OB17 vs FS17
Re: OB17 vs FS17
Thanks so much for your expert advice regarding the System 3 primer.
Re: OB17 vs FS17
Larry, System Three came out with a new topcoat and you would be surprised: easier to apply and much higher gloss than the previous one.
We'll post about it when it goes in production. It will be less than half price of a solvent based LPU like EMC, easier to use, very hard and looks good.
I am going to promote that paint.
PS: I agree about the old formulation.
Re: OB17 vs FS17
They sure did need too. The original sucked!Larry, System Three came out with a new topcoat and you would be surprised:
Re: OB17 vs FS17
Almost finished fairing with Quick Fair and have been pleased with the product. Sanding has gone well and everything looks good. I need some advice as to whether I need to add another coat of epoxy to seal the faring prior to priming. I have ordered and plan to use the System 3 primer.
Re: OB17 vs FS17
Finished fairing and plan to apply System 3 primer next week. Have not received a response to my previous post as to whether I need to seal the Quick Fair with epoxy prior to priming.
Re: OB17 vs FS17
No need to seal it just sand with 120 and apply the System 3. As I recall it is an epoxy based primer.
Re: OB17 vs FS17
That is correct, it's an epoxy based primer. No need for an additional seal coat.
Re: OB17 vs FS17
Just wanted to be certain before proceeding with the primer. Again, thanks so much for your advice.
Re: OB17 vs FS17
Finally I reached the flipping milestone stage of my FS 17 build. Since my retired friends can only lift around 20lbs on a good day I decided to purchased a chain hoist on line and a couple of cheap block and tackle pulleys from Harbor Freight and make this a one person flip. With the pulleys and hoist attached to my garage joists and my wife's help, what could have been a little stressful, turned out to be a piece of cake. Please note pics which show how this was done.
Re: OB17 vs FS17
Getting ready to start building my center console and need some advice regarding the best location for my batteries. Have a little more glassing and the interior will almost be complete. I plan to post some picks shortly . My gas tank is located just forward of the console under a casting platform I have included in the build and my concern is weight distribution. I will be installing a new 30 hp Suziki with a weight of approx. 160 lbs. My plan is to have a starting battery in addition to one for a 12 v trolling motor. I have storage available in a transom compartment for one battery (starting) and room in the console for both or just one. My other transom compartment looks as if it will be consumed with cables, wiring etc. Any suggestions will certainly be appreciated.
