Cvincent's PH18
Re: Cvincent's PH18
PS, what did you use to fill up the temporary dams for your reverse chines?
Re: Cvincent's PH18
LGF, I used a mixture of wood flour, milled fibers, and fumed silica. This mixture was difficult to sand/shape, but I wanted a very hard chine. I spent the weekend sanding the high areas and shaping with a long board. If I did this again, I would consider using plywood cut at an angle like others here have done instead of using a dam with epoxy.
Completed D15, Completed PH18
Re: Cvincent's PH18
It was 90degrees this afternoon so I attempted to post cure the outside lamination on the transom. I used 2 electric heaters and a tarp and tried not to start a fire. I was only able to get the temperature in the tent up to 110degrees. I need to pick up a heater with more output and try again. I am debating adding a 2nd layer of 12oz biaxial to the bottom panel, but I am not certain that it is necessary.
Picture of one of the reverse chines with dam removed and some shaping.
Re: Cvincent's PH18
Looks real nice and clean. Congrats!
Re: Cvincent's PH18
Looking good. Keep it up!
Re: Cvincent's PH18
Agree, you are really making some good progress!! Jeff
Re: Cvincent's PH18
I started filling the weave, the first coat went on Sunday. I used a loose slurry of epoxy and microballoons for the first round. I will most probably sand and do 4 more rounds of microballoons, then switch to quickfair to fill lows, then high build primer.
Re: Cvincent's PH18
That looks textbook perfect! Thanks for sharing, looking good. What are you using to sand, longboard?
Re: Cvincent's PH18
Cvincent, really nice work!!! Jeff
Re: Cvincent's PH18
Yes, I am using longboards for sanding. I will switch to a RO sander to finish up once I have the lows filled in. Thanks
Users browsing this forum: Google [Bot] and 4 guests
