Deck Replacement, Divinylcell thickness?
Planning a composite rebuild on a 15' scooter boat. (Deck, & transom) What thickness of divinylcell for deck replacement ? Laminating shedule? Also, core recommendation and laminating schedule for transom?
Re: Deck Replacement, Divinylcell thickness?
Formula Red, Give Jacques a little time to respond as he is currently on travel. Jeff
this will at least give you an idea of what youll need for the deck,
http://multihullblog.com/2010/11/plywoo ... omparison/
Tungsten, thank you for assisting Formula Red. We are all a little behind due to Hurricane Matthew so give Jacques a little more time to give Formula Red some guidance!! Jeff
Not applicable to our boats. That is a very weird table, we must be missing something.Tungsten wrote:this will at least give you an idea of what youll need for the deck,
Please post repair questions in the repair section. We will move this thread.
Please see this:Formula Red wrote:Planning a composite rebuild on a 15' scooter boat. (Deck, & transom) What thickness of divinylcell for deck replacement ? Laminating shedule? Also, core recommendation and laminating schedule for transom?
http://forums.bateau2.com/viewtopic.php?f=10&t=13371
What is a scooter boat? A TX scooter?
What is the framing that supports that deck?
I need to know the framing and the type of bond between deck, framing and sheer.
How about the transom? What do you now? Any stringer bonded to the transom?
http://gallery.bateau2.com/displayimage ... play_media
Having trouble posting pics. There are 2 pics above linked from formula red gallery.
The scooter boat is a 1990 Majek 15' Scooter. Deck has not been removed yet. I have determined the stringer layout by cutting a few of 3" holes and probing a small rod until I hit the stringers. The current deck is 1/2" ply.
3 Stringers(not top hat), from center stringer to outer stringers is approximately 22" , from outer stringers to edge of boat is approximately 15".
Would like to go with composites. Sugestions for stringer material and spacing if they need replacing, deck material and thickness and lamination schedule. Thank You!
Thanks, I can work with that. Give me a couple hours.
