At the beginning of July I moved the boat to the yacht club to rig it.
I ran steering hoses, wiring harness, and control cables from the engine to console.
Imgur Album
I installed the helm and throttle in the console.
Imgur Album
Hooked up the steering at the engine end and bled the system. Also ran the harness and control cables through a rigging tube and connected them at the engine. Was using the Suzuki factory service manual for all of it. For the engine I also installed a cheap amazon prop to start with.
Imgur Album
Made all the harness connections at the console and installed the ignition switch and troll mode switch. Also installed the switch panel.
Imgur Album
Had some help from the pup when it was my time to watch him but he was in his teenage phase and didn't always help progress. Still fun to have have around.
Imgur Album
Installed my MFDs and VHF and got to test out night mode while I was working late. At this point I also had the compass and light/antenna mast installed. Also the stereo which is a black box in the console you control through the MFD or a small remote.
Imgur Album
I had all of critical equipment wired up even though the switch panel wasn't connected yet.
Imgur Album
And the NMEA fuel level sender was hooked up too.
Imgur Album
There was still plenty to do but nothing that couldn't happen while in the water in her slip so I launched her under her own power for the first time at the very beginning of August. I was worried about how long the engine had been sitting having never run so I squirted some fogging oil in to each cylinder and used the prop to turn it over by hand a few times. Got everything secured again and backed her into the water. Engine fired up like it had been running 5 minutes ago... something I had honestly been stressing about for weeks doing all the rigging myself with no experience.
My fiancee was traveling but had a few friends who had helped do some priming earlier in the build come for the first trip. I had the break in procedure written on an index card and we followed that as we got the first hour run time on the clock. One of my favorite parts is just how quiet these modern 4 stokes are. Quick clip of the first trip with 18 minutes on the engine.
https://youtu.be/EljZDBe9E1A
