I'm planning on replacing all of my under deck bulkheads, stringers, and transom from the inside.
Can anyone provide me with proper bracing and support during the repairs?
Thanks
support structure for repairs
Re: support structure for repairs
Mulltr66, I am sure you can get good guidance and support here on our Builders Forum. Why don't you start by giving a good description of the boat, name, size width, engine and then post a few good clear photos showing a measuring of one form or another so we can get and understand the length and width of what you are proposing!! Good luck and enjoy!! Jeff
I'm converting from an I/O to twin 150 outboards.
Good, now we have a starting point!! Thank you, Jeff
I would build a full cradle and put it under the hull. Try to mirror the stringers from the outside. Doing more than just that would be good. After you cut out the stringers I guarantee the hull is going to be flexible and you will lose the shape if it is not very well supported. A normal fibreglass hull is a wet noodle until it has some stringers in it.
Fuzz
Fuzz
