
by Stuff
Gary
One tool that help me a lot was a DA sander. First level everything with the long board then use the DA to smooth the surface. Also don't confuse the DA sander with an palm orbital sander. They work the same way but the DA is more powerful.
Re: GF16 In The PSL
Posted: Mon Apr 07, 2014 11:25 am
by Noles309
Thanks stuff. I have an airhog of a DA that wants to kill my compressor. I also have an RO.
Re: GF16 In The PSL
Posted: Mon Apr 07, 2014 1:58 pm
by Stuff
I got an electronic DA from Harbor Freight. It might die by the end of my build but it's doing a great job so far. I think i cost me less than $60. Also you be surprised of how much the high build up primer can cover so don't worry if is not perfect. I guarantee you that it will come out better than you expected.
Re: GF16 In The PSL
Posted: Mon Apr 07, 2014 2:25 pm
by peter-curacao
Noles309 wrote:Thanks will.
Don't worry about it, at one point I thought the same thing, but then the next day is a fresh new day to start over with sanding, filling etc. all those days of doubt still makes a nice finished product, what I wanna say is, although at times it seems like a day wasted it still is progress
Hope you understand what I'm trying to say.
Re: GF16 In The PSL
Posted: Mon Apr 07, 2014 5:42 pm
by Noles309
Thanks Stuff and Peter for the encouragement. I guess it will be fine. I have done paint and body on cars but that is way easier than this. I was disappointed for sure in how the 1st round came out. I'll plug away at it. Gonna need more blended filler though.
Re: GF16 In The PSL
Posted: Mon Apr 07, 2014 6:16 pm
by Cracker Larry
What you've done so far looks great. Not too much, not too little. Do it 2 or 3 more times and it will be perfect. If you are ordering blended filler, I'd also get a small kit of Quick Fair for the final round. I start with 2 or 3 rounds with blended filler and finish up with a couple more of QF.
Re: GF16 In The PSL
Posted: Mon Apr 07, 2014 7:54 pm
by Noles309
Cracker Larry wrote:What you've done so far looks great. Not too much, not too little. Do it 2 or 3 more times and it will be perfect. If you are ordering blended filler, I'd also get a small kit of Quick Fair for the final round. I start with 2 or 3 rounds with blended filler and finish up with a couple more of QF.
I have a 3 quart kit of Quick Fair but I didn't have enough blended filler to go two rounds, one round and about 3/4 of the bottom on round 2. I got some silica for squaring off the chines and transom, they gave me the monster bag of silica. I could blend my own if I knew the ratio. Any guidance? Is the 3 Qt kit of quick fair enough for this boat?
Thanks, I have sure used your current build as a guide.
Some pics, I had already started the second application on the bottom when I took these. Feel free to critique.
Re: GF16 In The PSL
Posted: Mon Apr 07, 2014 8:05 pm
by Cracker Larry
A 3 qt. kit of QF will be plenty. The ratio is roughly 20% silica to the MBs. It's not critical. The purpose of the silica in the mix is mostly for anti-sagging.
One more piece of advice I can give is that you'll never regret spending an extra week on it. Fill it and sand it a few times until you can't stand it anymore, then rest up a few days and go back fresh and do it one more time
Re: GF16 In The PSL
Posted: Thu Apr 17, 2014 7:33 am
by Noles309
I found a really good deal on a trailer on craiglist. The length is good and its a little wide at 64" between the fenders. My concern is the weight rating might be too high for this boat. It was for a 17' Boston whaler which has a weight, less engine, of 1400 lbs. I know the GF16 is nowhere close to that. The owner doesn't know the weight rating of the trailer and it is about an hour from me. Any thoughts?
Re: GF16 In The PSL
by Noles309
Re: GF16 In The PSL
Posted: Thu Apr 17, 2014 7:44 am
by Stuff
Well if you don't want it I might be able to buy it from you. I need one for my sailboat.
Re: GF16 In The PSL
Posted: Thu Apr 17, 2014 7:47 am
by Cracker Larry
The trailer should have a sticker with it's load rating on it. You could always remove a leaf spring to soften it up a little.
Re: GF16 In The PSL
Posted: Thu Apr 17, 2014 9:21 am
by Stuff
It should be OK but a little bumpy. Cracker Larry that is a great idea.
Re: GF16 In The PSL
Posted: Thu Apr 17, 2014 9:41 am
by Noles309
Thanks guys.
2400 lbs....still doable you think?
Re: GF16 In The PSL
Posted: Thu Apr 17, 2014 10:30 am
by Stuff
With the cooler, fishing gear, the outboard, and everything else you should be around 60% of the rated weight. Maybe a little bumpy but not to bad. I think is a good trailer for your boat
Re: GF16 In The PSL
Posted: Thu Apr 17, 2014 4:59 pm
by Noles309
Double Craiglist score. Went to look at trailer and the guy had a 2011 Nissan 20 HP 4s electric start. He says only 7 hrs on it and it looks it to me. Its real clean under the cowl. 2 years of warranty left. Wooo friggin Hooo
I feel kinda like I stole them but he was a grown man...
Motor has sat in a shed for almost 2 years and needs a carb rebuild. Its a tiller but he converted it to remote. I will be converting it back to a tiller. I have all the parts but an ignition switch and kill switch. The trailer is clean as a whistle to. I'm stoked.
Now I need to get off my but and resume fairing.
Re: GF16 In The PSL
Posted: Thu Apr 17, 2014 6:17 pm
by Cracker Larry
Nice trailer and motor
I would take one leaf out of the trailer springs. The design weight of that hull is only 165 lbs. You and I aren't likely to achieve that
but it shouldn't be over about 225. That engine is what, about 120 lbs, 6 gallons of fuel plus tank less than 50, beer and gear and ice maybe another 100. I'd guess 500-600 pounds top loaded down weight without people.
Re: GF16 In The PSL
Posted: Thu Apr 17, 2014 7:59 pm
by Noles309
Cracker Larry wrote:Nice trailer and motor
I was wondering about that. It has 3 leaves so take out the short one on the bottom of the leaf pack?
Surprisingly it didn't pull all that bad empty on the way home.
Re: GF16 In The PSL
Posted: Tue Apr 29, 2014 5:26 pm
by Noles309
Fairing, fairing, fairing....
Its coming along slowly and looking better, been sick and had my truck wrecked for me. It hasn't been a great couple of weeks. I'm switching to quickfair to finish it up. I hope to get primer on it next week. We'll see.
Re: GF16 In The PSL
Posted: Tue Apr 29, 2014 8:09 pm
by jorgepease
Fairing broke me, I actually started throwing tools around the room LOL!
Re: GF16 In The PSL
Posted: Tue Apr 29, 2014 8:51 pm
by Cracker Larry
That's when it's time to walk away, make a drink, roll a joint, practice yoga, go fishing, or whatever it is you do to find peace. Sometimes I pull out the firearms and blow holes in paper. Let it rest for a few days. Then come back fresh. You'll be happier with the results in the end. Never work when you reach that point of frustration or you will just have to do it over again tomorrow.
Re: GF16 In The PSL
Posted: Tue Apr 29, 2014 9:13 pm
by mattken85
Something must be wrong with me, fairing hasn't bothered me much and has been one of the easier things to do on my GF16. Now fixing my first build rookie mistakes that I made early on pushed my buttons a little. Looking forward to seeing your progress on this build.
Re: GF16 In The PSL
Posted: Wed Apr 30, 2014 8:11 am
by jorgepease
I think I am just plain bad at fairing and I should have definitely walked away and gone for a dip the ocean )
Re: GF16 In The PSL
Posted: Wed Apr 30, 2014 8:31 am
by Noles309
mattken85 wrote:Something must be wrong with me, fairing hasn't bothered me much and has been one of the easier things to do on my GF16. Now fixing my first build rookie mistakes that I made early on pushed my buttons a little. Looking forward to seeing your progress on this build.
Thanks, you should start a build thread. Different strokes I guess. I don't enjoy it at all but I think I may be getting the hang of it finally. Have to sand today and see how it looks.
Re: GF16 In The PSL
Posted: Wed Apr 30, 2014 8:34 am
by Noles309
jorgepease wrote:I think I am just plain bad at fairing and I should have definitely walked away and gone for a dip the ocean )
You and me both brother....I will be glad when April is over, the house A/C took a dump this morning and its supposed to be in the 90's today of course. It has been a bad month
Re: GF16 In The PSL
Posted: Wed Apr 30, 2014 10:38 am
by mattken85
I should have started a build thread, a while ago. It is a little late now but I'll have something for everyone when I am finished. Should be soon.
Re: GF16 In The PSL
Posted: Wed Apr 30, 2014 11:38 am
by peter-curacao
mattken85 wrote:I should have started a build thread, a while ago. It is a little late now but I'll have something for everyone when I am finished. Should be soon.
Never to late to start one, i.o.w. never to late for some BOAT PORN!
Re: GF16 In The PSL
Posted: Mon May 05, 2014 10:50 am
by Noles309
Re: GF16 In The PSL
Posted: Tue May 06, 2014 10:33 am
by Noles309
I got the edges squared up. I think I used too mix much though
. I started with a block plane and a sureform but it was just too slow and I broke out the grinder. Amazingly, I managed to not do any damage with it, just made a gigantic mess
I sharpened 6 1/2' of chine edge. That should be good for this boat?
I also mixed up a batch of Quick Fair to try it out. It seemed much easier to apply than the blended filler. We will see about the sanding a little later...
Re: GF16 In The PSL
Posted: Tue May 06, 2014 4:41 pm
by Noles309
Well, I must have screwed up a batch of Quickfair. I know my measurements were right 7:3 by weight, according to the mixing Quickfair video. I guess it wasn't mixed good, hard to tell because it doesn't change color or anything. Some places are still tacky some 21 hrs after I put it on. I guess I have to sand it off or will it continue to slowly harden? Wishful thinking I know
This fairing crap is going to kill me yet. I'm over it. Seriously thinking about flat paint or truck bed liner and calling it a lesson learned... They enjoyment factor of building a boat is long gone
Though that monstaliner stuff is allot more expensive than flat auto paint.
Re: GF16 In The PSL
Posted: Tue May 06, 2014 5:06 pm
by garym
My recollection is that the larger container is a brownish color and the smaller container is white.
When you first mix it it looks like a chocolate vanilla swirl that you would get at the ice cream shop.
When fully mixed its a uniform light cream color. Don't give up on it to fast. Its great stuff.
It should kick over fairly quickly within its usable temp range.
Re: GF16 In The PSL
Posted: Tue May 06, 2014 9:52 pm
by Cracker Larry
Correct, 1 is brown, one is white. 2 parts brown to one part white. I've never bothered to weigh it, I just eyeball 2/1 on mixing sticks on a piece of cardboard. Stir until cream. Never had a batch fail yet. In warm weather it cures to sanding in 4-6 hours.
Re: GF16 In The PSL
Posted: Tue May 06, 2014 10:04 pm
by Noles309
Mine is tan and white. There is no appreciable difference in color when mixed or I'm earth tone colorblind, maybe just a shade lighter idk. I made double sure it was mixed good and cut the batch in half today.
Going to OK for 4 days to see my middle son graduate from Army Basic. If its still tacky when I get back I'll sand the crap off and start over. Luckily it was only one batch, but it was a 10oz one....
Re: GF16 In The PSL
Posted: Wed May 07, 2014 8:11 pm
by jorgepease
Just keep going, it definitely sucks the joy out of boat building but it all comes back on the next steps!
Re: GF16 In The PSL
Posted: Mon May 12, 2014 11:09 am
by Noles309
jorgepease wrote:Just keep going, it definitely sucks the joy out of boat building but it all comes back on the next steps!
I hope so. I'm back and ready to get to work. It sucks having borderline OCD and ADD combined
How is yours coming? Isn't it about time for an update?
Re: GF16 In The PSL
Posted: Mon May 12, 2014 12:31 pm
by garym
Have you seen the electric fairing board.
http://forums.bateau2.com/viewtopic.php ... rd#p310186
Its a couple of posts down.
Re: GF16 In The PSL
Posted: Sat May 17, 2014 10:09 pm
by Noles309
That is pretty cool. I'm about done though whether its perfect or not. Iv'e decided I have one more small round left in me and thats it. I'm thinking of painting it camo (Mossy Oak Shadow Grass) and calling it good.
https://styx-river.com/products/?catego ... =3#product
I also made the mistake of not going to Vero to get more Quick Fair. I went to a local FG shop and picked up some Awlfair. It takes forever to dry (24 hrs to sand) and when it is dry it really loads up the sandpaper. I don't recommend it.
Re: GF16 In The PSL
Posted: Tue May 20, 2014 9:31 pm
by Noles309
She's in primer finally, whew
Two coats and it looks pretty good, I can still see some of the pink Awlfair though through 2 coats
Definitely looks better all one color. Not surprising, I found some places I need to fair a little more, mostly around the transitions with all of the extra glass I put on it to take out the rocker. Ordering Quickfair now, no more pink crap. Pics tomorrow the flash pics are no bueno...
Re: GF16 In The PSL
Posted: Wed May 21, 2014 4:31 pm
by Noles309
Re: GF16 In The PSL
Posted: Wed May 21, 2014 4:45 pm
by Cracker Larry
That looks mighty fine! The primer always shows you what you missed with fairing. Good thing about the S3 primer is you can fair right over it to fix the little spots
Re: GF16 In The PSL
Posted: Wed May 21, 2014 6:28 pm
by Walkers Run
Looking good! I love this phase. Wax on wax off
Re: GF16 In The PSL
Posted: Wed May 21, 2014 7:18 pm
by garym
Looks like a boat. Nice.
Re: GF16 In The PSL
Posted: Thu May 22, 2014 10:46 am
by Noles309
Thanks guys
, I'm heading up to e-boat now to pick up some supplies, mainly Quickfair, so I can finish it and flip it. I'm going with Gator Glide G4 on the bottom. I hope to have it on and the boat flipped by mid week. We'll see.
Re: GF16 In The PSL
Posted: Thu May 22, 2014 12:10 pm
by Aripeka Angler
You sure you haven't done this before?
Very nice work
Re: GF16 In The PSL
Posted: Tue May 27, 2014 11:15 am
by Noles309
Re: GF16 In The PSL
Posted: Tue May 27, 2014 2:25 pm
by willg
That's cool. Congrats on the nice looking work, too.
Re: GF16 In The PSL
Posted: Wed May 28, 2014 10:59 am
by Noles309
Thanks Will, I noticed you painted yours before flipping it. I'm wrestling with that now. I can't really decide, are you happy with your decision?
Re: GF16 In The PSL
Posted: Wed May 28, 2014 11:36 am
That is so clean!
You are close, when the boat is finished, you can keep it at my dock, I will not use too much
Re: GF16 In The PSL
Posted: Wed May 28, 2014 10:33 pm
by willg
Noles309 wrote:... are you happy with your decision?
Definitely. With the hull upside down I had good lighting and I think better access to the whole thing.
Re: GF16 In The PSL
Posted: Thu May 29, 2014 12:45 pm
by Noles309
Yeah, I'm still not completely sure what I want to do about paint so I flipped her today. Her guts haven't seen daylight since I don't know when.
I'm going to have to strap her down though. If you bump it she's sliding off of the table. That gator glide is no joke.
My son and I set her in the grass to flip it and you could spin it with one hand.
I have a question about glassing the rubrails. Do ya'll usually do it? I'm not sure if I want to round over the edges or not. I was planning on glassing the inside with 6oz but I don't think that will cover a sharp edge either without bubbling will it? I don't plan on putting a aftermarket rubrail on it. I do plan on coating it with bedliner though. Thanks
Re: GF16 In The PSL
Posted: Thu May 29, 2014 1:11 pm
by garym
I rounded over the outer and inner rail edge and the glassed over the rail only. I'm not sure if I should have glassed over the rail and then down a couple of inches on the hull side. I think it would have required a large fillet on the underside of the rail which is challenging when your boat is right side up.
Just what I did, definitely get some other opinions.
Re: GF16 In The PSL
Posted: Thu May 29, 2014 1:50 pm
by Noles309
garym wrote:I rounded over the outer and inner rail edge and the glassed over the rail only. I'm not sure if I should have glassed over the rail and then down a couple of inches on the hull side. I think it would have required a large fillet on the underside of the rail which is challenging when your boat is right side up.
Thats what I was thinking about stopping at the bottom edge. I glassed up to the bottom of the rail with biax. Thanks
Re: GF16 In The PSL
Posted: Thu May 29, 2014 2:00 pm
by garym
I used 12oz biax tape to cover the rail. I rounded over the rail with a 3/8 router bit.
The glass will provide MINIMAL protection. When I trailered the boat to get the engine the white pvc trailer guides were touching the rub rail. The bouncing around on the trailer chaffed away the paint and the glass on the rail. A little epoxy and quick fair and all was well.
Re: GF16 In The PSL
Posted: Thu May 29, 2014 2:13 pm
by jorgepease
This is looking great!!!
Re: GF16 In The PSL
Posted: Thu May 29, 2014 9:49 pm
by Noles309
garym wrote:I used 12oz biax tape to cover the rail. I rounded over the rail with a 3/8 router bit.
May not even be worth it then. I might seal it up good with epoxy, prime it and roll the bed liner on it.
Thanks Jorge.
Re: GF16 In The PSL
Posted: Fri May 30, 2014 8:05 am
by garym
Get a 2nd opinion before you do anything.
Re: GF16 In The PSL
Posted: Fri May 30, 2014 8:55 am
by Noles309
Yeah, the plans don't call for it so I guess it would be ok with Jacques.
Got allot of other stuff to do before I have to make a decision on that though
Re: GF16 In The PSL
Posted: Fri May 30, 2014 9:42 am
Many GF16 owners like a spray rail. No problem to install one but I would not fiberglass it. Epoxy coating is enough.
Re: GF16 In The PSL
Posted: Fri May 30, 2014 1:52 pm
by PastorBob
My spay rail was just glued on... No problems with it after a few years use.. I would definitely put it on again it helps keep the boat dry... Enjoying watching the build.
Re: GF16 In The PSL
Posted: Fri May 30, 2014 2:07 pm
by garym
Gary,
Did you mean the rub rail attached to the shear or the spray/rub rail in the middle of the side?
If its the top rail at the shear then the answer may be different
Re: GF16 In The PSL
Posted: Fri May 30, 2014 3:14 pm
by Noles309
Rub rail at the shear.
Re: GF16 In The PSL
Posted: Sun Jun 01, 2014 8:01 am
by topwater
I rounded over the top edge and when i glassed the deck with 10 oz i ran the glass over the rail to the bottom edge.
Decks and rub rail will be Monstaliner. If the rail gets beat up just scuff with scotch bright pad and touch up.
Re: GF16 In The PSL
Posted: Sun Jun 01, 2014 12:02 pm
by Noles309
Thanks Top, I'm using the Monstaliner as well. I was just thinking it didn't really need to be glassed if using that as a coating since its thick and very abrasion resistant and the plans don't call for it either. I need to keep focused on the fact that this is a jon boat and was practice for something bigger down the road.
