Trim is a big concern. This boat rows very nicely with one and just fine with three. But with two, being down at the stern means that the boat is sluggish. A sandbag at the bow would have to weigh 100 lbs. That won't do.If the trim is the big concer... what about a sand bag on the forward seat?
Second rowing station for the V10.
Re: Second rowing station for the V10.
Tony
terrulian wrote: ↑Mon Jun 11, 2018 10:47 am Thanks very much, Jacques. Luckily, I'm short so that might help. Capt UB reports he managed it on his 6' dinghy.
I think I'm going to try it and report back. I will attempt to mount the new oarlocks temporarily somehow.
Bear in mind, this would be used only in the case where there weren't three on board and so the center seat passenger will not interfere with the rowing motion. My main concerns are the height of the bow seat, which is above the other two, and leg room. I have large holes in the center frame so maybe my toes can stick in there.
That dink was "PRETTY" and looked nice on the davits, it was far from a work boat! I had a RIB for the real work. The RIB had oar locks, noway could you row that beast!
Yep, you can get into vicious arguments on cruising sites (not that I would do that) over hard vs. soft dinghies.
There is absolutely no question about aesthetics, but as far as I'm concerned, no argument about the practicality of an inflatable either. You really don't want to put five jerry cans of diesel in a hard dink and then have to row a mile in chop! Perhaps a nesting dinghy would work but it depends on how much deck space you have and if you think davits will work for you.
We had one with an inflatable floor so 1/2-way between a RIB and a soft dinghy. It would get up and plane with two aboard easily. It doubled as a very comfortable seat on the foredeck when deflated. Among the downsides of a soft dinghy is that as you say, they won't row, so if your engine dies you are hosed. That happened to me in Bora Bora in a bunch of wind but a very nice local came along and not only towed me back to my boat, when I offered him a beer he gave me one instead!!
Tony
This was a free plan listed on our website 2 years ago. It is designed by my grandson Thomas, a yacht designer and fluid dynamics engineer.
He worked hard on it to make it easy to tow behind a sailboat, have good capacity and ability to perform well with two rowing locations.
I think he succeeded.
It is also efficiently sculled with a single oar.
Note the pram hull which stays wider forward than the V10 pointy bow.
We discussed the beam, thwarts height, footrests, knee positions etc. and the minimum length was 10 to 11'. That would be a hull length of 14' with a pointy bow.
Last week, I redesigned her for foam sandwich and tried to reduce her length. I could not go under the 10' while still being comfortable to row in the forward position.
Jacques,
The V10 tows fine, even in quite a bit of wind and chop. It is great in every way.
Tony
100lb? I'm not so sure. Now I know I'm dumber than your average box of rocks, but I think the same balance act for COG offset applies to V series as it does to the big monsters BUT since we are talking "water trim" we actually have a bit less as the hull is so much narrower on the bow of the Vs that it will drop much faster. I'm sure JM will call BS to that last part, but wide floats better than narrow.terrulian wrote: ↑Mon Jun 11, 2018 12:13 pmTrim is a big concern. This boat rows very nicely with one and just fine with three. But with two, being down at the stern means that the boat is sluggish. A sandbag at the bow would have to weigh 100 lbs. That won't do.If the trim is the big concer... what about a sand bag on the forward seat?
I think the math is that for every lb/ft you have behind you need the same put front. Remember that a lb/ft is the weight/distance from COG. So a 200lb person 2ft aft from cog (rear seat) would need 200lb 2ft forward of COG or 100lb 4 ft forward or 50lb 8ft forward. In all that math you need to figure your weight as well.
The big assumption here is that the hull displacement is constant at all points. If the displacement DOES count, then the displacement forward will be < than the displacement aft. I believe this comes out to something like
Code: Select all
(weight - displacement)lb/(distance from cog)ft
Like I said, I fully expect JM to call me all kinds of names and ban me from ever commenting on this topic again.
Jaysen,
All I know is that with a 200 lb rower (not me, yet) and 150 in the stern and 150 in the bow, she's trimmed just fine.
This is empirical. Don't know nothin' about no math.
Tony
Here's the trim with a 200 lb person aft, 100 lb forward, 160 lb amidship (weights are rough approximations):
Now with 200 lb amidship, 100 lb forward, 150 at the stern:
Tony
I guess it’s good I don’t have any friends (or spouse) willing to get into lil bit. Heck even the dog seems to look at her and say “are you nuts?”
