PH18 foam core....
So, I saw that many epoxy the base of their bilge pump right to the bottom (the pump itself is removable for maintenance)
So, I mixed up some structural epoxy, laid down a glob and put the pump in place. Checked it tonight and the bottom of the pump stuck, but hardly. With a little pressure from the side it released, just like if it was a mold surface. Must be the type of plastic that was used?
It us a Rule 2000 GPH.
I hate the idea of using screws, any ideas? 5200 ?
Adhering bilge pump base
Re: Adhering bilge pump base
5200 will hold it. I usually glue in a plywood pad and screw to it, but 5200 will work if you don't want screws.
I used 4000UV because thats what I had on hand. Its easier to get off than 5200/4200 and it doesn't turn yellow when exposed to UV.
A 3m rep recommended it to me. I had never heard of it.
http://solutions.3m.com/wps/portal/3M/e ... 747&rt=rud
http://www.jamestowndistributors.com/us ... 7AodWEMADg
Gary
GF-16 Completed
GF-16 Completed
The 4000 is more of a sealant than an adhesive. It might work for a while though. 5200 can glue grease to ice cubes
5200 or 4200 or lifeseal - the later being my favorite
they will hold plastic very well
When the sun expands in the far future, and rips the earth apart, there will still be orbitting the bloated red-giant sun, blobs of 5200, and the Brooklyn Bridge. Learned astro-archeologists will recognize both immediately.
- Walkers Run
I glued 2 of the same pumps in with thickened epoxy. I first ruffed up the base with 60 grit. I seams stuck good. Time will tell
Thanks, I am going to try that first so as to avoid screws if possible. If it will not stand a good yank or two I'll have to drill and seal with some short screws...
I think if you rough it up good then flash it gentle with a propane torch it will bond with epoxy. That's what I do with pvc and it holds pretty dang good. Let some of the thickened epoxy ooze up through the screw holes in the base and get inside a little, it won't come off.
Seems simpler to use a squirt of 5200 though.
CL, great idea. I had not of heating it up. And yes it should hold real well with little grabbers coming up through the holes. Thanks!