Re: GF16 In The PSL
Posted: Mon Jun 09, 2014 4:19 pm
by Noles309
Been plugging away nothing picture worthy. The rub rail is rounded over and smooth. Got the backing plates done for the bow and transom eyes. I've been working on a PVC wire and fuel line chase to the bow and for the drain holes that will be covered with foam.
Re: GF16 In The PSL
Posted: Fri Jun 13, 2014 9:55 am
by Noles309
I was looking at my manual for my 20hp Nissan/Hatsu 4s tiller it recommends a 70AH, 800 Marine Cranking Amps/650 Cold Cranking Amps battery. This sounds excessive for such a small motor and I see allot of guys on the web running the small AGM's like the Odyssey's that don't come anywhere close to these numbers.
Do they do ok? I will be using it for starting, lights and light electronics only. I'm looking to go small and light if I can.
Iv'e read of guys using this bad boy, 11 lbs and 7"x3"x5"
http://www.amazon.com/Odyssey-PC545-Pow ... R0MM98HG9S
Re: GF16 In The PSL
Posted: Sun Jun 15, 2014 1:50 pm
by Geir
Think your small battery is going to work just fine. It should deliver enough power to start your small engine. But off course you cant use a lot of electronics without your engine running before your battery run low. But it should not be the end of the world if that happens either, as your engine should have a back-up thru-cowl manual start if im not mistaken.
If it don't its a different story and it becomes way more important that you have big enough battery(s)
Re: GF16 In The PSL
Posted: Sun Jun 15, 2014 2:46 pm
by jorgepease
I only have one battery on my current boat but it bothers me sometimes when I let the gps run for long periods as I drift fish, so far no problems, must not take that much juice. Think I will put 2 batteries on this new boat though. I agree on the manual pull start, if it comes with that you don't need a bigger battery.
Re: GF16 In The PSL
Posted: Sun Jun 15, 2014 3:36 pm
by Noles309
Yes, it has the manual through cowl start and that's pretty much what I was thinking. Thanks guys.
Re: GF16 In The PSL
Posted: Wed Jun 18, 2014 10:41 pm
by Noles309
Re: GF16 In The PSL
Posted: Thu Jun 19, 2014 12:57 pm
by Noles309
Re: GF16 In The PSL
Posted: Thu Jun 19, 2014 3:08 pm
by Cracker Larry
Very clean work. Nice
Re: GF16 In The PSL
Posted: Thu Jun 19, 2014 4:12 pm
by Noles309
Thanks CL.....FWC Inspection in the morning to Woohoo
Re: GF16 In The PSL
Posted: Thu Jun 19, 2014 4:15 pm
by Cannonball
-FWC inspection- Gettin it done before you're done. Nice!
Re: GF16 In The PSL
Posted: Thu Jun 19, 2014 10:03 pm
by justin_dwyer
Great work, your are flying through your build.
Looks like you have it well thought out.
Justin
Re: GF16 In The PSL
Posted: Thu Jun 19, 2014 10:19 pm
by Noles309
Cannonball wrote:-FWC inspection- Gettin it done before you're done. Nice!
Yep, I had heard that it was taking months to get someone to come out so I decided I would call. Surprisingly, the officer called me within an hour or so. He said as long as it looks like a boat, he could do the inspection basically at my convenience.
Thanks Justin, it doesn't seem like its going that fast most of the time.
Re: GF16 In The PSL
Posted: Sat Jun 21, 2014 10:44 am
by Noles309
Reference the Inspection, the FWC officer said they actually prefer the boat not be completely finished when they inspect it. Its easier for them to tell it is a built boat not a stolen hull. All he did was measure it and printed out the form for me to take to the tag office, took 10 minutes. He didn't want to see pictures or receipts.
He was a pretty cool guy and we talked boats and fishing for probably a 1/2 hr or so.
Re: GF16 In The PSL
Posted: Sat Jun 28, 2014 12:48 pm
by Noles309
Re: GF16 In The PSL
Posted: Sun Jun 29, 2014 8:22 am
by topwater
That's a pretty slick cooler setup . I use the gray tint , one coat neat epoxy and two with tint and its covered .
Re: GF16 In The PSL
Posted: Sun Jun 29, 2014 10:28 am
by Cracker Larry
I don't think you are using enough pigment. I've done a lot of white lately and 3 coats gives great coverage.
Edit: I like that cooler set up too
Re: GF16 In The PSL
Posted: Sun Jun 29, 2014 11:28 am
by Noles309
Thanks guys, I've been using about 1/2 teaspoon of the paste per 3oz of epoxy. I only have med hardener so I have to do small batches. Is that not enough? There are no real directions for using it that I have seen anywhere.
Re: GF16 In The PSL
Posted: Sun Jun 29, 2014 12:51 pm
by jorgepease
maybe you should put in a chase tube for the gps wire just in case you need to pull it one day. I like the way the cooler turned out as well!
Re: GF16 In The PSL
Posted: Sun Jun 29, 2014 9:47 pm
by Noles309
I have a chase tube but it is pretty small. Its 1 1/2" pvc cut in half length ways and will be glued in. There is no sole in the boat so the pvc runs along the starboard side bottom panel. I wanted to get the wires run before I foamed the compartment in case I had trouble getting the connector through.
Re: GF16 In The PSL
Posted: Thu Jul 03, 2014 10:31 am
by Noles309
Still plugging away. I cut and glued on some rod holders towards the bow and finished out the rod tubes in the rear seat. Rods can go in from either direction front or rear and are long enough for fly rods.
I made some risers in the bow compartment so the two 3 gal fuel tanks will sit level in there. I also added some blocks for the tank tie downs. That is four coats of tinted epoxy in there, still not opaque but I'm not putting anymore coats on it...I'm debating on whether to put a door on the bow compartment or leave it open. I have a vent and the hardware to do it but I just want to get done at this point...
Chase tube into the mid seat cooler compartment for the GPS fishfinder and LED lights
Whats this?....If the boat ever ends up in the hands of any Gators or Hurricanes, It will always be a Seminole skiff
The vertical tube will be glued to the horizontal chase and the compartment will be foamed in after I get the wires run.
Thats about all the progress except for some drill and fill for vertical rod holders and cup holders.
Re: GF16 In The PSL
Posted: Thu Jul 03, 2014 12:52 pm
by crackedconch
Except now at least one Hurricane fan knows where it is........hahaha
Re: GF16 In The PSL
Posted: Thu Jul 03, 2014 1:58 pm
by mindunderwater
I love your build to the point I'm going to build one of these myself. As CL said it's a pretty neat use of less than 10 sheets of plywood.... Your fishing pole tubes make me think I should go this route for my sending tubes - just continuing them from the midship seat aft (I want to do stick steer from the middle seat)
Re: GF16 In The PSL
Posted: Thu Jul 03, 2014 10:19 pm
by Noles309
crackedconch wrote:Except now at least one Hurricane fan knows where it is........hahaha
Ha, you may know but good luck getting to it...
Re: GF16 In The PSL
Posted: Thu Jul 03, 2014 10:27 pm
by Noles309
mindunderwater wrote:I love your build to the point I'm going to build one of these myself. As CL said it's a pretty neat use of less than 10 sheets of plywood.... Your fishing pole tubes make me think I should go this route for my sending tubes - just continuing them from the midship seat aft (I want to do stick steer from the middle seat)
Thanks man...I have heard nothing bad about any of the GF series of boats, other than the slight rocker issue...I thought about stick steer to, but in the end I decided to keep it pretty basic....well kind of basic anyway
. I have enjoyed the build process, very therapeutic, even the setbacks haven't really phased me that much.
Re: GF16 In The PSL
Posted: Thu Jul 03, 2014 11:25 pm
by mindunderwater
My weight is the deciding factor here. I've already been backed down once in a jon boat that swamped. Granted that WAS with two guys my size and a heavier O/B than I'm planning on.
Sorry if I missed it but did you have a concrete selection made on an outboard?
Re: GF16 In The PSL
Posted: Fri Jul 04, 2014 10:07 am
by Noles309
I got a deal I couldn't pass up on a 2011 20hp Nissan/Tohatsu 4 stroke. Its around 115-120 lbs I think. All the 4 strokes are heavy even the 9.9's are 100 lbs +/-.
I was originally planning on a 20-25 hp 2 stroke but like I said, I couldn't pass this one up.
Re: GF16 In The PSL
Posted: Fri Jul 04, 2014 12:17 pm
by AtTheBrink
All right! That should push you along pretty good!
Re: GF16 In The PSL
Posted: Fri Jul 04, 2014 1:34 pm
by jorgepease
I hear they are reliable motors!
Re: GF16 In The PSL
Posted: Mon Jul 14, 2014 7:06 pm
by Noles309
So, I am wrestling with putting a jackplate on this boat or not. It will be mostly used on the flats. I don't have enough experience with one to know if its worthwhile on this type of boat or not. I will probably build my own. I'm to the point I need to drill the transom holes for the motor/plate. Any thoughts?
Re: GF16 In The PSL
Posted: Mon Jul 14, 2014 8:14 pm
by Cracker Larry
I wouldn't put a jack plate on that boat. They tend to run light in the bow anyway and need some weight forward. Moving the motor (and CG) further back will just make it worse. It will draft plenty shallow as it is, Set the anti-ventilation plate about an inch above the bottom. Mine handled a lot better with a Doel Fin on the engine, helped keep the bow down and kept it from porpoising. But it was a 25 hp too.
Re: GF16 In The PSL
Posted: Mon Jul 14, 2014 8:46 pm
by jorgepease
Yeah, without a tunnel, I don't think it would be worth it either.
Re: GF16 In The PSL
Posted: Mon Jul 14, 2014 10:11 pm
by Noles309
Yeah, I guess I could try it first and see how low the motor sits on the transom and go from there. The motor had a Doelfin on it so thats a plus.
Re: GF16 In The PSL
Posted: Tue Jul 15, 2014 6:56 am
by Walkers Run
Noles,
I thought of you when I saw this. FSU boat fenders
http://www.thehulltruth.com/parts-forum ... -kits.html
Re: GF16 In The PSL
Posted: Tue Jul 15, 2014 1:06 pm
by Noles309
Ha, sweet
Re: GF16 In The PSL
Posted: Wed Jul 16, 2014 6:09 pm
by Noles309
Carbon Fiber grab bar.....Check...2 layers of 50/50 Biax FG/Carbon.
I'll add 2 more layers after this cures and then a crossbar or mini console.
Re: GF16 In The PSL
Posted: Wed Jul 16, 2014 8:56 pm
by selever
Looks cool. What is the core material of that bar?
Re: GF16 In The PSL
Posted: Wed Jul 16, 2014 9:09 pm
by jorgepease
Second that! Nice wrapping, how do you attach it now...
Re: GF16 In The PSL
Posted: Wed Jul 16, 2014 9:38 pm
by Noles309
selever wrote:Looks cool. What is the core material of that bar?
Thanks. The core is foam pipe insulation from Lowe's.
Re: GF16 In The PSL
Posted: Wed Jul 16, 2014 9:47 pm
by Noles309
jorgepease wrote:Second that! Nice wrapping, how do you attach it now...
Thanks Jorge. I haven't really decided yet. possibilities include, FG flanges, making some flanges out of meranti, making a mold and pouring an epoxy flange and hole sawing through the mid seat top and glassing it directly to the rear frame of the mid seat, under the seat top. I will have access to it through the cooler cutout. I'm kind of leaning toward option 4 right now it will be the strongest with the biax below the seat and a filet around the tubes where they pass through the seat but it would be nice to have it removable to...
Re: GF16 In The PSL
Posted: Thu Jul 17, 2014 7:41 am
by Cannonball
I like it. That will be a nice addition to the gf16. Looks good!
Re: GF16 In The PSL
Posted: Thu Jul 17, 2014 8:02 am
by Walkers Run
Nice work! How will you finish that? Paint or will you clear coat and leave the carbon fiber look.
Re: GF16 In The PSL
Posted: Thu Jul 17, 2014 9:36 am
by mindunderwater
I'd think leaving it black would be out of the question - wouldn't that be crazy hot sitting in the sun for a few hours?
You could do a wrap on it with rope...?
Re: GF16 In The PSL
Posted: Thu Jul 17, 2014 10:51 am
by Noles309
Thanks guys, I'm really happy with how it turned out so far. As far as finish, I'm not sure yet, possibly a top coat of UV rated epoxy or clear. I would like to keep it natural. Carbon Marine gets a fortune for these things and tiller extensions, they claim they don't get hot. Rope work is a possibility as well.......basically I don't have a clue right now
I will be leaving it out in the sun to see just how hot it gets before I make a decision on the final finish
Re: GF16 In The PSL
Posted: Sat Jul 19, 2014 7:44 pm
by Noles309
Can my fuel line and wires for my nav lights run in the same PVC chase I have made? I was planning on the fuel in the bow. Right now I have a 1 1/2" pvc pipe ripped on the starboard side floor. I really didn't want to run two but I suspect I will have to or leave the fuel in the aft compartment ....where the battery and most of the electrical is...I have the good Type A1 hose if that makes a difference...Thanks
Re: GF16 In The PSL
Posted: Sun Jul 20, 2014 9:12 am
by topwater
I would not run any wires in the same chase as a fuel line.
Re: GF16 In The PSL
Posted: Sun Jul 20, 2014 10:07 am
by Noles309
Yeah, I pretty much knew that, I was hoping though, another rookie mistake
I will pretty much have to stack it on top of the other one though because I already foamed the mid seat compartment on the port side (Glad I held off on the starboard side). Thats gonna look like crap I'm afraid. I don't want the fuel in the back and the mid seat is out due to the cooler cutout.
I should have kept it simple, I don't see how you guys do the multi year builds, I'm getting really antsy to get this thing done and its "only" been six months for me....
Re: GF16 In The PSL
Posted: Sun Jul 20, 2014 10:27 am
by Noles309
Walkers Run wrote:Nice work! How will you finish that? Paint or will you clear coat and leave the carbon fiber look.
Well I left it out for an hour or so yesterday, It got pretty warm, not too hot to handle but still pretty hot. Might paint it or do the ropework on it. You should still be able to see the weave through paint I think. Just another thing to figure out.
Re: GF16 In The PSL
Posted: Sun Jul 20, 2014 3:26 pm
by Cannonball
I'd do the rope work on it. That would look cool!
Re: GF16 In The PSL
Posted: Sun Jul 27, 2014 2:16 pm
by Noles309
Re: GF16 In The PSL
Posted: Sat Aug 02, 2014 9:33 pm
by Noles309
Re: GF16 In The PSL
Posted: Sat Aug 02, 2014 9:40 pm
by jorgepease
looking good, I think I got that same fuse box )
Re: GF16 In The PSL
Posted: Sat Aug 02, 2014 9:47 pm
by Noles309
Its real nice, 6 circuit Blue Seas with the negative buss on top?
Re: GF16 In The PSL
Posted: Sat Aug 02, 2014 11:42 pm
by jorgepease
I haven't opened it yet, it's a Blue Sea but I think it might be the 12
Re: GF16 In The PSL
Posted: Sun Aug 03, 2014 3:03 pm
by osotexan
Looking great Noles.
I sure cant wait to be semi retired
Re: GF16 In The PSL
Posted: Tue Aug 05, 2014 9:44 pm
by Noles309
osotexan wrote:Looking great Noles.
Ha, I'm ready to go back to work once the boat gets done
I made some progress the last couple of days no pics though. I ran the wiring, Installed the battery hold downs, glued down the split pvc chase tubes along the bottom, finished the aft compartment with some foam and white tinted epoxy, worked on the grab bar and mounts/re-enforcement and did a bunch of drill and fill. Getting closer...
Re: GF16 In The PSL
Posted: Tue Aug 05, 2014 10:23 pm
by willg
Noles, amazing progress. Your first build post was 7 months ago. Impressive!
Re: GF16 In The PSL
Posted: Wed Aug 06, 2014 10:48 am
by Noles309
Thanks Will. It seems like I do a lot of dreaming and screwing around on the internet instead of building though.
Re: GF16 In The PSL
Posted: Thu Aug 07, 2014 5:03 pm
by Noles309
Re: GF16 In The PSL
Posted: Thu Aug 07, 2014 5:55 pm
by Cracker Larry
I hear you on the heat and humidity. 103 under my shed today, I had to quit early. Real early. Will try to hit a couple hours this evening if it cools down. Still 100 at 6 pm. To hot to even think clearly or work productively.
Your boat is looking good
Stay hydrated!
Re: GF16 In The PSL
Posted: Thu Aug 07, 2014 7:59 pm
by Noles309
Cracker Larry wrote:I hear you on the heat and humidity. 103 under my shed today, I had to quit early. Real early. Will try to hit a couple hours this evening if it cools down. Still 100 at 6 pm. To hot to even think clearly or work productively.
Stay hydrated!
Thanks Larry. Yeah it was 97 in my garage and the heat index was 102 I think. South GA, is definitely hotter than South FL. My son is in Richmond Hill and it has been god awful a few times we've been up there in the summer. Ya'll have cornered the market on gnats to
Re: GF16 In The PSL
Posted: Fri Aug 08, 2014 12:14 pm
by wegcagle
True, but then again we never have to worry about going hungry... just open your mouth for a few minutes and you can eat a couple hundred of the little guys
Will
Re: GF16 In The PSL
Posted: Sat Aug 09, 2014 11:33 am
by PastorBob
Boat is coming togather very well.. Your giving me a bunch of Ideas for my rebuild
.. We were in S. Ga 2 weeks ago at the inlaws I don't know how you do it.. Enjoy the progress keep the photos coming.. Bob
Re: GF16 In The PSL
Posted: Sun Aug 10, 2014 8:39 pm
by Noles309
Re: GF16 In The PSL
Posted: Sat Aug 16, 2014 4:06 pm
by Noles309
Re: GF16 In The PSL
Posted: Sat Aug 16, 2014 7:49 pm
by jorgepease
Looking good!!!!!
Re: GF16 In The PSL
Posted: Sun Aug 17, 2014 6:54 am
by Walkers Run
It's really coming together now. Very nice.
Re: GF16 In The PSL
Posted: Sun Aug 17, 2014 11:47 am
by wildbill
Damn; my deer & pronghorn heads are in my shop too !
nice work, Bill
Re: GF16 In The PSL
Posted: Sun Aug 17, 2014 7:53 pm
by Noles309
Thanks fellas, Yeah bill, you have to pick your battles with SWMBO. I did make a coat/hat rack out of a set. Those get to live indoors
Re: GF16 In The PSL
Posted: Mon Aug 18, 2014 5:12 pm
by Noles309
OK, today I mounted the motor to see where I was at as far as height and to drill and fill the mounting holes. As it sits right now the anti ventilation plate is 1" below the bottom, thereby making the motor skeg 12 1/2" below the bottom. I've read most flats boats run 1-2" above the bottom with the anti ventilation plate and Cracker Larry said he ran his GF16 1" above. Suggestions? I have the material to build a jack plate but CL advised against it on this hull.
