Got a little bit done today.
There were no cars parked at work so I popped the canoe outside and knocked back the first coat of lightweight filler a bit and had a little scurry about with a palm sander on the inside. Took the opportunity to get some pickies.
You can see that the woven tape I used didn't lay down nicely. It has a knitted edge that as well as being thicker than the tape, stops it from taking a curve. The holes you can see at each end are tubes I made from bi-ax, fitted through oversized holes and filleted, and glassed internally. They will be for the painters and also used as hanging points for storage.
I have made a little space in the compartments at each end that I'll fill with foam.
The little decks will be 1" thick foam sandwich and I intend to make the seats out of 65mm foam.
I put the boat back inside and got some more fairing mix on the bottom and upper panels. Also glassed the foam for the seats.
