Sk 14 SSI Ga
Re: Sk 14 SSI Ga
EDD, tell me again what sine HP is that motor? Jeff
Re: Sk 14 SSI Ga
Photo says it's a 9.8
Re: Sk 14 SSI Ga
Thanks Jaysen!! I could not read it!! Jeff
Re: Sk 14 SSI Ga
I had to click on the photo then enlarge it in the browser. My eyes are too old for those little pixels these days.
Re: Sk 14 SSI Ga
Very cool looking ride you got there!
Re: Sk 14 SSI Ga
I finally got around to priming and painting the top side. And cut out the scupper hole too.
Re: Sk 14 SSI Ga
Edd, looks good!! Jeff
Re: Sk 14 SSI Ga
Sweet. Looks mighty good!
Re: Sk 14 SSI Ga
I'm 99.9999% done. I just need to finish some wiring and mount the rear light.
I tested it out today with the 9.8hp in the wind and chop and I was able to run a consistent 18.6mph. I thought I might be able to go faster, but I guess my beefing it up has something to do with it (extra foam and framing triple layer backer and knees, "heavy duty" glassing etc). I haven't weighed the hull, but when flipping it for painting it was easy for me and my neighbor. But it is very rigid. I did have the gas tank full and the cooler full of water in order to see what it would do loaded, and I'm about 220lb. It planes off very quickly though and when idling you can turn it on a dime. It ran really good through the chop too. It didn't doesn't spray water either. Its surprisingly stable too. It's really easy to step in and out of when you are in about 1-2 feet of water. It performs better than I was expecting really.
I enjoyed this project. I was way off on how long I told my wife it would take I'm read to put it to use.
I did want to share something I discovered. the interstate battery store sells small, like 5-10lb small deep cycle batteries. I found them a while back while working on a different project. I bought one for this boat to run the lights and fish finder. It will be housed in the orange dry box. It's actually got enough powe to start the tohatsu that's on the boat; it's a manual and electric start.
Re: Sk 14 SSI Ga
Turned out really well. Looks great navigating the twisty creeks we have around here. Well done!