Re: GF16 In The PSL
Posted: Mon Aug 18, 2014 8:42 pm
by jorgepease
Without a tunnel you could still benefit from a jackplate with at least 4" set back, maybe get you a couple inches above the bottom of the boat or more even … if it doesn't screw up your center of gravity or if it's not too much for your transom to bear, that may be why he recomended against it.
Re: GF16 In The PSL
Posted: Mon Aug 18, 2014 9:23 pm
by Noles309
Thanks Jorge. That makes sense.
Cedarock advised me to build up the transom to get it level or 1/4" below. I'm going to post this in the Powerboats section as well so it will get more views.
Re: GF16 In The PSL
Posted: Mon Aug 18, 2014 9:59 pm
by Cracker Larry
I wouldn't use a jack plate, that boat will already be light in the bow and moving the engine aft will make it worse. And the boat does like the AV plate an inch or so above the bottom. That's where I'd start with it.
Re: GF16 In The PSL
Posted: Mon Aug 18, 2014 10:13 pm
by Noles309
Cracker Larry wrote:I wouldn't use a jack plate, that boat will already be light in the bow and moving the engine aft will make it worse. And the boat does like the AV plate an inch or so above the bottom. That's where I'd start with it.
So just build up the transom a couple of inches you think since its an inch below?
Re: GF16 In The PSL
Posted: Sun Aug 31, 2014 7:11 pm
by Noles309
Re: GF16 In The PSL
Posted: Mon Sep 01, 2014 9:11 am
by cottontop
Nice build! John
Re: GF16 In The PSL
Posted: Wed Sep 03, 2014 10:48 pm
by Noles309
Thank you John.
Not much to report here and nothing really picture worthy. I glassed over the transom riser and slatherd some blended filler on it and the inside today. More sanding is in my future
Re: GF16 In The PSL
Posted: Tue Sep 09, 2014 6:33 pm
by Noles309
Re: GF16 In The PSL
Posted: Tue Sep 09, 2014 9:58 pm
by snookiehunter
Looking good, brother. You're going to be on the water in no time!
Re: GF16 In The PSL
Posted: Tue Sep 09, 2014 11:00 pm
by jorgepease
yep, your almost there )
Re: GF16 In The PSL
Posted: Sat Sep 13, 2014 4:25 am
by justin_dwyer
Looking good mate, you'll be sorting out your fishing tackle soon
Re: GF16 In The PSL
Posted: Tue Sep 16, 2014 7:29 pm
by Noles309
Thanks guys.
I finished fairing the inside today and got a coat of primer on it. Pics tomorrow after i get the second or third coat on it. It will be nice to see her all one color.
Re: GF16 In The PSL
Posted: Wed Sep 17, 2014 2:30 pm
by Noles309
Re: GF16 In The PSL
Posted: Wed Sep 17, 2014 5:57 pm
by justin_dwyer
That looks great Mate, very tidy little boat
Re: GF16 In The PSL
Posted: Wed Sep 17, 2014 6:22 pm
by Walkers Run
Looks great! Amazing how it comes together when it's all one color.
Re: GF16 In The PSL
Posted: Wed Sep 17, 2014 7:02 pm
by Aripeka Angler
Very clean work, two thumbs up
Re: GF16 In The PSL
Posted: Wed Sep 17, 2014 9:32 pm
by Cracker Larry
It looks great, but I've just got to ask. It doesn't look like the bow deck is glassed in?
Re: GF16 In The PSL
Posted: Wed Sep 17, 2014 10:04 pm
by jorgepease
looking good, like it!
Re: GF16 In The PSL
Posted: Thu Sep 18, 2014 5:58 am
by mattken85
Larry I was thinking the same thing. Boat looks great though, you started your gf16 well after I did and have jumped way ahead of my progress.
Re: GF16 In The PSL
Posted: Thu Sep 18, 2014 8:24 am
by Irish
Great job Noles...like your rod holder idea should have done that on mine. Thinking the same as Larry re the front deck, rear one as well
Re: GF16 In The PSL
Posted: Thu Sep 18, 2014 10:08 am
by Noles309
I got the third coat of primer on late yesterday afternoon.
Yeah, the decks aren't glued down yet. I'm going to paint the outside, install and wire the shark eyes and bow and stern eyes before I glue them down. I wasn't sure if I could get to them or not with the decks down with my jacked up shoulder and back.
I had mixed primer left so I used it there. I wanted to see it all one color
Well mostly all one color anyway. I only faired and primed around the raised part of the transom where I built the riser. I still have to run a 6" strip of glass along the transom and rear deck when its installed.
Thanks for the props.
Re: GF16 In The PSL
Posted: Thu Sep 18, 2014 10:46 am
by Noles309
Cracker Larry wrote:It looks great, but I've just got to ask. It doesn't look like the bow deck is glassed in?
My plans don't show the bow deck glassed in, only 6" tape where the transom joins the rear deck. Do you recommend glassing it in? I did glass the deck tops with 6 oz.
Re: GF16 In The PSL
Posted: Thu Sep 18, 2014 12:12 pm
by Cracker Larry
It should be taped to the transoms, sides and frames. The seats/decks are structural in that boat and must be glassed all around.
Re: GF16 In The PSL
Posted: Thu Sep 18, 2014 8:14 pm
by Noles309
Cracker Larry wrote:It should be taped to the transoms, sides and frames. The seats/decks are structural in that boat and must be glassed all around.
OK. That is not what the building notes and lamination schedule show.
Quote: "On the outside of frames, putty fillets only, no tape.... Re-install seat tops on cleats. Fillet along hull sides, no tape except at seam between clamping board and rear seat top."
If you are recommending that I have no problem doing it as I have the glass and maybe enough resin to do it. I'm not trying to be contrary and have much respect for your expertise and high level of craftsmanship, but my plans don't say that.
Re: GF16 In The PSL
Posted: Fri Sep 19, 2014 1:09 am
by mattken85
My plans say the same thing, I didn't realize it. I am still planning on glassing it all the way to the top. I'm probably going overboard on fiberglass on mine.
Re: GF16 In The PSL
Posted: Fri Sep 19, 2014 10:19 am
by jorgepease
The fillets are strong but the glass will keep it from cracking with flex over time. im surprised its not on the plans
Re: GF16 In The PSL
Posted: Fri Sep 19, 2014 10:27 am
Drawing D218/3:
6. Build 1/2" radius putty fillet all around frames.
Tape outside seams of frames to hull sides
with 1 layer 6" tape.
and
12. Seams between seat tops and hull = 1/2"
radius putty fillet.
13. Between clamping board and upper face of seat,
one layer 6" wide fiberglass tape on
(1/2" radius) putty fillet.
You could just as well do that for all seat tops.
The boat was designed with a 15 HP in mind. Most builders use larger engines: glass the seat tops to the hull. It doesn't take much material or add much weight and will be stiffer.
Without it, nothing will break but yes, you could have stress cracks in the fairing putty after a few years of use.
Re: GF16 In The PSL
Posted: Fri Sep 19, 2014 1:18 pm
by Noles309
OK, the frames are glassed as per the plans. The mid seat top, where it meets the hull, is a fillet of wood flour sanded smooth, no fairing material was used. Am I good there? I was planning on doing the same for the bow and rear seat to include the tape at the transom as per the plans. Am I at risk of the wood putty fillet cracking if I don't glass over it? I would think not but I'm a amateur...
Maybe this glassing should be added to the plans as an option?
I will be running a 20hp 4-stroke. The entire outside of the hull is glassed in biax.
Re: GF16 In The PSL
Posted: Fri Sep 19, 2014 1:56 pm
I would glass all the tops. There will be a little more to fair but not much. You anyway will have to fair that seam if you glue them down with putty only.
I may add that to the plans: almost everybody uses a larger engine and it cost only a few feet of glass tape and a little bit of fairing.
Re: GF16 In The PSL
Posted: Fri Sep 19, 2014 6:30 pm
by Noles309
Jeezalou....just when I thought I was almost done.
Re: GF16 In The PSL
Posted: Fri Sep 19, 2014 7:35 pm
by Hope2float
She looks great, nice and clean. That looks like a great little boat. My advice to you is simple put glass tape over all fillets and there is no need to second guess or after a little slamming sit there and say I should have. On my P-21 all fillets are taped and it has pounded pretty hard and no stress cracks . I know it has only been on the water a short time. So far no problems
BUILD-ON!
Dave
Re: GF16 In The PSL
Posted: Fri Sep 19, 2014 7:50 pm
Yes, that's what I mean. When I say glass the tops, I mean tape the edges, not the whole thing.
Re: GF16 In The PSL
Posted: Sat Sep 20, 2014 10:38 am
by Noles309
Thanks everyone. I reassessed my inventory of supplies and I may or may not have enough resin and QF to do this. It will be really close. Probably a no on the QF. Dammit Jim...
Edit: Not enough biax tape either
So, I have some 10oz tape, will that work or does it have to be biax? I have enough cloth to make strips, but that is such a mess, I really don't want to do that...
Re: GF16 In The PSL
Posted: Sat Sep 20, 2014 2:04 pm
You can use the 10 oz. tape.
Re: GF16 In The PSL
Posted: Sat Sep 20, 2014 3:07 pm
by Walkers Run
how much quick fair do you need? I might have some
Re: GF16 In The PSL
Posted: Sat Sep 20, 2014 10:10 pm
by Doc_Dyer
Noles309 wrote:Dammit Jim....
Is this a bones reference ?
Re: GF16 In The PSL
Posted: Sun Sep 21, 2014 8:53 am
by topwater
I think it is
Re: GF16 In The PSL
Posted: Sun Sep 21, 2014 10:05 am
by Noles309
Doc_Dyer wrote:Noles309 wrote:Dammit Jim....
You got it
Thanks for the offer Bob. I'll see how it shakes out.
Re: GF16 In The PSL
Posted: Tue Sep 23, 2014 1:34 pm
by Noles309
Re: GF16 In The PSL
Posted: Tue Sep 23, 2014 6:21 pm
by Noles309
It sprinkled just a tiny bit, but never really rained
I knew it... It was black as can be....Worked on the grab bar a little bit instead. I'll try it again on Thursday I guess.
Re: GF16 In The PSL
Posted: Tue Sep 23, 2014 9:12 pm
by jorgepease
Don't worry, if you had started painting it would have been the perfect storm x 2 !!!
Re: GF16 In The PSL
Posted: Wed Sep 24, 2014 1:26 pm
by Noles309
Ha, you are right for sure.
Re: GF16 In The PSL
Posted: Thu Sep 25, 2014 7:46 pm
by Noles309
Well I had a setback today. I'm using the Monstaliner for paint (OD Green) like Jorge did on his XF20. I was painting the outside today. The first coat went on great. The second coat not so much. It started clumping up on me. I should have stopped, but I didn't. The stuff is just too expensive to waste, or so I thought. I guess I should probably sand it and re-coat it. I'm waiting to hear back from the company about it.
I was meticulous in following the directions. I'm not impressed so far and I bought enough in a contrasting color to do the inside (Desert Sand) as well...
Re: GF16 In The PSL
Posted: Thu Sep 25, 2014 9:57 pm
by justin_dwyer
That sucks mate, big time!!
Hope you get it sorted out so you can move on.
Nice colours though, I like them
Re: GF16 In The PSL
Posted: Thu Sep 25, 2014 10:24 pm
by jorgepease
That might be the roller falling apart on you, it's what happened to me. I managed to pick out most of the bits and sanded the rest but the paint gets tough, I would cut that off as soon as possible, it's easy to recoat and yeah it does set up fast in high humidity or heat, I didn't get anywhere near the pot life they said I would.
Re: GF16 In The PSL
Posted: Fri Sep 26, 2014 8:25 am
by topwater
Its got to be the high humidity . I never had a problem with it or the rollers. But i do work in a air conditioned
shop . Did you float some acetone on top of the mixed paint between coats to keep air out ?
Re: GF16 In The PSL
Posted: Fri Sep 26, 2014 8:39 am
by Noles309
topwater wrote:Its got to be the high humidity . I never had a problem with it or the rollers. But i do work in a air conditioned
Yep did all that. Its not the roller. The humidity was 74%. It was basically unusable after 1 1/2- 2 hrs.
Unfortunately, I'm leaving town now and can't cut the chunks off. I did a few but whatever....
Re: GF16 In The PSL
Posted: Fri Sep 26, 2014 8:55 am
by topwater
I had something similar happen with S3 primer . I mixed to much so like a bone head i thought if i sealed it up
real good it would be all right by the time i had to use it for the next coat . The exact same thing happened,
started clumping up when i tried to roll it. I let it dry then sanded it off lesson learned
Re: GF16 In The PSL
Posted: Fri Sep 26, 2014 5:23 pm
by Noles309
topwater wrote:I had something similar happen with S3 primer . I mixed to much so like a bone head i thought if i sealed it up
Yeah, pretty much what I did, except the instructions tell you to mix the whole gallon and the pot life is 10 hrs...
Monstaliner ignored my email and they close at 4:00. I missed them when I called yesterday and been traveling today.
Re: GF16 In The PSL
Posted: Sat Sep 27, 2014 8:32 am
by topwater
Both times i have used this stuff i did exactly that and didn't have a problem. The boat was in a controlled environment
but i did do my pickup outside in my garage . Of course the only time i get humidity in the 75 percent range is in the
middle of august .
Re: GF16 In The PSL
Posted: Sun Sep 28, 2014 9:30 pm
by Noles309
Unfortunately 74% humidity is low this time of year as was the temp @ an overcast 82 deg. I don't have access to a climate controlled shop and the boat wont fit through the front door...
I did hear back from them today via email. I guess they are in the middle of a move.The guy wants me to call him tomorrow. We'll see what happens. Buying more to put another coat on the outside is not setting well with me right now.
When I do the inside I will probably mix a half gallon at a time. I'm not taking a chance on it happening again.
Re: GF16 In The PSL
Posted: Mon Sep 29, 2014 12:17 pm
by Noles309
Today I talked with Eric Rosenthal the President of Monstaliner. He will be sending me another half gallon to put another coat on the outside. He gave me some other tips and tricks for using it as well. He said this happens every once in a great while and seems to be more of a temperature related event than humidity.
Anyway, more sanding, I don't have to sand it off just scuff it and cut off the big chunks with a razor blade. I'm not happy about having to re-do it but its nice when a company stands behind their product.
It does seem like its going to be a great product for a tough, no maintenance finish. I actually like the satin finish with the light texture it has, in the areas without the chunks in it of course. I now wish I hadn't faired it as much. This stuff will hide some sins to.
Re: GF16 In The PSL
Posted: Mon Sep 29, 2014 4:48 pm
by Noles309
Actually, after cutting all the chunks off with a razor blade it doesn't look half bad from 5'
Still need to scuff it with 120 then re-coat.
Re: GF16 In The PSL
Posted: Mon Sep 29, 2014 5:47 pm
by wildbill
That's a really good looking color.
Bill
Re: GF16 In The PSL
Posted: Mon Sep 29, 2014 6:12 pm
by jorgepease
looks great! )
Re: GF16 In The PSL
Posted: Tue Sep 30, 2014 8:43 am
by topwater
I think you will be real happy with it, its tough stuff. I have had it on the rocker panels
of my pickup for two years now and its holding up great .From -30 to 100 degrees and
still looks great .
Re: GF16 In The PSL
Posted: Tue Sep 30, 2014 3:33 pm
by justin_dwyer
That looks awesome Nole, don't worry about the setback, you'll move on pretty quick
Keep up the great work!
Re: GF16 In The PSL
Posted: Thu Oct 09, 2014 5:35 pm
by Noles309
Got my paint from Monstaliner on Monday and re-coated her today.
It looks great, but I would have had the same problem again if this was the original application which calls for 2 coats instead of it being a a re-coat. I had enough extra mixed so I was doing the flanges and shelf on the grab bar and hitting a couple of thin spots on the hull and she started to chunk and set up fast. The temp today was 84 and the humidity was 59%. The pot life down here is about 3 hrs max. A far cry from the 10 they advertise. I will wait for cooler weather to do the inside.
I took pics but it really doesn't look much different than the other ones I posted with the chunks cut off. The camera doesn't pick up the detail very well.
Next up, install bow and stern eyes and the shark eyes then glue and glass the bow and stern decks.
Re: GF16 In The PSL
Posted: Fri Oct 10, 2014 8:48 am
by topwater
Glad to hear you got it straighten out .
Re: GF16 In The PSL
Posted: Fri Oct 10, 2014 10:05 am
by Noles309
Thanks Top.
On a side note I saw you are from IL. I'm originally from Springfield and mostly grew up there. We moved to FL when I was a teenager. We had family in Dekalb and Crystal Lake and made many holiday trips up there. Good times, don't miss that brutal cold though. For the most part, we all pretty much left the state. We still have some ties though, my grandparents family farm around Clinton is leased out and still being farmed.
Re: GF16 In The PSL
Posted: Fri Oct 10, 2014 9:18 pm
by Noles309
Re: GF16 In The PSL
Posted: Sat Oct 11, 2014 6:42 am
by Walkers Run
Very clean wiring Noles. Looks great!
Re: GF16 In The PSL
Posted: Sat Oct 11, 2014 9:03 am
by jorgepease
Nice job!
Re: GF16 In The PSL
Posted: Sun Oct 12, 2014 5:28 pm
by Jim_Davisson
Great looking boat! Seeing it makes me miss my 16' Duracraft. I could go anywhere in it and with a pair of waders and the rear trolling motor I could push it into places it shouldn't have gone.
Re: GF16 In The PSL
Posted: Mon Oct 13, 2014 5:15 pm
by Noles309
Thanks guys
. I got the decks glued down today. Getting there.
I did have a change of plans. I had bought white Kiwigrip to match the desert sand color I'm painting the inside. They couldn't match it because it would have been over the amount of colorant that Kiwi recommends. So it has to be a contrasting color. Now she will be a tricolor. We'll see how it turns out. I reckon...
Re: GF16 In The PSL
Posted: Mon Oct 13, 2014 6:39 pm
by justin_dwyer
Looks awesome Noles.
Did you predrill all those screw holes for the wiring and then fill them with resin, or did you just screw straight into the wood?
Getting closer!
Re: GF16 In The PSL
Posted: Mon Oct 13, 2014 10:13 pm
by Noles309
justin_dwyer wrote:Looks awesome Noles.
Getting closer!
I did drill and fill and it sucked...
Re: GF16 In The PSL
Posted: Thu Oct 16, 2014 8:13 pm
by Noles309
Today I got the decks glassed down and I put a coat of UV resistant epoxy on the carbon fiber parts of the grab bar. No pics but making progress slowly but surely...
