sailboat kit construction bow.
Working on a CR13 kit I can't see any way tho get the bottom panels to join at the bow. Is there a trick to doing this? Help, I can't proceed!
Re: sailboat kit construction bow.
Please post pictures.
Start with very loose stitches and do not try to push the panels against the frames.
I've tried loose stitches, tight stitches, no stitches and I can't get the right and left bottom panels to come together at the bow to make the shape required. The wood doesn't bend/twist enough to bring the curves together. Without this I'm left with a $2K pile of scrap plywood. Very frustrating!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Many of those boats were built, we will help you solve the problem but without pictures, it is very difficult.
With pictures, I will see what the extent of the problem is, where the panels touch and propose solutions.
Do the panels push against each other? Where? At chine or keel? How far from the bow? Or is there a gap? How much? Or is it an interference with the frames?
I want to help but to say that it does not bend does not give me enough information.
The bow on my boat was difficult, but as Jacques said, a large number of his boats have been built by people who have never done this kind of thing before, like me. I struggled with the bow on my V10 in the same way you are, and if you search the forums, you will find many descriptions of people dealing with this. As he says, upload some photos and Jacques and others will be able to assist you.
Tony
Here's what I eventually resorted to, although most builders don't find it necessary to go to these lengths:
Tony
The V10 and V12 are tight but I have pictures of some other boat bows were the panels meet when the builder push with one finger.
The CR13 should be something in between but as soon as we see pictures, we can propose solutions.
Hi,
Bending sheets can be difficult but not undo-able, Try doing this.
Take the sharpest point with the most curve that is usually at the sharpest point at the bow and stitch that first don't stitch the rest of the sheet together, put lots of stitches in at first as many as an inch apart (2.5cm) Make sure you use good quality zip ties, then slowly expand that as you get away from the curviest part. Get a friend to hold the un-stitched part up so you can do your stitching, if you can't get help use a box,chair anything to help support the un-stitched side. I hope this is helpfull. Regards Salvatore.
I put a million stitches in my V12, started with them loose then just worked around methodically like replacing and tightening wheel nuts, slowly tightening each zip tie. You really have to tease them in. It was hard, but eventually came together.
I imagine Tony's was even harder being a slightly smaller hull (V10) needing almost the same curve.
Keep at it, it will come together.
Good luck
Cam.
Completed:
CC14 Canoe
V12 Sailing Dinghy
In Progress:
D5 dinghy
CC14 Canoe
V12 Sailing Dinghy
In Progress:
D5 dinghy
Looks good!! Jeff
