Recoat with epoxy and try to find better than a one to one epoxy. Resins 2:1 or more are harder.
On the bottom, mix the resin with graphite power, it is inexpensive and very hard.
Stuart's D5 Dinghy.
Re: Stuart's D5 Dinghy.
Thanks Jacques. I used west for the build but only have a little left. The damage was largely to a non structural area. I won’t be putting the outboard there again so I hope to avoid repeats. I am thinking about graphite on the bottom though it’s not easy to find in NZ except art supplies or small bottles for keyholes. I used west 420 Aluminium powder which seems to have given a fair bit of scratch resistance.
Good info about the epoxy.
You had me considering aluminum. What caused those scratches? Logs. Sand. Buildings?
Scratches to the bottom are largely river stones and boat ramps (the small ones that barely mar the surface.) The deepest scratch I am pretty sure is either the time I scrapped over a rock at low tide with two in the boat or scratches from the steel trailer I put it in. The side scratches are definitely that trailer but they don't bother me as it's paint only. The epoxy I put on under is untouched. I covered the whole outside with a coat of aluminium powder epoxy mix.
I have worked on my trailering technique and now have a decent mat and groundsheet to lay it on. No damage since. I am putting it down to teething issues rather than the materials or use of the boat.
The launch wheels work a treat. The skeg hasn't been called upon to take any damage at all yet. I put the wheels down in the water and nosy in to the ramp.
I did buy some flatbar aluminium for $5. 1m by 20mm by 1.6mm. About 3.5' by 1'' by 1/16''. I'll glue it on at the end of the season or earlier if I get around to it.
A nice build, well done!
Cheers. It was definitely a learning experience. I am taking more care with my second build. Bought a quality jigsaw with clean cut blades and decent circular saw. Also a full size set square (probably one of the biggest omisions in the dinghy.)