I'll get the glass tape faired up and primed and hopefully I can get the inside painted next week. Its finally cooling off some so if I paint it early enough, I shouldn't have any issues with the Monstaliner setting up too quick. We'll see I reckon.
Re: GF16 In The PSL
Posted: Sat Oct 25, 2014 10:52 am
by Noles309
Still working on fairing the decks in. Man that is time consuming. I was going to town yesterday, looked up and four hours were gone
I have done two rounds of QF and hopefully sanding round two and final spot priming today. Inside paint next week with any luck...
Edit for boring pics, but still pics...
Re: GF16 In The PSL
Posted: Sat Oct 25, 2014 6:10 pm
by osotexan
Noles,
She is looking amazing! I really like the color and love the shark eye style nav lights. I'm shopping for a pair for mine. Looks like you are getting to the really fun part while I will go sand some more, then some more and probably a little more.....
Re: GF16 In The PSL
Posted: Tue Nov 04, 2014 7:26 pm
by Noles309
Re: GF16 In The PSL
Posted: Tue Nov 04, 2014 7:41 pm
by terrulian
Looks pretty dang good from here!
Re: GF16 In The PSL
Posted: Tue Nov 04, 2014 8:25 pm
by Cracker Larry
I like it
Re: GF16 In The PSL
Posted: Wed Nov 05, 2014 8:06 am
by topwater
The boat is looking real nice . I like the monstaliner .
Re: GF16 In The PSL
Posted: Wed Nov 05, 2014 9:21 am
I said it before but I love that hull color. Nice job.
Re: GF16 In The PSL
Posted: Wed Nov 05, 2014 10:20 am
by Noles309
Re: GF16 In The PSL
Posted: Wed Nov 05, 2014 10:30 am
by Cracker Larry
Excellent. You will really enjoy it on the water too. Best little jon boat I've ever had.
Re: GF16 In The PSL
Posted: Wed Nov 05, 2014 5:35 pm
by jorgepease
What a beauty!!! Great Job!
Re: GF16 In The PSL
Posted: Wed Nov 05, 2014 6:02 pm
by pee wee
I have to ask . . . how will you mount the grab bar? I see it on top of the bench, but will it be screwed down, bolted down, will it be strong enough to grab hold of? I have to assume you've got it figured out, but I got impatient and wondered.
Re: GF16 In The PSL
Posted: Wed Nov 05, 2014 6:07 pm
by Walkers Run
Man that looks great!
Re: GF16 In The PSL
Posted: Wed Nov 05, 2014 8:20 pm
by Noles309
pee wee wrote:I have to ask . . . how will you mount the grab bar? I see it on top of the bench, but will it be screwed down, bolted down, will it be strong enough to grab hold of? I have to assume you've got it figured out, but I got impatient and wondered.
It will be through bolted. I also doubled up the seat top where they will mount to 1" and added bracing. It is plenty strong.
Ignore my epoxy drips and where I got careless with the roller inside the seat box.
Thanks guys for the comments.
Re: GF16 In The PSL
Posted: Wed Nov 05, 2014 9:24 pm
by BB Sig
If you can live with the drips, then I sure as heck can. Nice boat. I've been enjoying the build.
Re: GF16 In The PSL
Posted: Wed Nov 05, 2014 11:13 pm
by justin_dwyer
I love the colours too, great job Noles!!
Re: GF16 In The PSL
Posted: Thu Nov 06, 2014 6:30 pm
by Noles309
Re: GF16 In The PSL
Posted: Thu Nov 06, 2014 7:39 pm
by justin_dwyer
Looks great from where I'm sitting
Re: GF16 In The PSL
Posted: Thu Nov 06, 2014 9:09 pm
by BarraMan
Ohhhh! Now that IS nice!
Re: GF16 In The PSL
Posted: Sun Nov 09, 2014 9:10 pm
by Noles309
Re: GF16 In The PSL
Posted: Sun Nov 09, 2014 9:14 pm
by justin_dwyer
Neat looking work there Noles, looks like you're nearly home and hosed!
Might be a dumb question, what's sitting next to your sounder, I want to say it's where you put your beer snacks while your driving, but I'm thinking a rod holder?
Re: GF16 In The PSL
Posted: Sun Nov 09, 2014 9:20 pm
by Noles309
justin_dwyer wrote:Neat looking work there Noles, looks like you're nearly home and hosed!
You got it
, its a Scotty brand drink holder.
I do need to figure out some vertical rod holders though. Add that to the list.
Re: GF16 In The PSL
Posted: Wed Nov 12, 2014 10:19 pm
by Noles309
I finished the wiring today and amazingly everything works.
Tomorrow I'm going to the tag office to register it and start working on the trailer.
Re: GF16 In The PSL
Posted: Thu Nov 13, 2014 7:45 am
by Cracker Larry
That's about the nicest GF16 I've ever seen
Re: GF16 In The PSL
Posted: Thu Nov 13, 2014 3:20 pm
by willg
Noles, clean and precise work there. Really looking great.
Re: GF16 In The PSL
Posted: Thu Nov 13, 2014 9:25 pm
by Noles309
Cracker Larry wrote:That's about the nicest GF16 I've ever seen
That means a lot coming from a master craftsman such as yourself. I'm really happy with it. Its not perfect by any means but anyone thats seen it seems impressed. I keep going out in the garage just to look at it. I'm such a dork, at least thats what the little woman says and I reckon she's right.
willg wrote:Noles, clean and precise work there. Really looking great.
Thanks Will.
I got her registered today. It was relatively painless and took about an hour. They wanted everything and photocopied all my receipts and looked at all my pictures. The clerk and the boss. They probably don't do this that often would be my guess.
I went by a sign shop to order some registration decals in a nice contrasting color, the wife may be right
Trailer and motor next.
Re: GF16 In The PSL
Posted: Sat Nov 15, 2014 11:27 am
by Noles309
Not much progress to report. I did make a transom support plate out of some 3" x 1/4" aluminum. I used a 3" piece so I could put the motor through bolts through the bottom portion and have it be tall enough so the motor clamps will clamp down on it instead of the finished transom.
After I rounded off the corners:
After about 15 minutes of sanding with 400 then 600 and hand rubbing it with some Meguiars metal polish.
And where it will live:
Its not perfect but it looks pretty good to me. I just need to drill the holes.
Re: GF16 In The PSL
Posted: Sat Nov 15, 2014 11:33 am
by peter-curacao
Gary your boat looks great very nice work!
Something else, I found you a new signature picture hope you like it
Re: GF16 In The PSL
Posted: Sat Nov 15, 2014 11:50 am
by Noles309
HAHA thats frigging awesome man. I'm keeping that one
Thanks Peter
Re: GF16 In The PSL
Posted: Sat Nov 15, 2014 12:10 pm
by Cracker Larry
I told yall Peter aint right
Re: GF16 In The PSL
Posted: Sat Nov 15, 2014 6:31 pm
by jorgepease
Nice on both pics LOL!!
Re: GF16 In The PSL
Posted: Fri Dec 12, 2014 7:40 pm
by Noles309
Re: GF16 In The PSL
Posted: Fri Dec 12, 2014 8:11 pm
by jorgepease
Everything looks great!!!
Re: GF16 In The PSL
Posted: Fri Dec 12, 2014 8:42 pm
by Cracker Larry
Looks good, but I'd put another support on the trailer, closer towards the bow. Too much unsupported boat forward.
Re: GF16 In The PSL
Posted: Fri Dec 12, 2014 9:09 pm
by Noles309
Cracker Larry wrote:Looks good, but I'd put another support on the trailer, closer towards the bow. Too much unsupported boat forward.
Yes sir that is definitely in the plans.
jorgepease wrote:Everything looks great!!!
Re: GF16 In The PSL
Posted: Sat Dec 13, 2014 6:29 am
by Walkers Run
Great looking boat!
Re: GF16 In The PSL
Posted: Sat Dec 13, 2014 8:56 am
by topwater
The boat looks great out in the daylight
Can't wait to see it in the water .
Re: GF16 In The PSL
Posted: Sat Dec 13, 2014 3:14 pm
by Noles309
Thanks guys.
Today I mounted the motor, installed all the fuel line fittings, got the throttle cables and all the other parts installed that the previous owner removed when he converted it to remote steer. It was a backyard Magyverd type conversion btw...
The carb needs rebuilt, I'm trying to decide if I want to try and tackle that or not.
Heavy ass cooler for some up front weight. I put a block of closed cell foam under the front of the cooler to level it out. Works great.
Re: GF16 In The PSL
Posted: Sat Dec 13, 2014 3:34 pm
by jorgepease
motor looks brand new ))
Re: GF16 In The PSL
Posted: Sat Dec 13, 2014 10:49 pm
by Noles309
jorgepease wrote:motor looks brand new ))
It pretty much is
. It still has the original oil filter and oil in it and it looks barely run, really clean. The old dude (I'm old, but he is considerably older than me
) I bought it from said it had around 10 hrs on it and it looks it. It has sat for at least 3 years and the fuel wasn't drained or run out of it or anything.
I have a factory service manual and the carb rebuild kit. Whats the consensus on trying a rebuild? I have some mechanical aptitude but I've never attempted an outboard carb rebuild before
I am kind of nervous about it.
The Nissan manual is a little lacking. I had to figure out the tiller re-install myself, not much in the manual about it, especially orienting the tiller throttle cables. The book assumes its already installed and only needs adjustment. An exploded parts diagram I found on the web came in kind of handy.
Re: GF16 In The PSL
Posted: Sun Dec 14, 2014 5:35 am
by nathan
Very nice build.
Don't be nervous about the carb cleaning. You obviously have the mechanical aptitude.
Get a can of carb cleaner from an auto parts store, a good clean place to work (I use a oven broiler pan for small carbs), properly fitting screw drivers , compressed air might help (be very careful with the air you don't want to shoot a small part across the room or damage a diaphragm that you didn't know was there) and safety glasses while using the cleaner and air.
I rarely use a kit but it should make things extra easy, just swapping out jets and seats after cleaning very easy. A torn gasket will make the kit invaluable.
Re: GF16 In The PSL
Posted: Sun Dec 14, 2014 7:47 am
by jorgepease
You just built a boat! Whats a little carb rebuild!!! ))
As long as you don't need any specialized tools
Re: GF16 In The PSL
Posted: Sun Dec 14, 2014 2:00 pm
by Noles309
Thanks for the reassurance fellas. I'll probably give it a go.
Re: GF16 In The PSL
Posted: Sun Dec 14, 2014 2:40 pm
by Aripeka Angler
Very nice looking completed boat
Time to get her on the water!
On the carb rebuild, use your cell phone to snap pics of parts removal sequence. I rebuilt Harrison's carb on the aluminum boat he had before the GF-12. It was pretty easy
Re: GF16 In The PSL
Posted: Mon Dec 15, 2014 1:20 pm
by Matt Gent
Noles309 wrote:jorgepease wrote:motor looks brand new ))
Easy, have to do it seasonally on my yamaha. More often than not I don't find anything but it runs great when put back together. Shoot me a note if you have trouble, I'm off all December.
Re: GF16 In The PSL
Posted: Mon Dec 15, 2014 3:48 pm
by Walkers Run
I use this stuff. It comes with a basket inside, you put the disassembled carb in the basket and let soak in the nasty stuff.
let me know if you want to borrow it. I'm in the PSL all the time. I want to see your boat anyway.
Bob
Re: GF16 In The PSL
Posted: Mon Dec 15, 2014 8:10 pm
by Noles309
Thanks guys.
Bob, shoot me an email I'll give you my#.
Re: GF16 In The PSL
Posted: Mon Dec 15, 2014 8:41 pm
by Cracker Larry
You can probably find a youtube video on exactly how to rebuild/clean it. I recently rebuilt the carb on my lawn mower and found a dozen videos on how to do it.
Re: GF16 In The PSL
Posted: Thu Dec 18, 2014 1:15 pm
by bernd1
Nice boat Gary !
BTW how deep had you mounted your engine? Distance bottom to AV-plate motor? Even ? I'm interested to know this.
Bye
Bernd
Re: GF16 In The PSL
Posted: Thu Dec 18, 2014 5:58 pm
by Walkers Run
I had the opportunity to see Gary's boat in person this week. The pictures don't do it justice. Great looking boat!
Re: GF16 In The PSL
Posted: Thu Dec 18, 2014 6:54 pm
by Noles309
bernd1 wrote:Nice boat Gary !
Bye
Bernd
Thanks Bernd. On the advice of CL, the AV plate is one inch above the bottom.
Walkers Run wrote:I had the opportunity to see Gary's boat in person this week. The pictures don't do it justice. Great looking boat!
Thanks Bob, it was nice meeting you.
Today I worked on my poling platform. I got the deck part of it cut, glued and glassed. I also installed a bow support bunk on the trailer.
Re: GF16 In The PSL
Posted: Fri Dec 19, 2014 11:49 am
by bernd1
Gary,
let me know how the boat runs with this installation. I planed to raise my engine too but I found no time to do it.
If possible just make a video of the boat running.
Bye
Bernd
Re: GF16 In The PSL
Posted: Fri Dec 19, 2014 2:55 pm
by Noles309
Will do Bernd, hopefully soon.
Re: GF16 In The PSL
Posted: Wed Jan 07, 2015 8:42 pm
by Noles309
I've been getting a little done. Iv'e been working on a carbon fiber tiller extension and a short poling/casting platform/seat combo. Putting off the carb rebuild as long as possible
Re: GF16 In The PSL
Posted: Thu Jan 08, 2015 12:11 pm
by Fuzz
Ok, I give. GF16 in the PSL. What is the PSL?
Nice looking build, I am looking forward to seeing the on the water reports.
Re: GF16 In The PSL
Posted: Thu Jan 08, 2015 12:34 pm
by Cracker Larry
Port St. Lucie, Florida
Re: GF16 In The PSL
Posted: Thu Jan 08, 2015 1:30 pm
by Noles309
Cracker Larry wrote:Port St. Lucie, Florida
Ding ding....aka the pissle, pizzle, Port St.Lousy or NYC south. I could go on
When the Mrs. retires we are packing up for the Florida panhandle coast or the SE GA or SC coast. Haven't completely decided yet, just outta here. Gotta few years left though...
Re: GF16 In The PSL
Posted: Thu Jan 08, 2015 2:06 pm
by BB Sig
The panhandle is nice. I prefer around Apalachicola, Port St. Joe or Mexico Beach. Anywhere in between is good. The Mormons bought up a lot of the larger parcels of land in the last few years. Not sure what that was about but it makes it harder for the rest of us to get any.
Re: GF16 In The PSL
Posted: Thu Jan 08, 2015 6:02 pm
by Noles309
BB Sig wrote:The panhandle is nice. I prefer around Apalachicola, Port St. Joe or Mexico Beach. Anywhere in between is good. The Mormons bought up a lot of the larger parcels of land in the last few years. Not sure what that was about but it makes it harder for the rest of us to get any.
Yep, my family has a place on St. George and we spent new years there. It was great. Most of my family lives in Tally. We looked at some places in Carrabell and Apalachicola while we were there this time and last summer.
My son lives in Richmond Hill, GA close to Savannah. We really like that area to. I can't wait. I'm tired of S Fla, been down here about 30 years now and ready to go back to gods country.
Re: GF16 In The PSL
Posted: Sat Jan 10, 2015 11:00 pm
by Fuzz
Noles309 wrote:BB Sig wrote: I'm tired of S Fla, been down here about 30 years now and ready to go back to gods country.
So what part of Alaska are you planning on moving too?
Re: GF16 In The PSL
Posted: Sun Jan 11, 2015 9:45 pm
by Noles309
Re: GF16 In The PSL
Posted: Mon Jan 12, 2015 5:21 pm
by peter-curacao
Noles309 wrote:I'm tired of S Fla, been down here about 30 years
I would be happy too move there
Re: GF16 In The PSL
Posted: Tue Jan 13, 2015 7:44 am
by Noles309
peter-curacao wrote:Noles309 wrote:I'm tired of S Fla, been down here about 30 years
Ha, the grass is always greener I guess. I thought you pretty much lived in paradise
They say you can never go home but that is a lot closer for me.
Re: GF16 In The PSL
Posted: Tue Jan 13, 2015 8:52 am
by blueflood
Too funny, from where I sit I say.. "man, it would be great for all-year summers" but then I would miss the four very different seasons. Fall is the best and winter to warm up next to a roaring fire but then again, being in swim trunks soaking the rays...yep, the grass is always greener; except in winter
Re: GF16 In The PSL
Posted: Tue Jan 13, 2015 10:39 am
by peter-curacao
Noles309 wrote:Ha, the grass is always greener I guess
True
Yep the weather and water is nice, then there is:
The corruption
Bad infrastructure.
Sky high electric and water prices, about US$ 8,- per m3 (265 gallon) water and about US$ 0,40 a KWh, but for those prices long regularly power failures are included.
Because almost everything is imported no constant stock and ridiculous supermarket and shop prices (try to build a boat here)
most is closed after 5 and some of them are even closed between 12 and 14:30, can you believe that?
I can go on and on, what for a lot of you seems normal for us is pure luxury, I think that's why they invented the green rum to forget all about that
Re: GF16 In The PSL
Posted: Tue Jan 13, 2015 11:42 am
by Fuzz
Yep the grass is always greener...................
I love Alaska in the summer. 20 hours of sunlight is hard to beat. Does not matter what the clock says you can go and do.
Downside is 6 months of winter and 5 hours of daylight this time of the year.
Sorry about the hijack
Re: GF16 In The PSL
Posted: Tue Jan 13, 2015 1:57 pm
by Noles309
blueflood wrote:Too funny, from where I sit I say.. "man, it would be great for all-year summers" but then I would miss the four very different seasons. Fall is the best and winter to warm up next to a roaring fire but then again, being in swim trunks soaking the rays...yep, the grass is always greener; except in winter
Yeah, thats one thing I miss bad is the definite change of season you get in N FL. That and the people are way more laid back and less traffic and....and...
Fuzz wrote:Yep the grass is always greener...................
Its all good man, not much building going on here. The Mrs. and I will be up your way in Aug. taking an Alaska cruise for our 25th. I'm really looking forward to it. Who knows, maybe I will want to move up there after all
Re: GF16 In The PSL
Posted: Tue Jan 13, 2015 6:06 pm
by Fuzz
If you are going to be any where close to the Kenai peninsula let me know. It would be nice to meet more builders from this site.
Re: GF16 In The PSL
Posted: Tue Jan 13, 2015 7:24 pm
by Aripeka Angler
Noles309 wrote:The Mrs. and I will be up your way in Aug. taking an Alaska cruise for our 25th. I'm really looking forward to it. Who knows, maybe I will want to move up there after all
Excellent, hopefully you will have some time to explore when you are not on the boat.
The fishing is pretty dang good there!
