Hello All,
Can standard biaxial cloth be cut into stripes and used instead of fiberglass tape? If yes, what can be done to prevent fraying of the edges? Thanks in advance...
Fiberglass Tape for FL 14
Re: Fiberglass Tape for FL 14
The tape I've used was coarsely sewn along the edges to keep it from unraveling. I suppose the process would be to mark the sheet of biaxial fabric into proposed strips, sew inside both edges of each strip, and then cut into tape. I don't know what your options are, but my choice is to buy the tape!
Thanks very much Hank. Unfortunately the FG tapes that I've found are narrower and weaker than the required ones. So it looks like I have to cut my own strips... Still looking for a more suitable solution...
Hi Alpin
Yes to the biax cloth cut into strips. It is pretty heavy.
I recommend a trip to the local sewing store ask for a rolling fabric cutter and some extra blades.
put the cloth on a flat level surface and roll away. I have never worn out one of the cutters but have never cut a lot of fabric either. Scissors work but it tends to be a rough cut.
mark
mark
Yes, I often do that with left over pieces. Fiberglass tape starts out in 50"wide rolls and is cut to 5 1/2" tape from that. Doesn't matter much if you do it or a machine at the factory does it.Can standard biaxial cloth be cut into stripes and used instead of fiberglass tape?
Actually, you want the edges to be frayed, it helps a lot with the fairing.Those hard factory cut edges are harder to fair than a hand cut ragged edge. Either way you have to sand them out to a feather edge before fairing.If yes, what can be done to prevent fraying of the edges? Thanks in advance...
Thank you all folks. Your responses are very helpful for me...
Users browsing this forum: Yandex [Bot] and 1 guest
