Thanks everyone for the help on the forums so far. It is greatly appreciated. I do find that it is sometimes difficult to find corroborated advice. I search the forums as much as I can, and post as little as I can to try not to repeat technical questions that have already been addressed. However, it sometimes seems the opinions can be greatly varied for single topics and the technical jargon confusing at times. Add in that its all done remotely, and it slows me down a bit. I certainly get the paralysis by analysis which has been mentioned in the forums before. Anyhow, it is still a fun project and I'm hoping to complete it soon.
CURRENT STATE: Runners are glued on and need to be glassed over. Spray rails will be glued on soon too. Fairing and sanding the hull coming up. (see questions below about sanding in last picture please)
I did not take many pictures of the inside of the boat during building, but I did do a fair amount of custom work before flipping it. I ran chase tubes, limber holes, drilled transom drain, drilled bow eye holes, made backer plates, made foam compartments and anchor locker, cut and framed hatches, and fabricated a bow rubrail. I will add photos in after I flip it again.
sanding threads How does this sanding of the threads look? Too deep into glass for the slurry fill? Is this what it needs to look like for the mechanical bond when not working wet on wet?
What respiratory protection do you guys use when sanding? N95 particle mask?
What do you use to clean up the boat after sanding, but before fairing? air only? clean rag? tack cloth? something else?
So far I've found the most difficult part was filleting the outside seems and getting a nice round edge. I've worked wet-on-wet for everything except my next step of glassing over the runners, which is another reason for the sanding questions above. I know I need the sanded bond between the two layers, but am not sure if the sanding in the picture above suffices for that purpose.
Thanks!
Chris