You actually might start to think about moving there once you see Alaska
Re: GF16 In The PSL
Posted: Tue Jan 13, 2015 9:03 pm
by Cracker Larry
All I've got to do is look at the clothes you are wearing in the summertime to know that I'm not moving there, or probably even visiting
Re: GF16 In The PSL
Posted: Wed Jan 14, 2015 10:44 pm
by BB Sig
I've always dreamed of going hunting either in Alaska or Canada. Short trip and never the thought of staying longer than a week or two.
Re: GF16 In The PSL
Posted: Thu Jan 15, 2015 7:46 am
by Noles309
Aripeka Angler wrote:Noles309 wrote:The Mrs. and I will be up your way in Aug. taking an Alaska cruise for our 25th. I'm really looking forward to it. Who knows, maybe I will want to move up there after all
That is the plan. There are a couple of fishing excursions I'm looking at
Fuzz wrote:If you are going to be any where close to the Kenai peninsula let me know. It would be nice to meet more builders from this site.
Will do.
Re: GF16 In The PSL
Posted: Sat Jan 17, 2015 7:36 pm
by Noles309
Re: GF16 In The PSL
Posted: Sun Jan 18, 2015 7:24 am
by Walkers Run
Very nice Gary! I think you've got working with carbon fiber down.
Re: GF16 In The PSL
Posted: Sun Jan 18, 2015 8:26 am
by topwater
Nice work
Is the carbon fiber a wide tape or are you cutting it from a wide roll ?
Re: GF16 In The PSL
Posted: Sun Jan 18, 2015 9:15 am
by Noles309
Thanks guys. The shafts are made with CF "sleeve". Its really pretty easy to work with on smaller things like I have done. Something like a pushpole, mast, multiple curves and tapers would be quite a challenge. Its just a matter of figuring it out I guess. They were fun little projects.
BBC does sell some CF sleeve, but I needed smaller diameter that they dont stock.
http://www.sollercomposites.com/composi ... eeves.html
Couple of right side up pics:
Re: GF16 In The PSL
Posted: Sun Jan 18, 2015 10:21 am
by Cracker Larry
Very nice work on the carbon fiber. I need to learn more about that.
Re: GF16 In The PSL
Posted: Sun Jan 18, 2015 11:33 am
by Irish
Nice job on the carbon fiber tiller extension. Gotta make me one ....now if I can just find me a supplier for the tubes in Canada
On another note going back on your postings I noticed you where making some mods to your trailer for extra support at the bow. Could you post a few pictures. (close up if Possible) I need to do something on my trailer as I also have a Gf16 though after looking at your quality of work I feel like burning mine.
Thanks.
Re: GF16 In The PSL
Posted: Sun Jan 18, 2015 12:00 pm
by Noles309
Thanks Irish, Soller will ship worldwide. I bought the bunk from here :
http://www.etrailer.com/Boat-Trailer-Pa ... 27850.html
You could make one easy enough, but I was feeling lazy
I bought the flat bow stop from them as well.
Re: GF16 In The PSL
Posted: Sun Jan 18, 2015 12:11 pm
by Irish
Thanks a heap
Re: GF16 In The PSL
Posted: Sun Jan 18, 2015 5:17 pm
by Jim_Davisson
Fantastic looking work!
Re: GF16 In The PSL
Posted: Sun Jan 18, 2015 9:08 pm
by Noles309
Cracker Larry wrote:Very nice work on the carbon fiber. I need to learn more about that.
Thank you
. Nothing to it for a man of your skills.
Jim_Davisson wrote:Fantastic looking work!
Thanks. I'm looking forward to seeing what you do with that PH18
Re: GF16 In The PSL
Posted: Fri Jan 23, 2015 9:00 am
by Noles309
Re: GF16 In The PSL
Posted: Fri Jan 23, 2015 9:15 am
by Cracker Larry
Sweet
That's got to one of the nicest GF16s that I've seen. Fine job
Re: GF16 In The PSL
Posted: Sat Jan 24, 2015 10:10 am
by Noles309
Cracker Larry wrote:Sweet
Thank you sir
Re: GF16 In The PSL
Posted: Sat Jan 24, 2015 7:08 pm
by Noles309
Re: GF16 In The PSL
Posted: Sat Jan 24, 2015 8:13 pm
by TRC886
Don't let SWMBO see that platform...she will want it for a coffee table
I'm not going to argue about the carb, but
I'd try it first, just to see what happens. If it runs fine, and gasoline is not pouring out of it, I'd run it
Re: GF16 In The PSL
Posted: Sat Jan 24, 2015 8:22 pm
by Cracker Larry
Really nice work
Just a comment on that light mounted on the platform. It would not be legal in GA or SC, probably FL or in any federal waters. It has to have an unobstructed viewing field of 360 degrees, which means it has to be higher than the motor. A good option in a small boat, if you don't want it on a taller mast is to mount it on top of the motor cowling. Your setup will get you a ticket here. Could get you run over too
Re: GF16 In The PSL
Posted: Sat Jan 24, 2015 8:24 pm
by Noles309
TRC886 wrote:Don't let SWMBO see that platform...she will want it for a coffee table
HAHA, already did bro. Gss was pouring out like a mofo
Re: GF16 In The PSL
by TRC886
In NC, it must be 3 meters higher than the bow light.
Edit: That should be 1 meter
Re: GF16 In The PSL
Posted: Sat Jan 24, 2015 8:26 pm
by Cracker Larry
I think that is 3 feet, not meters.
Re: GF16 In The PSL
Posted: Sat Jan 24, 2015 8:27 pm
by Noles309
Cracker Larry wrote:Really nice work
You are right. Its not legal here either. I'm pretty sure its not legal on the motor here either. I will change it out eventually. I was originally going with a taller platform.
Re: GF16 In The PSL
Posted: Sat Jan 24, 2015 8:39 pm
by TRC886
Ah well
Such is life. I've never been much of a carburetor man, and I usually take it to a local independent mechanic. He won't charge more than an hour of labor...which is cheaper than me messing it up
Re: GF16 In The PSL
Posted: Sat Jan 24, 2015 8:50 pm
by TRC886
Cracker Larry wrote:I think that is 3 feet, not meters.
If it were only so simple. I'm like you...I think in feet and inches, not meters.
http://www.ncwildlife.org/Portals/0/Boa ... gRules.pdf
Vessels Less Than 12 Meters (39.4 ft.) In Length
Vessels or sailboats using power: the lighting arrangement in
figure 1, 2 or 3 may be used.
Sailboats using sail alone: the lighting arrangements in figure
4, 5 or 6 may be used.
The white masthead light must be at least 1 meter (3.3 ft.)
higher than the colored sidelights.
Edit: I could be mis-reading this.
Edit 2: That was supposed to have been 1 meter, not 3
I have changed that post too.
Re: GF16 In The PSL
Posted: Sat Jan 24, 2015 9:54 pm
by Cracker Larry
Feet, meters, who cares
I seldom even turn on lights at night unless I'm in a high traffic area. My night vision is much better without light glare, but when I use them I want them out of my field of vision, way overhead preferably.
Re: GF16 In The PSL
Posted: Sun Jan 25, 2015 7:51 am
by peter-curacao
Wow that boat is very nice
great job
About the light you can exchange the aluminum tube for a longer one just lengthen the wires, I know this because officially mine is to low also, got away with it though
Re: GF16 In The PSL
Posted: Sun Jan 25, 2015 8:04 am
by Walkers Run
Boat's looking great Gary!
On a boat without a top I lIke a removable light with a tall mast. Just keep it stowed until you need it.
Re: GF16 In The PSL
Posted: Sun Jan 25, 2015 10:02 am
by Noles309
Cracker Larry wrote:Feet, meters, who cares
Same here, I doubt I will be using it much at night anyway which was why I wasn't too worried about it right now.
peter-curacao wrote:Wow that boat is very nice
great job
Thanks Peter. That is probably what I will do. I will have to move it though. If its too long to fold down it will be in the way on the platform.
Walkers Run wrote:Boat's looking great Gary!
Thanks Bob. I'm out of stuff to do now, it's time to tackle the carb. I put it off as long as I could.
I did't want you to think I was trying to keep your carb cleaning bucket.
I'm kind of OCD with stuff though. I like to be completely done with one thing before I move onto the next and the motor is the very last thing I reckon.
Re: GF16 In The PSL
Posted: Sun Jan 25, 2015 11:03 am
by Cracker Larry
I wish
I've got opposite OCD, I get tired of doing one thing and move to another, then back again, depending on my mood. Still got a half dozen unfinished things to finish
Speaking of which, it's warmed up enough for me to go to work. Steering time.
Re: GF16 In The PSL
Posted: Sun Jan 25, 2015 11:29 am
by Noles309
Cracker Larry wrote: the motor is the very last thing I reckon.
I wish
HA, the motor is for me anyway.
Whatever works right?
It still feels pretty cool here and the boats in the shade now that the oak tree bloomed back out. I'm sure my blood is thinner than yours though.
Re: GF16 In The PSL
Posted: Sun Jan 25, 2015 11:55 am
by Aripeka Angler
Awesome job Gary
Can't wait to see some on water photos.
On the light mast deal, Craig put his up on top of the motor cowl. I think it looks nice up there IMHO...
Re: GF16 In The PSL
Posted: Sun Jan 25, 2015 5:42 pm
by Noles309
Aripeka Angler wrote:Awesome job Gary
Thanks Richard. That might be the best way to go, but I swear Iv'e read somewhere that is not legal either. I'll do some research.
Re: GF16 In The PSL
Posted: Sun Jan 25, 2015 7:47 pm
by Cracker Larry
It is legal as long as it is taller than anything that may obstruct the view in 360 degrees. If you were to mount this same light on the engine cowling I don't think you would have any legality problems at all.
Re: GF16 In The PSL
Posted: Sun Jan 25, 2015 8:28 pm
by Noles309
The Florida statute on vessel navigational lights defers to the USCG regs:
Recreational vessels are required to display navigation lights between sunset and sunrise and during periods of reduced visibility (fog, rain, haze, etc.). The U.S. Coast Guard Navigation Rules specify lighting requirements for every description of watercraft
USCG Regs:
For power-driven vessels less than 39.4 feet (12meters) in length, the
masthead or all-round white light must be at least 3.3 feet (1 meter)
above the sidelights .
In my case, that makes the cowling mount illegal....Gonna have to get a 3' pole I guess ifn I want it to be legal... I may just put it on the motor and live dangerously
Re: GF16 In The PSL
Posted: Sun Jan 25, 2015 8:51 pm
by Cracker Larry
I'd carry a damn flashlight and not worry about it too much. I never put lights on my GF16 and often ran it at night. The law doesn't expect much out of small boats, just be seen when you need to. Put it on the cowling. A pole sticking 3' up in the air would be unacceptable to me, and I'd bust it pretty quick too.
Re: GF16 In The PSL
Posted: Sun Jan 25, 2015 10:37 pm
by Noles309
Yeah, I'm not too worried about it. I have a killer flashlight (Jetbeam) and a QBeam. FWC is very scarce around here around here anyway
Re: GF16 In The PSL
Posted: Tue Jan 27, 2015 8:53 am
by cottontop
Gary your boat looks great!!!!! I haven't followed your build very closely(my fault). You did a wonderful job. You are going to love her. John
Re: GF16 In The PSL
Posted: Sat Jan 31, 2015 11:19 am
by Noles309
cottontop wrote:Gary your boat looks great!!!!! I haven't followed your build very closely(my fault). You did a wonderful job. You are going to love her. John
Thanks John!
I got the under pad for the SeaDek this week and installed it on the cooler seat and back rest. I got the underpad from Hydroturf and its 1" thick. It was pretty hard to cut because its so thick. It looks ok I think, but not great. I kind of wish I had gone one size thinner, 11/16" would have been easier to cut clean. Anyway, it looks pretty good and will make a good, durable, no maintenance seat pad.
I'm going to attempt the carb today or tomorrow, there is virtually nothing else left to do.
Re: GF16 In The PSL
Posted: Sat Jan 31, 2015 11:55 am
by Noles309
Deleted
Re: GF16 In The PSL
Posted: Sat Jan 31, 2015 12:55 pm
by gonandkarl
Hallo Noles,
I followed your build all the time and I think you built the most beautiful GF16.
As I am starting to play around with glassfibre and carbon sleeves to make myself a 3 m long boom and yard for my chinese chung rig I want to ask you a question.
How many layers of the carbonsleeves did you put on top of eachother for these legs and tiller extension. It might help me to decide how I will carry on.
My plan is 2 glassfibre sleeves followed by 4 carbon sleeves for stiffness.
Greetings from Karl ( Austria ) at minus 3 deg Celsius and snowing, so the boatbuilder is in the warm house and tossing around all the plans in the head.
Re: GF16 In The PSL
Posted: Sat Jan 31, 2015 11:10 pm
by Noles309
Hello Karl and thanks. It was 70 degrees here today, sorry
Your plan sounds pretty good. I used 6 layers as well. I used the 50% carbon/50% FG biaxial sleeve. It is very stiff, strong and light. The way you plan would be even stronger I believe with the 100% carbon sleeve.
I made a mistake on the grab bar as it was my first attempt. I only used four layers and it has some flex to it when mounted and you put some good force on it. I am going to make some braces for it. Live and learn. They were fun projects.
Good luck and post some pics when you get started.
I started the carb rebuild this afternoon. Man, you have to practically disassemble the top half of the engine to get the carb off of this thing
I got it all torn apart, cleaned (It was a real mess inside, I'm glad I got the rebuild kit), replaced the rebuild parts and got it back together. Tomorrow I'll put it back on the motor, put all that back together and see what happens. I did find a wire with the insulation skinned/melted off with some heavy corrosion on it. It was almost corroded in two it was resting on the intake manifold. I also dropped a teeny tiny clip and spent over an hour looking for it
Re: GF16 In The PSL
Posted: Sun Feb 01, 2015 4:11 am
by gonandkarl
Hallo Noles,
Thank you very much for the building info about how you did the GF/Carbon pieces. I will start soon with the boom because I can build it in my cellar ( 17 degree Celsius ) away from the Winter weather. I just visit the boat in the cold shed at least once a day just to look at the beauty. ( as one says in the eye of the beholder )
I wish You all the luck with your carburetor rebuild. Thats why I am building a sailingboat because I am definitely not mechanicly gifted to work with engines. Last time I did that not very succesfully in the early seventies on my then already 10 Year old Ford Anglia car engine. I worked on it for weeks and scrapped it after that only to buy myself afterwards only new cars.
Re: GF16 In The PSL
Posted: Mon Feb 02, 2015 8:34 am
by Noles309
OK motor gurus, the carb rebuild is done. That all went pretty smoothly.
So, I got it all done and was trying to pump up the primer bulb and it wouldn't pump up. Its new and I knew it worked because I had tried it just to see if I could get the motor running about a month ago and gas was pouring out of the motor.
The motor had sat for about 2 years according to the guy I bought it from.
I'm thinking there was a bad fuel line inside the cowling or something, there was one cracked around the barb on the fuel pump so I temp fixed it. Tried it again and no go. Pulled the lines apart in the various unions and there was air going through the line when I pumped it.
I'm thinking wtf is going on? There was a full 3 gallon tank in the bow. I go and pull the tank....fricking empty. The tank was strapped down there was no fuel in the boat and there was no fuel on the ground. The carb was full when I pulled it off. I check the oil and there was fuel in it of course. I drained it and there was about 2 quarts probably. The crankcase holds 1.2. My question is where the hell did all that fuel go? No way it evaporated that fast. It didn't noticeably leak anywhere and its in my driveway I would have noticed. Did someone siphon it out and not spill a drop? That would be kind of hard to do without pulling the tank out. Then you put it back and strap it back down? Why not just take the tank?
I don't understand....obviously.. Anyone got any ideas?
Re: GF16 In The PSL
Posted: Mon Feb 02, 2015 8:37 am
by Cracker Larry
Somebody stole your gas. Got a teenage son with a car?
Re: GF16 In The PSL
Posted: Mon Feb 02, 2015 8:45 am
by Noles309
Cracker Larry wrote:Somebody stole your gas. Got a teenage son with a car?
Thats really the only thing that makes sense. I do have a 19 year old at home, I don't think it was him, not his style at all, he has a company truck, a really good job and rarely drives his own truck. The tank didn't look like it had been messed with, It was strapped down tight, which isn't that easy to do in that tight space. There are 2 three gallon tanks up there, one was empty and it was loose come to think of it...Could have been the punks that hang out at the house kitty corner to us, I did get in their ass awhile back for driving like idiots up and down the street...idk.
Re: GF16 In The PSL
Posted: Sun Feb 08, 2015 4:27 pm
by Noles309
Re: GF16 In The PSL
Posted: Sat Feb 14, 2015 9:11 pm
by Noles309
Re: GF16 In The PSL
Posted: Sat Feb 14, 2015 10:28 pm
by Noles309
Here is some video my wife took, she is a dork as you can tell....
and so am I, I haven't used a tiller since I was a kid and it shows
It seems like there is a lot of spray out the back. It does have a Doelfin on it and I thought about taking it off to see if its needed.
You can kind of hear what I was talking about with the motor in the last two videos. The sound doesn't really come through that well though.
https://www.youtube.com/watch?v=AZUwB5Yi63o
https://www.youtube.com/watch?v=F8ETKZGoFUo
https://www.youtube.com/watch?v=-vTg5p1ziIg
https://www.youtube.com/watch?v=xnYLF1lrlVI
https://www.youtube.com/watch?v=RsWl4P1aK5A
https://www.youtube.com/watch?v=QlqM9SR1WL0
https://www.youtube.com/watch?v=364EPuf4P3E
Re: GF16 In The PSL
Posted: Sat Feb 14, 2015 10:46 pm
by Cracker Larry
Very nice job
We splashed on the same day Did you drink rum? We did
Re: GF16 In The PSL
Posted: Sat Feb 14, 2015 11:32 pm
by Noles309
Cracker Larry wrote:Very nice job
HAHA, We had a little of everything, some beer with our mahi sandwiches at a place by the ramp then sangria and margarita's at the mexican joint we had supper at.
Re: GF16 In The PSL
Posted: Sun Feb 15, 2015 6:05 am
by Aripeka Angler
Congratulations on the splash
It's a great feeling isn't it?
Re: GF16 In The PSL
Posted: Sun Feb 15, 2015 7:50 am
by Walkers Run
Congratulations Gary. Such a cool boat!
Re: GF16 In The PSL
Posted: Sun Feb 15, 2015 9:36 am
by topwater
The boat looks like a flats fishing machine , nice setup i like the layout
Re: GF16 In The PSL
Posted: Sun Feb 15, 2015 9:39 am
by willg
Congratulations, Gary! Great looking boat.
Re: GF16 In The PSL
Posted: Sun Feb 15, 2015 9:57 am
by Fuzz
I bet you are one happy man! Tons of work and now the pay off. That thing looks like it really scoots for only having 20 HP. Plus it sounds like on the vidio your wife is happy with the boat and that is more than half the battle
Re: GF16 In The PSL
Posted: Sun Feb 15, 2015 10:21 am
by Noles309
Thanks for all the comments guys. It means a lot, especially after seeing some of ya'lls work.
