In order to help introduce these products to our customers, we will be offering a very good
Here is a link to the EMC section of Boatbuildercentral.com
EMC Products
no topcoat (Sterling, Awlgrip, EMC, etc.) paints are OK below the water line for extended periods of time. If your boat lives on a trailer, then its fine to paint the bottom with topcoat. 2 weeks or more in the water at one time will not hurt most of them either. If your boat will ive in the water, then you need a true bottom paint.What paint should I use below the water line? Unless I'm missing something, which is not beyond the realm of possibility, all of the EMC paints are only for use above the water line.
Yes, to all the above. We will be adding quarts of reducer to the store todayMy boat is small and I was leaning toward using white, so a quart of base and a quart of activator. Do I need a brushing reducer, and if I do, is it available in quart size?
sterling brushing catalyst has always been available in pintsYou can get Awlgrip in pints where EMC & Sterling you have to buy in quarts or gallons.
I can spray but I want to try roll/tip just for the mess factor and not having to mask off the whole garage basically.
