1. I'm an idiot
2. Angle grinder + 40g flap wheel == need to express point 1.
3. Knowing that I get to go over it again with paste makes me feel that point 2 is less of an issue.
Question: do I need the double layer transom? If I get a motor it will be an electric and under 3hp. I'm thinking all I need is the one layer. Thoughts?
Jaysen's V12 -- 'Lil Bit' of everything fun
Re: Jaysen's V12 -- 'Lil Bit' of everything fun
Jaysen, I don't think you need more than 1 if you are going to use a small electric motor. Let's wait and let Fuzz or Cracker Larry give you a final opinion!! Jeff
An angle grinder is an implement of destruction. I only use those when tearing a boat apart, not for building one We've all been idiots at least once, sometimes more than once I leave the angle grinder on the shelf, right along with the belt sander, when building a boat.
If you don't double the transom, at least put a clamping board 8 or 10" high along the entire top. If it were me, I'd double it and put a clamping board. Never know what the future might bring. I've never been known to under build anything though
In my defense I was destroying the glops of epoxy.
My only "concern" is the added weight. It's not much but I've realized that the transport cart may not like the added weight of the glassed bottom. I thought that maybe a decent trade off would be the double transom for the glass on the bottom.
Well... Looks like it's going to be "fix puzzle joints first". Just had one decide it was not glued properly enough so it let go. Nothing that can't be put back together.
Those glops of epoxy are much easier to clean up when wet. Saves a lot of work and sanding. Try to work clean, don't leave glops to dry and sand off. I'd put a layer of tape over those puzzle joints.
Tape? Packing tape?
The glops are from the not-thick-as-peanut-butter glue running through the joint. Can see right through a few spots post "idiot".
No, 6" fiberglass tape. Glass one side with tape, let it cure. Fill the joint good with thickened epoxy on the other side, the glass tape will hold in the glue. Strike it off clean with a plastic spreader. No sanding necessary. And don't put that plastic sheeting on top of it, it just makes a mess and creates more work. Use what you need to not glue it to the floor underneath though.Tape? Packing tape?
Jaysen I would do everything Cracker Larry says. He is THE MAN when it comes to building these boats
As for the transom I would bet one layer would be strong enough but that would limit your options. Maybe you or somebody else will want to put a motor on it at a later date and then that little extra glass would have sure been nice Either way it will be interesting to see how it turns out.
Recovery from plan:
1. Let wood dry (some idiot fell asleep and it rained without the cover)
2. Use CL glass tape method putting tape on INSIDE of hull panels.
3. Glue up all doubled pieces including transom.
4. Get back on assembly schedule.
Only really sets me back 4 days but I have a lot of working time tomorrow. Shouldn't be more than a day behind by tomorrow evening.