Yes Fuzz she is happy with it and proud of me. She has been very supportive of the time and $$ I've spent on it. She has posted it all over her facebook, I don't do facebook
Everyone that sees it seems to like it. I got several comments at the ramp, I would just say say thanks as I'm really not one to brag, but the little woman would say he built it himself and that would start a discussion. I didn't think I was ever going to get it in or out of the water. But thats a good thing I guess
I am really happy with it.
I did manage to scratch up the Gatorglide good on some rocks while trying to get those pics with the boat by itself, with the wind and some a-hole ripping by us at at 30 while it was staked out. Its real slick but it doesn't have the abrasion resistance they claim (or I was expecting too much). Should have just went with graphite and saved some cash.
The motor issue is going to bug me though anyone got any ideas?
A mechanic is the absolute last resort for me
Finally, Bob I need to get with you and return your carb cleaning rig.
Thanks again all.
Re: GF16 In The PSL
Posted: Sun Feb 15, 2015 5:07 pm
by bigphillet
So cool. I hope mine looks 1/10th as nice. Did you check compression?
Re: GF16 In The PSL
Posted: Sun Feb 15, 2015 5:17 pm
by Noles309
bigphillet wrote:So cool. I hope mine looks 1/10th as nice. Did you check compression?
Thank you. I have not. I need to get a gauge and I'm going to get one of those Tiny Tachs to check rpm's. I can live with its current performance, 25 feels plenty fast in the boat, but it will be one of those nagging things knowing me. I won't be able to leave it alone.
Re: GF16 In The PSL
Posted: Sun Feb 15, 2015 5:21 pm
by Steven
Congrats. Great looking boat. Sounds like the rev limiter on my little Nissan 15HP. Definitely need a tach to confirm.
Re: GF16 In The PSL
Posted: Sun Feb 15, 2015 5:42 pm
by Fuzz
Gary if you are going to use a tiny-tac make sure and read the instructions well. I know us men do not like doing that
but it is easy to get the wrong setting and then you are being lied to. Ask me how I know
Re: GF16 In The PSL
Posted: Sun Feb 15, 2015 7:52 pm
by Noles309
Fuzz wrote:Gary if you are going to use a tiny-tac make sure and read the instructions well. I know us men do not like doing that
Yeah Iv'e heard those tachs are hard to get dialed in right on 4 strokes.
Thanks Steven.
Re: GF16 In The PSL
Posted: Sun Feb 15, 2015 8:04 pm
by justin_dwyer
That looks awesome Noles. Great work, now go and have some fun!!
Re: GF16 In The PSL
Posted: Sun Feb 15, 2015 9:53 pm
by Jim_Davisson
Noles, looks like you have two shops in your area that repair props. Around here $30-$50 will get an aluminum prop of that size fixed (missing chunks welded back in if needed, balanced and repitched) usually an aluminum prop can be bent up or down 1-1½ degrees pitch and it's typically no extra cost to have that done when they repair it. If it's a stainless prop one can be "labbed" (balanced, repitched and sharpened) around here, its around $125 on up but only on very minor repitching & repairs are always extra with stainless. I'm pretty sure your high speed issue isn't the prop but its always nice to have a level playing field to troubleshoot from.
Edit: I misread and thought it was a 30 HP, so it likely has an aluminum prop which is more economical to fix
Re: GF16 In The PSL
Posted: Sun Feb 15, 2015 11:33 pm
by TRC886
Great looking outfit
You've got a right to be proud of it, but don't get a hurry at the ramp
I don't know about your "rev limiter". On mechanical engines, a governor will restrict airflow into the engine, limiting the RPM's. I believe that electronic engines work similarly. OTOH: If your Chevy gets stolen, On-Star can kill about half of the cylinders; and I've heard that if you drive your Corvette over about 100 MPH, it'll start missing until you slow down
Have you checked the timing
Where is the cavitation plate in relation to the bottom of the hull? That spray you refer to may be coming from the motor being mounted too low on the transom. I know on my boats, if the cav plate is below the hull, it throws excess spray, similar to what yours is doing.
Re: GF16 In The PSL
Posted: Mon Feb 16, 2015 8:08 am
by Noles309
TRC886 wrote:Great looking outfit
Thank you
I don't have a timing light. I'll have to take it somewhere for that
The plate is around 1/2"-3/4" above the bottom after measuring again. I thought I built the transom up so it would be 1" up
. Hard to get a good measurement. I think its the doelfin making all the spray. With the thickness of the doelfin it is level and maybe slightly below at the rear depending on motor tilt. The motor is pretty level, it is set in the third hole. I will take it off and try it. I had read they are good for these boats and it came with the motor so I left it on.
I do have a jackplate that I built, but I was advised not to use it.
Re: GF16 In The PSL
Posted: Mon Feb 16, 2015 8:57 am
by BB Sig
Great looking boat! Congrats. You looked might happy.
Re: GF16 In The PSL
Posted: Mon Feb 16, 2015 9:44 am
by wseibert
Congrats on the launch!
Re: GF16 In The PSL
Posted: Mon Feb 16, 2015 1:57 pm
by gonandkarl
Congratulations on launching your beautiful boat. I had a look at all your videos and I loved them. Still cant get over it that some of you guys build your boat in just 1 Year, it just motivates me to work harder on my boat that I can splash it maybe still at the end of this summer.
Re: GF16 In The PSL
Posted: Mon Feb 16, 2015 9:14 pm
by TRC886
Noles309 wrote:I don't have a timing light. I'll have to take it somewhere for that
If you have a service manual, you may not need a timing light. The manual for my 1970 Merc details how to time the motor statically. If you successfully rebuilt your carb, with all those tiny parts and adjustments, static timing the motor will be a piece of cake
Re: GF16 In The PSL
Posted: Mon Feb 16, 2015 10:06 pm
by Noles309
TRC886 wrote:Noles309 wrote:I don't have a timing light. I'll have to take it somewhere for that
Unfortunately the manual is lacking. It helped with tearing down and reassembling the carb, but there is no trouble shooting help or any real instruction on anything. It pretty much assumes you are a dealer mechanic and already know what you are doing...
Thanks for all the kind words.
Re: GF16 In The PSL
Posted: Mon Feb 23, 2015 2:38 pm
by osotexan
Your boat is awesome! I really like the leaning post and tiller extension. I've been thinking about a similar set up for mine. You have kept me inspired through the build. We started construction close to the same time, see what a real job does to one's funtime? Can't wait for retirement.
Great job Noles!
Re: GF16 In The PSL
Posted: Mon Feb 23, 2015 3:13 pm
by Noles309
Haha. Thanks, you are closing in though.
Re: GF16 In The PSL
Posted: Sat Feb 28, 2015 6:00 pm
by Noles309
Well, I got the Tiny Tach and installed it. The plan was to test it today, instead it rained 4" and tomorrow isn't looking good either...
maybe next weekend
Re: GF16 In The PSL
Posted: Sun Mar 01, 2015 12:03 am
by Fuzz
Gary,
Just an idea but maybe you can put it on the muffs and see what it reads at idle. This should at least tell you if you have it set up right or not. Better than learning that after you get it in the water. I still can't believe how well it runs with a 20hp four-stroke on it.
Re: GF16 In The PSL
Posted: Mon Mar 02, 2015 8:47 am
by Noles309
Fuzz wrote:Gary,
Yep, got it set up. Should have taken it out as it was really nice. a tad windy, but was "persuaded" to do other stuff
Re: GF16 In The PSL
Posted: Mon Mar 02, 2015 2:57 pm
by Fuzz
It is simply amazing how the "other stuff" can become the must do thing.
When my Dad was 83 I asked him for some advice. I wanted to know how old a man had to become before a woman was no longer running his life. Dad said he was not sure but he did know it was more than 83
Re: GF16 In The PSL
Posted: Wed Mar 04, 2015 12:43 pm
by Phantom_22
Beautiful build!
I just acquired a free 20hp Merc with less than 10hrs...and I'm trying to decide what to put it on.
I live on the water near Galveston, and own a 23' Ranger Bay. A nice little skiff would be great for the marshes around here.
I bought PH22 plans years ago when they first came out, and I thought I could do anything! Life, family, work, etc has long since created a time issue...so, needless to say, my PH22 plans have been in a box for years. I may actually be able to complete a smaller one, though! This thread is great motivation!
Re: GF16 In The PSL
Posted: Wed Mar 04, 2015 12:54 pm
by Noles309
Phantom_22 wrote:Beautiful build!
Thank you!
That was why I built this skiff first. Another bigger boat is definitely in my future. That 20 is perfect for this boat IMHO.
Re: GF16 In The PSL
Posted: Fri Mar 06, 2015 10:31 pm
by osotexan
Gary I'm really interested in your leaning post. I'm thinking of integrating more than just a a "grab rail". I would like to install basic electronics, minor tackle "hanging" and a drink holder. If you were to do it all over again what would you change or suggest. I'm thinking go drawing something up for one of the many aluminum fabricators here locally. I plan on piloting my boat in the exact manner you are doing yours.
I give thanks for all who have gone before me. Great job!!!!
Re: GF16 In The PSL
Posted: Sat Mar 07, 2015 8:48 pm
by Noles309
osotexan wrote:Gary I'm really interested in your leaning post. I'm thinking of integrating more than just a a "grab rail". I would like to install basic electronics, minor tackle "hanging" and a drink holder. If you were to do it all over again what would you change or suggest. I'm thinking go drawing something up for one of the many aluminum fabricators here locally. I plan on piloting my boat in the exact manner you are doing yours.
Thanks. My bar does have a gps/fishfinder, led, cupholder and two rod holders mounted to it. Some things I would change would be making the shelf more like a dashboard with sides so I could mount the switch panel to it instead of the rear frame. On the sides, I would mount the nav lights like you see on some skiffs instead of cutting holes in the hull for shark eye lights. I would also just glass it to the mid seat frame and saved a lot of time and work fabbing the flanges to make it removable, which I will most likely never do.
Good luck.
Lights on the console:
Re: GF16 In The PSL
Posted: Sat Mar 07, 2015 9:12 pm
by osotexan
Thank you for the reply Gary.
So many things to plan. You have given me some great insight.
I'm thinking of anchoring it to the section of the decking that meets just forward of the "cockpit". I really don't want to attach it to the floor of the boat.
Again so much to consider, that's whar so great about building our own boats.
Re: GF16 In The PSL
Posted: Sat Mar 07, 2015 11:20 pm
by Matt Gent
Curious if you got anywhere with sorting out the tach.
I've got a new 2015 Suzuki DF30, and put on a Hardline hour/tach:
http://www.amazon.com/gp/product/B000FO ... UTF8&psc=1
According to my manual, the engine idles at 850 +/-50. On the hose the tach reads right around 860 when set to wasted spark (1 spark per revolution). But on the water, it is clearly reading half rpm.
So I wonder if the motor runs wasted at idle, then not above that. On the hose I can't determine a clear change point, was going to try that on the water under load. BTW I'm right down the street, motor goes on the pontoon I keep in C23.
Re: GF16 In The PSL
Posted: Sun Mar 08, 2015 12:02 am
by Noles309
Matt Gent wrote:Curious if you got anywhere with sorting out the tach.
Hey Matt,
I have not run it yet. hopefully monday. The one I got is even cheaper than that:
http://www.amazon.com/gp/product/B00ACD ... UTF8&psc=1
I had to set mine the same (1 spark per revolution) to get the correct idle on the hose at 950ish. It seemed to be working ok, no load of course, and it was showing over 4000 when I revved it pretty good. There is definitely some lag in the reading as well.
I have read online that you should use it on the bottom or center cylinder, with as little wire as possible and to wrap it as close to the plug as you can.
I did read on there that yours is for two cylinder motors. Maybe thats the problem?
Holler if you want to get together.
Re: GF16 In The PSL
Posted: Sun Mar 08, 2015 10:31 am
by Noles309
osotexan wrote:Thank you for the reply Gary.
That is basically what I did:
I reinforced the seat top in the area underneath where it is mounted. But like I said, I would just glass it to the back of the mid seat frame or hole saw the seat top and run the legs through and glue/glass it in. I have a foamed compartment under the cooler that it sets on, so I wouldn't have been securing to the bottom either. Your talking aluminum though so you're going to have to bolt it in obviously...Tough decisions I know.
I wasn't too worried about it because the only real extra expense I had was the CF. The ply was all scrap and I had the epoxy, so I was pretty much winging it. The same with the platform...
I'm sure whatever you decide will be great given the quality of your work thus far.
Re: GF16 In The PSL
Posted: Mon Mar 09, 2015 5:51 pm
by Noles309
Well its definitely prop time. I was hitting the limiter at 25 mph @ 6200 rpm's at 3/4 throttle when I took her out this afternoon. When my wife and grown son got in the boat, I was still hitting it at almost full throttle at 21 mph loaded
It has the stock, pretty beat up, 9 pitch on it now. Any prop gods out there have any ideas? 10p or 11P?
Re: GF16 In The PSL
Posted: Mon Mar 09, 2015 8:52 pm
by Cracker Larry
I'm not a prop god, but do have a right good understanding of them. If it's pretty beat up that will cost a lot of performance, and it's also out of balance which will cause damage to the shaft seals and bearings in short order. Don't run it long like that.
If you're hitting 6200 at 3/4 throttle you need a good bit more pitch, at least 2" or 3". On my GF16 with a 25, I used a 15 pitch stainless, after trying a couple. Stainless will give better performance and last a lot longer.
Re: GF16 In The PSL
Posted: Tue Mar 10, 2015 8:21 am
by Noles309
Thanks Larry. I was thinking at least 2" since I was still over-revving with a full load. I for sure won't be running it anymore until I get a replacement. Its too hard to stay off the limiter. I might should have gone with a 25hp....
Re: GF16 In The PSL
Posted: Tue Mar 10, 2015 8:58 am
I agree that it is probably not the HP but the prop. Some prop shops will let you test a prop and bring it back for exchange. I know Bobby Soles in North Palm beach did that years ago but I don;t know in PSL.
Try an 11 or even 13.
Re: GF16 In The PSL
Posted: Tue Mar 10, 2015 9:46 pm
by Noles309
Thanks Jacques. I called PowerTech today they recommended the SRT3R9PTN30 Which is a 9.5" 9 pitch (which is almost what is on it now, 9.25/9p) with more rake than stock and some cupping. I would have thought it needed more pitch, but I guess thats their business...
http://www.ptprop.com/index.php?page=sh ... &Itemid=46
Re: GF16 In The PSL
Posted: Tue Mar 10, 2015 9:50 pm
by Cracker Larry
I wish you the best, but I think it needs more pitch, even cupped and raked.
Re: GF16 In The PSL
Posted: Tue Mar 10, 2015 10:10 pm
by Noles309
Cracker Larry wrote:I wish you the best, but I think it needs more pitch, even cupped and raked.
I know right....Did you run a PowerTech prop on yours? The only other one in SS that I could find for this motor is a Solas Saturn. 9.25/11p max
http://boatpropellers.iboats.com/Tohats ... =909336304
Re: GF16 In The PSL
Posted: Wed Mar 11, 2015 9:10 am
I agree with Larry. It is strange that they recommend the same prop.
Re: GF16 In The PSL
Posted: Wed Mar 11, 2015 10:01 am
by Noles309
Yeah, I know. It's a 1/4" bigger in diameter but has more rake and it's cupped....
Re: GF16 In The PSL
Posted: Wed Mar 11, 2015 2:46 pm
by Jim_Davisson
Here's Mercurys prop finder, I've seen it quite accurate when using weight vs. RPM's with friends boats. Keep in mind any of these type things don't account for everything and can be way off too.
https://www.mercurymarine.com/en/us/pro ... #/step-one
SS is very tough to find in motors under 30hp generally. Sure sounds like you need atleast a 11-13p depending on diameter. Once you get close to the perfect, pitch sometimes the same prop pitch in a different diameter will dial it in.
Builders here might benefit from a section on the forum that gives similar bateau boats/motor size/and prop that worked best. Imagine if everyone posted under each boat style their individual results with there motor size and prop? Not wanting to hijack the thread, but a thought....
Re: GF16 In The PSL
Posted: Wed Mar 11, 2015 3:08 pm
A very good thought and I started working on that 2 weeks ago.
For some boats, I added a "reviews" section to the study plans. Look at the OD18 for example, at the bottom of the page:
http://www.bateau.com/studyplans/OD18_s ... ?prod=OD18
I have to work on the link . . .
It is a big job to go through the forum posts and find that data but I'll keep doing it.
Re: GF16 In The PSL
Posted: Wed Mar 11, 2015 5:11 pm
by Noles309
Ha, mercs prop selector gave me basically the same thing. Two choices both 9.25 dia in a 9p and 10p...go figure....
I also called a local prop shop and they recommended the same powertech prop that powertech did....
Re: GF16 In The PSL
Posted: Wed Mar 11, 2015 5:54 pm
by Walkers Run
It's possible your current prop isn't what it says it is. I've had the pitch on aluminum props changed before and did not re-stamp the prop. Stuart propeller or Bobby Soles can tell what pitch your prop is.
Re: GF16 In The PSL
Posted: Wed Mar 11, 2015 5:58 pm
Ask them if they are willing to exchange it for one with more pitch after a 30 minutes test.
When I worked for Cigarette, we did the math (and we knew the boats) but if the engines were just a little bit different, the final prop selection was done after testing. In 50% of the cases, we were close with the formulas but not perfect.
In this case, that flat bottom boat should go well above 25 mph. It is not right to redline at such a low speed.
Oops, just saw the post by Walker's Run, it makes sense.
But there is also Cracker Larrr who has experience with the same boat.
Re: GF16 In The PSL
Posted: Wed Mar 11, 2015 7:38 pm
by Cracker Larry
Mine would run about 33 mph with a medium load, 25 hp 2 stroke Merc and a 15" pitch stainless, I think it was a Michigan Wheel prop. Don't remember the exact style. Nothing radical.
Re: GF16 In The PSL
Posted: Wed Mar 11, 2015 8:36 pm
by Noles309
Walkers Run wrote:It's possible your current prop isn't what it says it is. I've had the pitch on aluminum props changed before and did not re-stamp the prop. Stuart propeller or Bobby Soles can tell what pitch your prop is.
True, I hadn't thought of that either. I talked to Blair Propeller and Marine in Stuart today. Jacques mentioned Bobby Soles as well maybe I will check with them. He is also a Powertech dealer. Powertech does offer an exchange program for a $30 restock fee. That can get expensive quick
Re: GF16 In The PSL
Posted: Thu Mar 12, 2015 11:53 am
by tech_support
Ken at Propgods is fantastic to deal with.
