Hi TomW - my engine is a 2012 F150BET - I believe having looked it up that it’s max rpm is 5500 … so maybe I am closer than we thought?
C19 Stretch and re-build - Launched!!
Re: C19 Stretch and re-build - Launched!!
Okay Tom the motor spec I got were for 5000-6000 and peak HP at 5500. But let's go with yours as they have made motors for other parts of the world before, I also just found the same specs today. So, in that case your prop needs no change. If you want to go to a 4blade drop to a 15 pitch if you can find the diameter, it should be on the barrel of the prop. Or if not get me the manufacturer and I can probably find it. They usually use one diameter with multiple pitch sizes. Or, if it is from a local shop you can take it to them and have them give you the diameter and recommend a 4Blade.
Let me know what you want to do on the 4Blade. Tom
Thanks Tom - what do I buy myself with a 4 blade?TomW1 wrote: ↑Wed Jan 19, 2022 3:23 pm Okay Tom the motor spec I got were for 5000-6000 and peak HP at 5500. But let's go with yours as they have made motors for other parts of the world before, I also just found the same specs today. So, in that case your prop needs no change. If you want to go to a 4blade drop to a 15 pitch if you can find the diameter, it should be on the barrel of the prop. Or if not get me the manufacturer and I can probably find it. They usually use one diameter with multiple pitch sizes. Or, if it is from a local shop you can take it to them and have them give you the diameter and recommend a 4Blade.
Could I get lower RPMs at trolling speeds?
Could I get a faster top speed?
Ive heard certain propellers are better at keeping the nose down on a boat ... is this true?
You will lose 3-4 mph top end but gain an easier handling boat. Also, in rougher water it will help in steering and handling. This means keeping the nose down, but this depends on the rake of the prop. There are 4 parts of a prop diameter, pitch, rake and cup. The diameter and pitch set the basic size of the prop and speed of the boat. Rake and cup indicate how the prop will perform. Increasing rake or cup by too much will increase bow lift. Each increase the water held on the blade.TomTom wrote: ↑Thu Jan 20, 2022 11:41 amThanks Tom - what do I buy myself with a 4 blade?TomW1 wrote: ↑Wed Jan 19, 2022 3:23 pm Okay Tom the motor spec I got were for 5000-6000 and peak HP at 5500. But let's go with yours as they have made motors for other parts of the world before, I also just found the same specs today. So, in that case your prop needs no change. If you want to go to a 4blade drop to a 15 pitch if you can find the diameter, it should be on the barrel of the prop. Or if not get me the manufacturer and I can probably find it. They usually use one diameter with multiple pitch sizes. Or, if it is from a local shop you can take it to them and have them give you the diameter and recommend a 4Blade.
Could I get lower RPMs at trolling speeds? A couple hundred.
Could I get a faster top speed? No top speed will decrease slightly.
Ive heard certain propellers are better at keeping the nose down on a boat ... is this true? Yes, read on, it depends on rake and cup.
In conclusion a 4blade prop with low to moderate rake and cup is what you are looking for. In whatever diameter you find by 15 since we decided the 17 pitch was fine. Let me know what brands are available to you and I can help. Solas are available worldwide, I don't know what is available to you.
Let me know if I can help more. Tom
Hi TomW - many thanks. I will measure the diameter next time I am near the boat.
If my sole intention was to be able to troll at the lowest possible rpms would a 4 blade still be the way to go and do you think I could shave some rpms off my 2000 rpm/ 7kt speed?
Tom, I would say yes as the 4blade grabs more water, you should be able to get down to 800-1000 rpms. This should give you 3-5 mph.
Regards, Tom
Regards, Tom
Also have some updated speeds … these are off the digital speedometer that works on a pitot tube/ water pressure…
5400 = 40 mph
4500=34 mph
3600 =25mph
3400 =23mph
3300=21mph
2800- 15 mph
2400 = 11-13 mph
2000- 2200 = 10 mph
1800 - 9mph
Tom was that your top speed at maximum rpm? Did you have any rpm's left? Tom
If I trim up slightly I can pick up about 2 extra mph … I haven’t seen the rpm go above 5400.
