[quote="byboatbuilder"]Note picture of FS 17 Completed Stitching.
Those panels sure fit well!
your first attempt you used the location of the photo on your computer, not in the gallery. Use the preview button to check if you have it right, that will save you some effort.
OB17 vs FS17
Re: OB17 vs FS17
Re: OB17 vs FS17
Perfect stitching job. Nice
Re: OB17 vs FS17
Thanks for the picture posting help and your kind comments.
Re: OB17 vs FS17
Build is going great! For planning purposes I need some advice regarding the location and size of chase tubes for a teleflex steering system, engine controls and,of course, electrical. Will build a center console and am considering locating the gas tank under the console or seat area and would appreciate any thoughts as to the size and location of the tank for a 40hp 4s. The gas line will have its own chase.
Re: OB17 vs FS17
Same for all boats: 2" or more OD, min. 24" radius for the turns, holes in framing close to the top, not the bottom, fuel in separate chase tube.byboatbuilder wrote:Build is going great! For planning purposes I need some advice regarding the location and size of chase tubes for a teleflex steering system, engine controls and,of course, electrical.
Under console and size is up to you. I would say 25 gallons, max. 40.
Re: OB17 vs FS17
Thanks Jacques for you usual prompt response..
Re: OB17 vs FS17
Since I will be painting the hull shortly, what are your supplier recommendations for superior quality paint and primer?
- remedy32
Re: OB17 vs FS17
40 hp at full throttle will burn about 4gph. That would produce a speed of about 30mph or a bit more. 75% power would be about 22-24 mph at about 3 gph and much more comfortable if there's any chop.I'd decide how much range I need and go from there. We got a 9 gal. above deck tank for our FS17 new at a very low price, like 30 bucks. It's mounted under the console/seat. This runs our older 40 2 stroke for 3-4 hours of fishing at mixed speed between trolling and covering distance. Max range is about 40 miles in our case. I'd think 15-20 gal. would be plenty in most cases. Take a look at the 18 gal. Moeller for instance. I do like the small tank because it's easy to get all the fuel out at the end of season and not have funky gas issues the following spring.
I routed the Teleflex steering cable from the CC area up to the enclosed starboard gunwale, then back inside it to the transom. This has worked out fine and is easy to push the cable through. Cracker Larry's OD18 picture is worth a look. Think he reposted it about 10 days ago. Just copy (more or less ) and you'll probably be happy.
Bill
CT
Bill
CT
Re: OB17 vs FS17
Thanks Bill for your continued interest and practical advise that is most helpful in my planning process. My wife and I are going to Beaufort, NC this weekend and plan to look at a number of boat color combinations since this area is the wooden boat building hub of or state.
Re: OB17 vs FS17
Right here is a good place to get it. The System 3 high build yacht primer is hard to beat, as are the EMC topcoat paints. I do not recommend S3 for topcoats. They make a great primer, but the paints not so good.Since I will be painting the hull shortly, what are your supplier recommendations for superior quality paint and primer?
I put a 40 gallon tank in my OD18 and with a 70hp 2 stroke Yamaha I can run for 2 full days easy. Range is about 300 miles.