Re: GF16 In The PSL
Posted: Sun Mar 22, 2015 9:14 pm
by Noles309
I went with the Powertech recommended but upped the pitch to 10" over the 9" that was initially recommended and I'm glad I did. The top speed increased to 26.5 mph @ 5990 rpm and cruise at 20 mph @ 4800 rpm. If I would have went with the 9" I'm pretty sure I would have been into the limiter and that would have really pissed me off.
That was with me and the wife. I didn't run it alone. I was hoping to get closer to 30 at wot but I'm still really happy with it.
I even poled it a little today
Thanks for all of the advice
Re: GF16 In The PSL
Posted: Sun Mar 22, 2015 11:12 pm
by Fuzz
Noles,
26.5 out of a 16 foot boat with only 20 hp sure seems good to me. I bet the gas mileage is really good also. One of those run all day on a 6 gallon can type of boats.
Re: GF16 In The PSL
Posted: Mon Mar 23, 2015 8:39 am
by Noles309
Yeah Fuzz, I forgot to mention that. I have 4 1/2 hrs of running and haven't been through one 3 gal tank yet. There isn't a whole lot left in it though.
Question about fuel/water separators, I have a station that sells non ethanol fuel about 2 miles from my house and plan on only running that fuel. Would ya'll still run a fuel/water separator?
Re: GF16 In The PSL
Posted: Mon Mar 23, 2015 8:40 am
by topwater
yes
Re: GF16 In The PSL
Posted: Mon Mar 23, 2015 9:10 am
That is much better and thanks for posting the pics.
Re: GF16 In The PSL
Posted: Mon Mar 23, 2015 9:36 am
by Cracker Larry
Yes!!
Re: GF16 In The PSL
Posted: Mon Mar 23, 2015 1:25 pm
by Walkers Run
Yes to the separater!
Re: GF16 In The PSL
Posted: Mon Mar 23, 2015 7:11 pm
by cottontop
Yes! One time with water in fuel and if you don't, you will wish you had. Very low cost. Just one more type of insurance. John
Re: GF16 In The PSL
Posted: Mon Mar 23, 2015 8:06 pm
by Noles309
Sounds good gents. I will definitely follow ya'lls advice.
Re: GF16 In The PSL
Posted: Mon Mar 23, 2015 8:54 pm
by swglenn
What is a good recommendation on a fuel/water separator brand? Racor, Sierra, ?? Micron size?
Re: GF16 In The PSL
Posted: Tue Mar 24, 2015 11:00 pm
by Matt Gent
The little Racor is a quality piece and has a replaceable element. Cheapest place I found it was defender
http://www.defender.com/product3.jsp?pa ... id=1034738 for a Honda branded version. Just put one on my pontoon.
Use sealant (permatex fuel safe, I know have a lifetime supply), and the fittings need to be TIGHT to prevent air leaks.
Re: GF16 In The PSL
Posted: Tue Mar 24, 2015 11:28 pm
by Cracker Larry
I prefer this, in the stainless version
http://www.jamestowndistributors.com/us ... rator+Kits
Glass or plastic bowl filters for gasoline are frowned upon in any enclosed spaces and I'd be likely to bust it wherever it was. I like a stainless housing and a metal filter canister like an auto oil filter, 10 micron or better. This one is a Sierra. You can get replacement elements almost anywhere. All the name brands of marine engines have this same universal size filter with their name on it, and any marine supply or automotive stores like NAPA carries them. Even Walmart has them. In my shop I've got a list of all the generic part numbers of Fram, Wicks, Mercury, Yamaha, Sierra, Motorcraft...they are all about the same. Replacement elements available everywhere. Honda, maybe not so much.
Re: GF16 In The PSL
Posted: Wed Mar 25, 2015 7:54 am
by Noles309
I had looked at that Sierra one and I was undecided on getting one with the clear bowl. How often do you change the filter on those?
Thanks for the info.
Re: GF16 In The PSL
Posted: Wed Mar 25, 2015 8:28 am
by Cracker Larry
I change the element once or twice a year, and always carry a spare.
Re: GF16 In The PSL
Posted: Wed Mar 25, 2015 9:57 am
by Walkers Run
I change mine when I do the 100 hour service. Like Larry said always carry at least 1 spare.
Re: GF16 In The PSL
Posted: Wed Mar 25, 2015 1:53 pm
by Noles309
Cool. Thanks
Re: GF16 In The PSL
Posted: Thu Mar 26, 2015 9:58 pm
by Matt Gent
I have the Sierra style on my skiff (90hp); the small Racor one on my pontoon (30hp), where it is in the open. I prefer to have the sight bowl, but the big racor ones are so expensive. Elements for the Sierra one are super cheap, so just replace it often. But you have to do the pump into a glass and sit deal if you are trying to check for water.
If you go for the Sierra one, make sure to remember if you have the large or small thread filter. There are two sizes, and it stinks to buy the wrong one on accident.
Re: GF16 In The PSL
Posted: Sun Apr 05, 2015 4:45 pm
by Noles309
My son, daughter in law and the grand kids came down for Easter. We took the GF16 out for boat rides. To my surprise with 3 adults and two 60-70 lb kids I was still getting 22mph out of her at around 5700 rpm. She was a little sluggish, but still performed well with a heavy load I think. I'm really happy with this boat
Re: GF16 In The PSL
Posted: Sun Apr 19, 2015 11:00 am
by Noles309
I finally got around to getting the fuel/water separator. Does this fuel line configuration look ok? The instructions are pretty vague but it is one in and one out and for where I need to put it, this config will work the best.
Re: GF16 In The PSL
Posted: Sun Apr 19, 2015 1:13 pm
by Cracker Larry
Yes, I like that type because it gives you a choice of which way the hoses feed.
Re: GF16 In The PSL
Posted: Sun Apr 19, 2015 1:41 pm
by Noles309
Re: GF16 In The PSL
Posted: Mon May 04, 2015 12:35 pm
by mindunderwater
Been away for a while-never got a chance to say just how great that looked.
Question - how'd you feel about someone else... well 'copying' is such a bad word - let's say 'imitating' (the sincerest form of flattery
) that grab-bar / stand-up design element in their own GF16? Also - how're you finding moving around it going forward / aft? Any issues?
Re: GF16 In The PSL
Posted: Mon May 04, 2015 1:15 pm
by Noles309
No worries man. Copy away.
Its a little bit of a pain to climb over the mid seat, but I don't really do it that often so its not a deal breaker for me.
Re: GF16 In The PSL
Posted: Wed May 13, 2015 10:18 am
by mindunderwater
Plans purchased this AM. I'll put a thread up once there's something to see.
Re: GF16 In The PSL
Posted: Wed May 13, 2015 1:31 pm
by Noles309
Sweet, I'll be looking forward to it.
Re: GF16 In The PSL
Posted: Thu May 21, 2015 2:09 pm
by massimiliano
Hallo,
I'm ready to begin this boat, and I'm wondering if there is any reason not to move the middle seat forward at the joint of the side plywood ?
This means to me, have the boat more strong and more space in the back.
Does make sense ?
Thanks,
Max.
Re: GF16 In The PSL
Posted: Fri May 22, 2015 9:07 am
by Noles309
That would be a question for the designer, Jacques. I built mine as designed. I initially had thought of modifications but decided against it as it was my first build. I did fully glass the hull inside and out. That was my only deviation from the plans.
It is an awesome skiff and I love it.
Having a blast in the PSL....
Re: GF16 In The PSL
Posted: Fri May 22, 2015 11:46 am
Re: GF16 In The PSL
Posted: Wed May 27, 2015 12:36 pm
by mindunderwater
Wonder if steam-bent stock would be OK for rubrail. Spruce isn't really 'a thing' around here - have to ship it in ($!) but I can normally get Cypress and rip it down to say 1/2" or 3/4". My attempts at consistent rips on the ply were... discouraging.
Re: GF16 In The PSL
Posted: Wed May 27, 2015 1:51 pm
I never specified spruce for the rubrail. That must come from some wooden boat forum.
They love expensive hard to find wood and you are not a real man unless you own at least two bizarre saws with a japanese name.
I prefer and specify laminated strips of plywood. It is much easier to shape, it is stronger and no steam needed.
I try to stay away from steaming, the wood gets wet and you must let it dry clamped on the boat before applying epoxy.
BTW, you can probably bend that rubrail without steaming. That sheer line is almost planar (= curved in one way only).
Re: GF16 In The PSL
Posted: Wed May 27, 2015 8:35 pm
by Noles309
Thats what I used, left over 1/4" laminated in three layers per the plans. I just cut it with a skil saw and a guide I got at Lowes. I didn't feel like messing with the table saw as its buried in the shed...
http://www.lowes.com/ProductDisplay?par ... &cId=PDIO1
Re: GF16 In The PSL
Posted: Thu May 28, 2015 9:30 am
by mindunderwater
Jacques:
Spruce for me comes from the family boat building up in Southeast Alaska where it isn't nearly so hard to get. I'll take another whack with the skil saw and a 1/4" sheet from the home un-improvement store.
<Edit> I have no special love for those funky saws. I have enough trouble using the ones I've got.
Re: GF16 In The PSL
Posted: Thu May 28, 2015 9:45 am
I was joking about the wooden boat afficionados, I like to tease them but don't say that you are one of them.
Re: GF16 In The PSL
Posted: Thu May 28, 2015 10:14 am
by mindunderwater
Jacques:
Didn't figure you were. I'm too big and ugly to take anything personally anyhow
Noles - are you finding you're looking for a spot to sit for a while on longer runs?
Re: GF16 In The PSL
Posted: Thu May 28, 2015 12:31 pm
by Noles309
The mini platform is a perfect place to sit
Re: GF16 In The PSL
Posted: Thu May 28, 2015 5:59 pm
by jorgepease
she looks great! any videos of her running?
Re: GF16 In The PSL
Posted: Thu May 28, 2015 6:14 pm
by Cracker Larry
I'll say it again. That's the nicest looking GF16 that I've ever seen. Hope you bring it to the builders meet in Homassasa this fall.
Re: GF16 In The PSL
Posted: Thu May 28, 2015 7:53 pm
by Noles309
jorgepease wrote:she looks great! any videos of her running?
Thanks Jorge, just the original one from the splash day.
Cracker Larry wrote:I'll say it again. That's the nicest looking GF16 that I've ever seen. Hope you bring it to the builders meet in Homassasa this fall.
Thanks Larry. I would really like to come if only for the day. We'll see how it shakes out. I can't commit for sure yet.
Re: GF16 In The PSL
Posted: Mon Jun 01, 2015 1:05 pm
by massimiliano
Congratulations, that's a wonderful lucking boat.
I have to begin this boat in the next few days and because mine, should run in river and often shallow, I'd like to build a tunnel for the jet.
Anyone could tell me the general dimension of it ( maybe the engineer that make the project ) ?
Thanks,
Max.
Re: GF16 In The PSL
Posted: Mon Jun 01, 2015 1:30 pm
We have tunnels in some boats but as I explained in previous threads, I do not recommend it for the GF16.
The GF16 is a narrow boat and there would not be enough lifting surface left if you cut a tunnel in it.
Re: GF16 In The PSL
Posted: Mon Jun 01, 2015 1:37 pm
by Noles309
massimiliano wrote:Congratulations, that's a wonderful lucking boat.
Thanks,
Max.
Thank you. Mine easily runs in 12" and floats in 4". I guess everyone has different needs but I can't imagine needing to run shallower than that. It would make me nervous anyway.
There have been a couple of GF series boats that builders added tunnels to with less that stellar results from what I remember. I don't really think you need a tunnel with a jet anyway, but I'm no expert.
Here is a video of a GF16 jet and no tunnel.
https://www.youtube.com/watch?v=XRySvJbWrr0
GF16 Tunnel build
http://forums.bateau2.com/viewtopic.php?f=12&t=8528
GF12 tunnel build
http://forums.bateau2.com/viewtopic.php ... 2&start=10
I would make a post in the powerboat section. Jacques is more likely to see it there. Good luck
Edit: I guess we were posting at the same time Jacques
Re: GF16 In The PSL
Posted: Tue Jun 02, 2015 12:51 am
by massimiliano
This link was really helpful mostly the video.
Thanks again.
Re: GF16 In The PSL
Posted: Tue Jun 02, 2015 12:55 am
by massimiliano
What do you use to spread the epoxy on the fiberglas or the fairing epoxy on the plywood ?
Max.
Re: GF16 In The PSL
Posted: Tue Jun 02, 2015 1:00 am
by massimiliano
What kind of paint and primer have you used for the GF16?
Epoxy or normal paint?
Re: GF16 In The PSL
Posted: Tue Jun 02, 2015 8:27 am
by Noles309
massimiliano wrote:What do you use to spread the epoxy on the fiberglas or the fairing epoxy on the plywood ?
Max.
I used a 4" foam roller and a bondo spreader.
massimiliano wrote:What kind of paint and primer have you used for the GF16?
I used the System 3 primer sold here and a truck bed liner called Monstaliner instead of paint.
Re: GF16 In The PSL
Posted: Mon Jun 08, 2015 11:09 am
by Noles309
Re: GF16 In The PSL
Posted: Mon Jun 08, 2015 11:14 am
by terrulian
Just curious, is that a stick for poling?
As you can see, I'm not from around here.
Sorry about the fading.
Re: GF16 In The PSL
Posted: Mon Jun 08, 2015 11:20 am
by Noles309
Its for anchoring in shallow water like in this pic: It is a solid 3/4" fg rod with a stainless tip.
Re: GF16 In The PSL
Posted: Mon Jun 08, 2015 6:12 pm
by terrulian
Never seen one. Kinda looks like something you'd see in Asia...or Florida, I guess. Where did they originate? We have skinny water around here but also considerable chop, wind, and current so I don't think they'd be secure in this environment. From a quick web search, looks like they're mighty popular so...I'm just ignorant.
Re: GF16 In The PSL
Posted: Mon Jun 08, 2015 8:43 pm
by Cracker Larry
I carry 2 stake out sticks on my OD18, plus a push pole. Beat's the heck out of an anchor in shallow water. I've got a fixed bracket on the transom for one, and the other I put wherever I need it to keep the boat from spinning. Seldom need 2, but I like redundancy
This is a Wang bracket on the transom. Hang out with your Wang out is their motto. It works for me in anything under about 6' deep
Re: GF16 In The PSL
Posted: Mon Jun 08, 2015 8:54 pm
by Noles309
Nice, I like those brackets. Do those Wang brackets hold the stick up when not in use so you don't have to completely remove it when running?
Iv'e been flip flopping on getting one or not.
I put my anchor together from a kit available from Max Gain systems for like $36.
Re: GF16 In The PSL
Posted: Mon Jun 08, 2015 10:15 pm
by Cracker Larry
No, you have to completely remove it, but if you forget to, it's OK
The sticks are tough and I don't think you can kill them. I've tried
It would be real easy to make a collar with a wing screw to hold them up though.
They are the same fiberglass stick that's on a power pole. Aripeka Angler dug a furrow down an asphalt highway in Florida with his. It survived. Asphalt needs some patching though
Re: GF16 In The PSL
Posted: Tue Jun 09, 2015 8:23 am
by Noles309
Yeah, I remember reading about one that has an insert in the tube that will hold it up but I don't remember the brand.
Re: GF16 In The PSL
Posted: Sun Jun 14, 2015 7:57 pm
by Noles309
I think I'm finally done. I had a guy make me some snap on covers for my frame cutouts. They look ok at best. My wife says I'm too picky... But damn, when you pay someone to do something you expect at least better quality than you could do yourself.
They are almost a perfect color match though
Had her out again today in the ICW and to the inlet. It was pretty windy and kinda rough for this little gem, has me jonesing for the bigger boat already
She is an awesome skinny water river and creek boat for sure though.
Re: GF16 In The PSL
Posted: Sun Jun 21, 2015 3:20 am
by Fuzz
Hey Noles,
Are you still planning on a trip to Alaska this summer?
Re: GF16 In The PSL
Posted: Wed Jul 01, 2015 2:33 pm
by Noles309
Fuzz wrote:Hey Noles,
Yes we are and really looking forward to it.
On a boat note, I had used a supposed UV resistant epoxy on my carbon pieces......not so much on the UV.
It had started turn gray so I painted it all black. Once I painted it, the grab bar and tiller extension got pretty damn hot, funny how that works
Anyway, I googled rope wrapping and learned how to do spiral hitching/coxcombing and wrapped the tiller extension and grab bar in OD 550 cord.
Maybe now I'm done....who knows....
I did order some plans last week though....
Re: GF16 In The PSL
Posted: Wed Jul 01, 2015 3:01 pm
by osotexan
That looks sweet Gary!
Re: GF16 In The PSL
Posted: Wed Jul 01, 2015 3:26 pm
by Cracker Larry
I really like that
I need to do it on my steering wheel, for when my hands are wet and salty and fishy. You sure have done a fine job on that boat!
Re: GF16 In The PSL
Posted: Wed Jul 01, 2015 4:43 pm
by Noles309
Thanks guys. Its pretty easy, time consuming though. I used about 200' to do those two things and 2 sets of cooler handles. I also made an extended kill lanyard out of it. The grab bar alone took 99 1/2 feet.
Re: GF16 In The PSL
Posted: Wed Jul 01, 2015 5:13 pm
by gonandkarl
Hi,
Looks beautiful and makes a lot of sense on a black bar.
Now that you are finished you mentioned you ordered plans.
Let us nosy guys know what we can expect as your next boat build.
I am looking forward to follow it.
Re: GF16 In The PSL
Posted: Wed Jul 01, 2015 5:31 pm
by Walkers Run
Very cool Gary! What a great idea
Re: GF16 In The PSL
Posted: Wed Jul 01, 2015 5:58 pm
by terrulian
Very fine job on the fancy rope work. Very fine.
How do you hide the end?
Re: GF16 In The PSL
Posted: Wed Jul 01, 2015 6:33 pm
by Noles309
Thanks guys.
I'm going to build a SC16 for my son.
terrulian wrote:Very fine job on the fancy rope work. Very fine.
Tony, you can see the end in pic 2. I need to melt it in a little more. It was windy today and I was having trouble getting the lighter started.
Re: GF16 In The PSL
Posted: Sat Jul 04, 2015 12:19 am
by jorgepease
wow, that is sweet!!!
Re: GF16 In The PSL
Posted: Sat Jul 04, 2015 9:22 am
by bigphillet
Very nice! I hope mine comes out half as nice. Happy 4th!
Re: GF16 In The PSL
Posted: Sun Jul 05, 2015 11:04 am
by mindunderwater
Noles -
Nice job on the para cord wrap. I seem to remember this conversation with you a while back
Looks great!
Re: GF16 In The PSL
Posted: Sun Jul 05, 2015 2:59 pm
by Noles309
mindunderwater wrote:Noles -
Looks great!
It was fine before I had to paint it. The uv resistant epoxy I used didn't work as advertised. Once I painted it, it got hot.
Re: GF16 In The PSL
Posted: Fri Jan 15, 2016 1:37 pm
by 94'325is
Just read through the whole thread, great job on the build, documentation and finish. I've been between several boats to build next and the FS14 was the first on the list. After reading your thread, watching the videos and then looking at other GF16s I'm starting to lean towards it more and more. How does the boat handle a chop? I'm not concerned with it bouncing around but I'd like to avoid pounding and being soaked if possible. Also now that you've presumably used it at least a few times since you launched what are your overall impressions? What would have you done different or the same?
Re: GF16 In The PSL
Posted: Sat Jan 16, 2016 9:07 pm
by Noles309
Its a great boat. I love it. It runs pretty dang dry and Iv'e had it in some sloppy stuff in the Indian River (big water down here). If you slow down in a chop you will have no worries, if you don't, she will pound pretty good. If you spend most of your time in bigger water, its probably not the boat for you.
Things I would do different: Rig it for a trolling motor, use epoxy graphite on the bottom instead of Gatorglide, make the back deck flush with the top of the rubrail or drill some drain holes in the transom (It holds water where the transom meets the deck) and thats about it.
Things I don't like about it: Only one, the mid seat. Its wide at 24" and a pita to climb over.
Its perfect for what I do 90% of the time which is creeks, smallish rivers and mangrove tunnels.
Re: GF16 In The PSL
Posted: Sun Jan 17, 2016 6:59 am
by jorgepease
why not the Gator Glide is it scratching up? Mine has held up pretty good but haven't really beached her that much
Re: GF16 In The PSL
Posted: Sun Jan 17, 2016 7:34 am
by Noles309
For what it costs, I don't think its really worth it. It doesn't seem as slick as it did and I dont think its really held up all that well. I have had to touch up places that went through to the primer. They show those airboats running on land with the stuff. I figured it would be indestructible in the water....
Re: GF16 In The PSL
Posted: Sun Jan 17, 2016 12:33 pm
by jorgepease
I'l keep an eye on mine, so far no issues. Was glad you didn't say it started to blister after a week in the water or something like that, haven't tried that to see what would happen if I did that.
Re: GF16 In The PSL
Posted: Mon Jan 18, 2016 9:08 am
by 94'325is
Noles309 wrote:Its a great boat. I love it. It runs pretty dang dry and Iv'e had it in some sloppy stuff in the Indian River (big water down here). If you slow down in a chop you will have no worries, if you don't, she will pound pretty good. If you spend most of your time in bigger water, its probably not the boat for you.
Things I would do different: Rig it for a trolling motor, use epoxy graphite on the bottom instead of Gatorglide, make the back deck flush with the top of the rubrail or drill some drain holes in the transom (It holds water) and thats about it.
Thanks for the report, I'm glad to hear you're liking it. My local waters are lakes, St Johns River and IRL/ML. I was really looking at the FS14 w/ a flat sole since I like the open layout but having a center bench length might be worth it for 2 extra feet of length, especially with your reports of liking it so much. I wish there was a side by side of an FS14 and GF16.
Sorry to hijack your thread, great job and thanks for documenting. Makes sitting in a cubicle almost bearable.
Re: GF16 In The PSL
Posted: Mon Jan 18, 2016 12:58 pm
by Noles309
No worries, who doesn't like talking about their boat?
The FS14 was on my short list to. I went with the 16 for the two extra feet of length for the same amount of plywood.
Re: GF16 In The PSL
Posted: Mon Jan 18, 2016 3:13 pm
by 94'325is
That's my thinking as well, larger boat is always good. I believe I can squeeze the extra 2 feet in my garage w/ a swing tongue, that's my constraint.
Looking at your pictures, when you put in the PVC chase tubes for electrical and fuel lines did you use any fiberglass tape or was it just thickened resin? I really like that idea, in fact I'll probably be stealing a lot of them actually whenever I can start my new build. That grab bar especially!
Re: GF16 In The PSL
Posted: Mon Jan 18, 2016 8:17 pm
by Noles309
Ha, steal away. I used thickened epoxy to bed them in and then I glassed over them with 9 oz tape. Also, it would have been much easier to do one chase per side if I hadn't forgotten it and poured foam in the compartment that it needed to pass through
Re: GF16 In The PSL
Posted: Tue Jan 19, 2016 7:47 am
by 94'325is
Thanks again, this is all really good information to know moving forward. It's amazing how many small details go into the building process.
Re: GF16 In The PSL
Posted: Tue Jan 19, 2016 12:50 pm
by 94'325is
One more question for you, have you noticed any flexing in the bottom when running at full speed? I recall reading a few posts where people had said there was bottom flexing issues w/ 25hp and above. It wasn't a strength issue but I was curious if that was an issue or not. Also since you have the grab bar mounted permanently (really like that idea) you will have to stand back there all the time I assume? I saw tanks and a cooler in the bow, is that enough to offset the weight? Thanks!
Re: GF16 In The PSL
Posted: Tue Jan 19, 2016 6:30 pm
by Noles309
No flexing, but you can feel the water at speed if that makes any sense to you. It doesn't bother me any. I'm running a 20 though not a 25.
The driving position is fine. I also sit on the platform and drive quite a bit when I have a passenger. I don't need the cooler with a passenger, but alone I do. I strap it down on the front deck.
I need to try dropping the motor a notch just to see what it does. I'm also contemplating playing with the motor height some. I would like to get 30 out of it and I'm thinking if I raised it another inch or maybe a little more I may be able to get it.
Re: GF16 In The PSL
Posted: Tue Jan 19, 2016 9:58 pm
by TomW1
94'325 and Noles I was on Cracker Larry's GF 16 several years ago. There was no flexing. We were out in the bay off Crystal River in Florida about 5 miles. The waves started to show white caps so we headed in. His 25HP hit 30-32kts with both of us total weight of about 480 lbs on board. The GF16 is a great boat.
Re: GF16 In The PSL
Posted: Wed Mar 01, 2017 10:07 am
by 94'325is
Noles,
Do you by any chance have the measurement for the total height of your grab bar from the deck to the top? I'm working on sizing a grab bar and am between 42" and 48" and yours looks like it's in a good spot. Thanks!
Re: GF16 In The PSL
Posted: Wed Mar 01, 2017 11:06 am
The bottom is designed for 15 HP. Cracker Larry and several other builders have installed bigger engines and because of that, they reinforced the bottom with at least one extra layer of biaxial. This is perfectly fine and I think I mention that in the building notes.
If your engine is >15 HP, add one layer of biaxial each side and pay attention to the runners: epoxy them properly to the bottom.
Built that way, even with a 25, the bottom will not flex.
BTW, please post technical questions like this in the technical section, the one at the top.
I monitor those sections and reply every day.
Re: GF16 In The PSL
Posted: Wed Mar 01, 2017 11:08 am
For the grab bar, it depends on your height.
I am 5-10 and a 36" grab bar in my son's GF16 is fine.
My son is 6' and he would like a grab bar a couple inches higher.
Re: GF16 In The PSL
Posted: Sun Mar 05, 2017 12:05 pm
by Noles309
94'325is wrote: ↑Wed Mar 01, 2017 10:07 am
Noles,
I'll measure when I get home. Mine is actually a little too tall I think.
Re: GF16 In The PSL
Posted: Wed Feb 13, 2019 2:33 pm
by RickFenn
On these plans for the bottom panels. Are the measurements every 20 3/8”?
Re: GF16 In The PSL
Posted: Wed Feb 13, 2019 2:45 pm
by piperdown
RickFenn wrote: ↑Wed Feb 13, 2019 2:33 pm
While not addressed to me...no. From the back transom it's every 12" up to where the measurement is at 14 3/4". The last line for the bow is 20 3/8" from the end of the plywood sheet.
Re: GF16 In The PSL
Posted: Wed Feb 13, 2019 2:50 pm
by RickFenn
Thanks for the reply. Just got a little confused looking at it
Re: GF16 In The PSL
Posted: Wed Feb 13, 2019 3:34 pm
by piperdown
RickFenn wrote: ↑Wed Feb 13, 2019 2:50 pm
If my calculations are correct, the space between the 14 3/4" mark and the last line at the bow should be 15 5/8" then the 20 3/8" to the end of the plywood sheet.
Re: GF16 In The PSL
Posted: Sat Mar 16, 2019 2:58 pm
by Repton
Hi Gary,
Having just read your entire thread let me say that you have built a truly handsome boat! I have recently been toying with the idea of building another boat and was thinking of a river/lake panfish/crappie boat - something of narrow beam, flat bottom, in the 14-16 ft. range and comfortable for an <older> gentleman to fish in. Going through the Bateau line up it seems that the GF boats are ones most closely fitting those requirements.
I would necessarily want stick steering from a location nearer the bow than the GF16 "middle" seat which I understand is not movable due to structural constraints (see Jacques post in another thread). Also, as you suggested in your "druthers" , I would want a trolling motor also, but the bow transom of the GF16 does not easily lend itself to accommodating one.
I already have an almost brand new Merc. 20 4 str. with remote control, power trim and electric start and it seems that it would be an adequate motor for a "lightly" built GF16.
I note that you are using 2 - 3 gal. tanks instead of a 6. I guess that's for ease in getting them in and out of the bow compartment. Makes sense. I would like to stick with a portable tank but dragging it in and out of the boat is a pain in my FS17 (actually, FS 15.5 as I scaled the 17 down). So, I might conceivably go with a fixed tank up in the bow.
Rocker! It seems that every one of these GF's has had the rocker demon show up and not without a great deal of hair pulling and consternation. Even though the designer has acknowledged it's put there on purpose, that doesn't seem to dissuade most builders to stress about it until its "fixed". (sound familiar?). If there really is a good reason to "fix it", it would make more sense for those of us going forward to "fix" it before it happens. I.E., when cutting out the parts. Thoughts?
I believe you have worked out the bugs in your choice of paints - exactly what I would have chosen even before I started reading your build thread. I would even go with the same color combo as you did (if you didn't object too strongly
). I'd also go with the graphite - I did 3 coats on my boat and have run it over all sorts of bad things and nothing has yet cut through to the primer!
I'm just not sure yet....I still object to the high bow which is not seen on the type of boats I'm thinking of building. For one thing it makes for a longer trolling motor and its farther down to the water when you have to lean over the side a pick up a monster fish
Great boat! Great Job! Inspiring!
Bobby
Re: GF16 In The PSL
Posted: Sat Mar 16, 2019 4:40 pm
About the rocker: we don't want excessive rocker but many planing boats have a little bit of rocker in the stern half of the hull, like 1/2" for a 20' at DWL. As designed, the GF16 has 3/8" rocker in the last 8'. The boat works perfectly well that way.
Take in account the overlaps at the transom and you have something that looks like a shingle between 1/8 and 1/4". I would just fair that: the two combined will reduce porpoising if any.
A 100% flat run (rocker less than 1/8") is not needed here, it's not a speed hull and I prefer stability.
I have a GF16 with the designed rocker and with a 20HP and 2 persons on board, factory Al prop, we top at 28 mph. That's enough for that boat.
Re: GF16 In The PSL
Posted: Sat Mar 16, 2019 10:40 pm
by txjm
I think stick steer from the middle seat would work great on this boat. That would move weight forward where it needs to be. I am in the process of deciding on a trolling motor on mine. I don't think it will be a big stretch to do but I think it will mean a moving some of the stuff(like gas) back under the rear seat. When I stand on the front of the boat the rear is barely in the water. standing between the front deck and middle seat would work great.
The 20 will be great. Anything over that is likely too much unless you are running a real heavy load. I also hit about 28 with a 20hp tohatsu.
With stick steer from the middle, you could likely put gas under the middle seat, even fixed.
I got rocker also. I added a few layers of 12 oz biax and flattened it out to dead flat. I had what everyone worried about, porpoising. It really seems that weigh distribution is the culprit and not rocker. A cavitation plate fixed all my problems. I don't know if I would worry about it. I sure wouldn't let the fear of a little rocker steer you away from the GF series. It is easy to prevent or fix if it bothers you. be careful when putting the bottom on and you can prevent most of it.
I love the boat so far.
Re: GF16 In The PSL
Posted: Sun Mar 17, 2019 9:28 am
by Noles309
Thanks Bobby, Tally is my hometown btw
I'm with Jim, stick steer from the mid seat would be ideal in this boat. I like his idea of the fuel tank in the mid seat as well in this configuration. I run solo a lot and you need weight forward in that scenario, which was why I put my fuel up front. I used two 3 gal tanks because in most cases 3 gal is plenty and it was easier to fit the shorter 3 gal tanks up front and when full, 3 gal is way easier to handle than 6.
The 20 is a perfect motor for this boat. I would like to try a 25 two stroke one day though.
I don't have a patent on anything on my boat copy away
Re: GF16 In The PSL
Posted: Sun Mar 17, 2019 12:17 pm
Yes, weight distribution is the main culprit when ti comes to porpoising but a little unbalance between rocker and a shingle helps a little bit. It's like two forces working against each other when the boat begins to porpoise.
It is something that most builders will not notice.
Re: GF16 In The PSL
Posted: Tue Apr 02, 2019 7:56 am
by Repton
Gary,
Couple of questions...
You built exactly by the plans, correct?
You indicate that your boat floats in 4" and am curious to know if you could provide some info as to your weight distribution when its floating at 4". Like, say, 2 half full 3 gal. gas cans in the bow, motor and battery (what size and weight?) in the stern, anything else (weight and location) of significance? Obviously, no people included, right?
Is it really exactly 4" or just somewhere in the neighborhood of 4"? Doesn't really matter to me what it is, but am more curious as to the precision of that number.
Do you know the finished weight of your boat? Just the hull, the wood, glass and paint?
This will information will be very helpful to me going forward.
thanks,
Bobby
Re: GF16 In The PSL
Posted: Tue Apr 02, 2019 3:32 pm
by TomW1
Noles the GF16 with a 25 2 stroke Merc by CL ran 32 knots with our combined 500 lbs a small cooler and tackle. He had put two 12oz layers of fiberglass on it to stiffen it up. He also had a Doel Fin on the motor to account for porpoising.
Re: GF16 In The PSL
Posted: Tue Apr 02, 2019 4:53 pm
by TomW1
Bobby don't worry about the high bow it is a small boat and the front transom can be cut down some and then a block placed under the mounting for the trolling motor. I believe a 48 or 56 inch standard trolling motor will work well. I would not even be adverse to just cutting down a short section of the transom for the trolling motor. That would keep the keep the general look with the trolling motor replacing the part you cut out.
Re: GF16 In The PSL
Posted: Tue Apr 02, 2019 5:35 pm
by Noles309
Repton wrote: ↑Tue Apr 02, 2019 7:56 am
Gary,
thanks,
Bobby
Hey Bobby, Yes I built to the plans with the exception of raising the transom.
I don't know the finished weight. The draft was measured by me out of the boat and no passengers. Draft was around 4" I don't remember the exact measurement.
The 20 Nissan with electric start weighs like 90 lbs. I have a real small motorcycle battery under the back deck, it weighs about 10 lbs. Two full 3 gal fuel tanks and anchor under the front deck. Yeti 35 strapped to front deck. FG push pole and stick anchor and misc other small stuff was the load out when I measured.
Re: GF16 In The PSL
Posted: Wed Apr 03, 2019 9:09 am
by Repton
Gary,
thanks for that information.
Are you in Savanah forever or will you be back in Tally anytime soon?
thanks
Re: GF16 In The PSL
Posted: Wed Apr 03, 2019 6:50 pm
by Noles309
Pretty much forever...we visit occasionally my dad and brother are there.
Re: GF16 In The PSL
Posted: Sat Jun 18, 2022 11:28 am
by MBMurphy3
cedarock wrote: ↑Mon Mar 24, 2014 8:17 pm
I pop in from time to time to see how my fellow boat building friends are doing and tend to follow boat building threads about boats that I am familiar with a little more often. When I saw this thread about the rocker, I sent Gary a PM about my experience with my gf14. I advised not to let the rocker go and thought about it and think that it should be shared for everyone to ponder and to help Gary and future builders come to the right conclusion.
I checked the bottom of my boat once while building and thought that it was flat from the mid seat back, which is what I had read in threads dating way back on the gfs. I launched with an old mariner 15 and was quite happy. It would push the boat 23-24 mph by myself and would plane okay with my wife and small dogs. Later, My brother and I took it out to the flounder hole and he weighs a touch more than Maggie!
The boat really struggled to get on plane with that extra weight up front. I also noticed that the bow was riding higher than I thought it should and it would porpoise really bad by myself. I was okay for a while but about six months went by and I started to question what was going on. I then checked the bottom closely and found pretty much the exact rocker as is in this thread. Last 20 inches or so had 1/4 inch of rocker. My thoughts were that the boat was trying to run on that 20 inches. By adding weight, the motor struggled to lift the bow to run on that planning surface. Thinking about how to correct my mistake...... I decided to turn it over and take out the rocker. Luckily, I used graphite on the bottom and up the sides a bit. I taped the paint and sanded the graphite down some. I glued a 1/4 piece of ply to take half of the rocker out, cutting around the runners. I shaped it down with a grinder to about 1/8 inch thick toward the bow and used biaxal strips at varied widths to build up and take out the rest of the 10" or so of the rocker. I covered the ply and the biaxal strips with a full piece of biaxal. And then one more piece to cover the entire patch and around the sides a little. Then a new fillet along the runners and taped them again to tie it all together. Faired and rolled some graphite on it all.
I noticed a difference right away. The boat would run with a lower bow at 27 mph by myself with the same motor. No problem planing with two and porpoising was all but gone while running solo. I don't know if my repair was the best way but it has worked well for a couple of years and if it fails (don't think it will), a gf16 will be in the future with no rocker in the last 20 inches. I am sure that more horsepower would have overcome my situation and I thought about getting a 25 before the repair. I did replace the mariner with a four stoke 15, due to dependability of the mariner, and it performs the same with the heavier motor. Does any of this make sense or am I just obsessive about getting the best performance possible!
My son and I are building a GF16. We noticed the 1/4" gap from the bottom of the stern transom to the work table we are using. We noticed it before we flipped and installed the bottom. We reviewed various threads for the GF16 and found this rake is common (probably universal). There seemed to be two approaches. "No big deal . Leave it." and "Probably best to fix it". Reading the "post bottom installation" solutions they all seemed like a pain in the stern. We decided to fix it before the bottom was fixed to the transom. We placed a 1/4" x 3/4" strip across the beam on the bottom panel where the bottom of the boat meets the bottom of the transom. We stitched the bottom panel leaving a gap which tapered from 1/4" at the stern to 0" about 20" going toward the bow. We glue/puttied the gap. This was a mega simple way to fix the problem. Thanks to every that posts. It is a great help to know in advance what we are facing.
Re: GF16 In The PSL
Posted: Sat Jun 18, 2022 4:43 pm
by Noles309
Cool....That's the easy way to fix it for sure.
